02-07-2024, 03:31 PM | #179 | |
Rep 7,473
If you only wanted to utilize timing you become an NA engine, and like an NA engine, at some point you need boost to make more power. You also can more easily add boost compared to timing.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 02-07-2024 at 03:38 PM.. |
02-07-2024, 03:44 PM | #180 | |
Rep 4,174
Mods: Yes.
02-07-2024, 03:56 PM | #181 |
Rep 7,473
The issue is there's only so much timing you can add before you can't add anymore. That's why eventually you'll need boost.
02-07-2024, 04:02 PM | #182 | |
Rep 315
Your car is making some real good power. I'm seeing similar torque numbers just a lil higher due to more timing(ethanol and 13/14deg)..creeps above 700nm. We're still sitting around 20psi. Hoping we'll take a stab at 25psi soon. Tires spinning above 6k in 3rd is a real butt pucker moment lol. I'm" on the hunt for 18" 513m's or staying with 437's and drag radials for traction. |
M2guru409.00 |
02-07-2024, 04:10 PM | #183 | |
Rep 4,174
If you guys want, I can do a virtual dyno for you - just for fun.
Mods: Yes.
02-07-2024, 04:22 PM | #184 |
Rep 7,473
It's impossible to do a boost based tune on any tuning platform.... The DME architecture is load based and there's no way to change that unless you rewrite the entire DME logic.
VGSON220.50 CanadianM280.50 |
02-07-2024, 06:56 PM | #186 |
Rep 249
usually 2.9psi ≈ 2 degree timing, Once you final the tune. It's always safer to run more boost and back off the timing if your turbo still has room(in the efficiency range). The OTS map runs more timing with tapered boost because the stock turbo runs out of steam.
02-07-2024, 07:09 PM | #187 | |
Rep 711
Eclipse sounds sweet! My last car was an eclipse. Excited to see how your tuning progresses |
02-07-2024, 07:22 PM | #188 | |
Rep 711
Ethanol has higher octane (more knock resistance) than 93 so you can run more timing before hitting an octane limit than with 93. It's a little confounded though, because ethanol also burns slower than 93, so it already needs more timing to get to MTBT than on 93 does. Edit: What I said about burning speed above is incorrect. I just did some quick googling and it looks like higher ethanol blends have faster flame speeds than gasoline, for some reason I had it backwards Carry on! Last edited by wheela; 02-07-2024 at 09:27 PM.. |
02-08-2024, 10:41 AM | #189 | |
Rep 4,174
I compared mine against my actual dyno and it was spot on - 14% drivetrain loss was calculated to get the wheel HP numbers. Logs: https://datazap.me/u/amuroray/dyno-r...og=0&data=4-23 Graph: These were done on lower boost and more timing - the logs indicate that higher boost and less timing equaled more peak HP.
Mods: Yes.
02-08-2024, 01:51 PM | #190 | |
Rep 4,174
Sport Plus - (higher boost, lower timing) https://datazap.me/u/amuroray/3rd-4t...25-26-27-28-29 RPM | Boost| Timing| Torque (NM)| Engine HP 5800 | 19.5 | 5.5 | 553 | 450.4 5900 | 18.7 | 5.5 | 536 | 444.1 6000 | 18.2 | 6 | 530 | 446.6 6100 | 17.6 | 6.5 | 513 | 439.5 6200 | 17.5 | 6.5 | 500 | 435.4 6300 | 17.2 | 7.5 | 495 | 438 Comfort - (higher timing, Lower boost) https://datazap.me/u/amuroray/dyno-r...og=0&data=4-23 RPM | Boost| Timing | Torque (NM)| Engine HP 5800 | 5900 | 6000 | 16.0 | 9.5 | 514 | 433.1 6100 | 16.0 | 10 | 506 | 433.5 6200 | 15.7 | 10.5 | 502 | 437.1 6300 | 15.8 | 10.5 | 496 | 438.8
Mods: Yes.
02-08-2024, 04:20 PM | #191 | |
Rep 711
02-08-2024, 04:41 PM | #192 | |
Rep 4,174
In my post above, I compared the logs of the car in Sport Plus where it makes more boost, but less timing and it records slightly more power. Here is the STD corrected graph:
Mods: Yes.
02-08-2024, 07:53 PM | #193 | |
Please tell Me more >/dev/null
13
Rep 43
02-09-2024, 06:07 PM | #194 | |
Rep 249
My point is when the car is tuned up close to max. It's safer to back up timing a bit and add more boost. When you know it's too much boost, the car goes to limp mode. When you know there is too much timing, it'd be too late |
F87source7313.50 |
02-11-2024, 01:26 PM | #195 |
Rep 878
Drives: OG M2
M2guru Do you know what's up with these screws for the oil and coolant inlet/outlet lines? So there are supposed to be 6 of them. And from my understanding, all 6 of them are the same part number 07129904588. But for some reason, I have some screws that are longer than others and I'm not sure why. It looks like the longer ones will fit into the block and screw all the way in but they won't fit into the turbo side screw holes (they are too long to properly hold in the lines). Any idea why this is and which screws are supposed to go where? Also, is that 588 the same part number you used for your screws?
02-11-2024, 01:55 PM | #196 | |
Rep 587
A couple things that I can remember: 1) I also think mine were not the same length, but pretty sure they were the same width and thread pitch (I cannot remember which went where, but it looks like it shouldn't matter - even though you are finding out that it might) and 2) when securing them to the block (and maybe the turbo), the flange doesn't fit flush with the block, but it was in as far as it could go. This threw me off for a while until I verified with someone else's photos. I hope that helps. Wish I could remember more precisely for you. |
samsamdar605.00 |
02-11-2024, 02:05 PM | #197 | |
Rep 878
Drives: OG M2
02-12-2024, 11:31 AM | #198 |
Rep 261
This should clear the confusion.
But there’s one with two lines together, that would require a longer bolt.
Speedtech top mount G35|Motive| Reflex plus | Wagner EVO 3 | BMP manifold | Dorch Stage 2 HPFP | PI | Precision Racework stage 4V2 LPFP | BendCalibration Flex Fuel Kit |turner catch can| HRE 20” \Apex 18” wheels| ECUTEK tuned by bendCalibration|ohlins suspension
IG Modded_M2 |
