04-08-2022, 06:39 PM | #111 |
Rep 763
Got it sorted, the millway setup requires transferring the stock bushing from the top hat. It was cracked causing the spring to bind and unload. Didn't realize how negatively it impacted the ride quality. It has been sorted now and ride significantly smoother. Initial impressions on this setup are great.
View post on imgur.com |
4
04-19-2022, 01:18 PM | #112 | |
Rep 76
Do you have Millway Street or Race plates? Do you have thrust sheets for the springs? Still not sure if mine is the Ohlins damper bushing (BMS MR40) and/or the camber plates. |
04-19-2022, 03:55 PM | #113 |
Rep 344
I've been sitting on this for a while and forgotten about it. When I had the issue with the front struts, my shop worked to help eliminate the camber plates and spring tension to verify it was the damper making the noise. I sent this video to Öhlins USA at the time to help them understand the sound and when it happens.
https://youtube.com/shorts/gC7ocRRxiU0 When you watch the video, notice that the car is barely moving at all. The noise is caused by any small movement/load to the struts. I won't say that a loose top-nut would never sound like that/wouldn't make noise at that small level of movement, but in my limited experience, it's a different sound and requires a little more force. |
06-10-2022, 04:47 PM | #114 |
Rep 76
I added Torrington bearing sheets to the front springs and it got rid of the "clunk" at low speed steering which was just the coil spring binding.
Glad it wasn't anything with the dampers. |
06-11-2022, 08:14 AM | #115 |
Rep 309
Drives: 2018 M2 LBB - 6MT
Forgot to update. Got the front struts back on with Vorshlag plates and the noise is now gone.
10-22-2022, 02:42 AM | #116 | |
Rep 126
The ohlins are about 6 months on my car now and got this issue from the start. I find this very frustrating for this expensive mod.
@Rub1con76
chris7197365.00 |
10-23-2022, 01:52 AM | #117 |
Food Critic
1086
Rep 1,015
I rebuilt my Ohlins and all my noise related to this went away.
10-24-2022, 09:59 AM | #118 | |
Rep 126
@Rub1con76
10-25-2022, 12:49 AM | #119 |
Food Critic
1086
Rep 1,015
New shim stack, revalved for higher spring rate, new fluids, new seals, dynoed.
11-04-2022, 01:15 AM | #121 | |
Food Critic
1086
Rep 1,015
Also, my car did two ocean crossings in that time plus daily use of about 45k kms. ALL coilovers need a rebuild at some point, and it was the time for mine. Rear was becoming quite unpredictable on track, after the change it's so incredibly planted it's like a different car.
11-04-2022, 02:14 AM | #122 |
Rep 126
Because the knocking is not always there, its very hard to tackle the problem.
It seems that it occurs only when i steer left side up or down a driveway or so. My installer thinks its a wheel bearing
@Rub1con76
01-17-2023, 01:17 PM | #123 |
Rep 156
Well I just want to add that I had ticking and binding noises from the front left strut for some time and it would disappear and come back, we dismantled the camber plates and cheacked them and everything looked ok but the sounds kept on, then last week I decided to change my springs from 90 to 120 to suit my track use better and I noticed two things. first lots of small stones had bedded them selfs in between the first and second spring coil, secondly I decided to completely remove the damper from the front axle and what I could observe was small stones and debris where getting between the gold mounting cup and the hub carrier. After cleaning it all up all sounds, ticking, clicking and binding are gone 🙌
03-22-2023, 07:23 AM | #125 |
Rep 126
Months further now and stil no cure.
At first it looked like i had to drive a while before the sound shows up. Now it looks like that the time is shorter now. On FB was another discussion and they pinned a few options the knocking sound can produce
@Rub1con76
03-23-2023, 07:26 PM | #126 |
3886
Rep 54,510
Drives: F80 M3
Use chassis ears to pin point the source of noise.
Inner and outer tie-rod noise should be fairly straight forward to pinpoint. Not typically a noise that would come and go. Same with ball joint noises. You could also reinstall the OE suspension or just the top mount to eliminate noise from the Ohlins or camber plates. |
Rub1con76202.50 |
03-24-2023, 11:32 AM | #127 |
Rep 87
Took me a few attempts to get this setup right. (Ohlins road and track + millway race camber plates) 1. Make sure you have the correct orientation of the struts. The M2 requires left/right struts to be swapped compared to an M3/M4. You will also need the adapter kit. Photos attached.
Ohlins RT/SPL/Millway
Paragon/Pagid BMC/Active EL/Remus Race BBS e88/513m IG: @aatlas_M2C |
07-25-2023, 10:05 AM | #128 | |
Rep 42
What spring rate are you guys running? I have the recommended springs front 90 and rear 190, but its quite stiff on back roads so been advised to drop the rear springs to 160. Cheers. |
07-26-2023, 11:36 PM | #129 | |
Rep 380
https://f87.bimmerpost.com/forums/sh...8#post30344538 The springs I'm running are 80 N/mm in front and 160 N/mm in the rear and I'm very happy with the ride quality. My friend with the standard 90 & 190 springs says my car rides way better than his. |
07-27-2023, 04:21 AM | #130 | |
Rep 555
07-27-2023, 05:15 AM | #131 | |
Rep 42
Maybe changing the springs is the way to go. |
07-27-2023, 10:16 PM | #132 | |
Rep 380
