01-27-2022, 05:40 PM | #1 |
Rep 2
Possible coolant leak from oil filter housing?
Hey guys,
I popped my hood open yesterday and found dried coolant all over my alternator and oil filter housing. Seems like the oil filter housing/thermostat housing is leaking coolant? Trying to get some feedback before I open it up and replace the gasket inside. This is my first BMW so I am trying to get some opinions before I start taking things apart trying to fix this leak. |
01-27-2022, 06:57 PM | #2 |
Rep 196
That is one of the "will happen" failures that the n55 almost always experiences during its lifespan. I did mine at 50k because I started having oil gunk collect around the bottom plate from it.
You will need the gaskets, enough coolant for a full flush, and an oil change kit. Oil and coolant flow through the housing. The gaskets are cheap on FCP euro and they even have a guide on how to replace it yourself. It's not difficult, but the intake manifold is a PITA because you have to loosen the whole thing to get to bolts on the back of the OFH assembly. If you are planning on ever upgrading your HPFP to use more aggressive tunes and or ethanol, you will save yourself a lot of time and headache with the manifold by doing them together. Both jobs need the manifold to be moved (HPFP = off completely) so may as well do them together if the HPFP is going to happen anyway. Best of luck. Make sure you properly bleed the coolant system by having the car go through its process (also look that up, really easy)
14' Alpine White M235i 6MT, BM3 Stg2+, VRSF DP-CP-FMIC, Dinan Muffler, GFB DV+, 3.5 bar MAP, Dorch Stg1 HPFP, NGK 97506, BM3 Flexfuel Kit, CDV delete, KW V3, EDC delete, Powerflex Camber LCA bushings, VMR 801 18x8.5/9.5 et45, Conti Extremecontact 235/265
Next step: M2 Competition or Manual Supra MKV build Summer 2022 |
chris7197334.00 |
01-27-2022, 10:29 PM | #4 |
Rep 7,431
Make sure you prime your oil system if you do gasket replacements on the oil filter housing otherwise you risk rod bearing failure or seizure.
chris7197334.00 |
01-29-2022, 11:56 PM | #6 |
Rep 5,372
Perhaps I'm missing something, but I don't see any liquid anywhere in those photos. If you're talking in about the white residue on those aluminum parts, it's surface corrosion and nothing to worry about.
01-30-2022, 12:04 AM | #7 | |
Rep 7,431
You can also try to scape at the white marks, if it goes away it could be coolant residue, if it doesn't it is surface corrosion.
01-30-2022, 02:55 PM | #8 |
Rep 6
01-30-2022, 05:31 PM | #10 |
Rep 7,431
Xuv said it not me, you can pressure test the coolant loop with a cheap pressure tester to be sure.
01-30-2022, 09:01 PM | #11 |
Rep 2
I checked with a local shop as well and they seem to also think its surface corrosion on the aluminum parts. My coolant level is still at the full line and there doesn't seem to be coolant build up around the cap or any plastic parts. I will probably do a coolant pressure test to double check. My mileage is at about 52,500. I appreciate the input from everyone though.
01-30-2022, 09:35 PM | #12 | |
Rep 7,431
01-30-2022, 10:35 PM | #13 |
Rep 5,372
I think it would be rather odd to only have coolant on aluminum parts and nothing else. Coolant attracts dirt thus the surrounding plastics and other parts should also be covered in coolant. Lastly, about the only thing on the top of an N55 motor that's going to cause a coolant leak is the overflow hose to the overflow tank. And when those go, a large amount of coolant is puked.
01-30-2022, 10:41 PM | #14 | |
Rep 7,431
01-31-2022, 12:41 AM | #15 | |
Rep 929
01-31-2022, 12:56 AM | #16 | |
Rep 7,431
You don't need to prime your oiling loop for oil changes, and you don't really need to fill the oil filter housing with oil after oil filter changes either. You can, but I doubt it would do much to skip this step. But you should be careful because if you over fill and oil gets on your belt then you pretty much have to replace that belt, so it is a risky thing to do, especially since the oil drains out immediately as you fill it (due to the drainage hole bmw implemented which is normally plugged up by the oil filter lid, and if that is not in place oil drains out I explained this in depth in my malo industries oil filter cap review if you want to know more).
4
01-31-2022, 07:42 AM | #17 | |
The Seeker
13863
Rep 3,325
My recently acquired car has just under 20,000 miles and is dry, but I'm keeping an eye on it. I had no idea of the catastrophic failure that could result from the common leak. I considered getting a Kies guard, but with how particular I am I think I'll just keep an eye on it. |
01-31-2022, 11:43 AM | #18 | |
Rep 5,372
With the exception of the $40 coolant return line which should be replaced at least every 5 years/50K miles on these cars, coolant leaks on N55s are extremely rare. I've never heard of the OFH assembly leaking coolant either. Oil is what leaks out due to the location of the oil galleys to the leading gasket edges.
F87source7253.50 |
01-31-2022, 04:01 PM | #19 | |
Rep 7,431
20k miles isn't that old, you have alot longer before any issues were to arise. So take it easy no need to panic. BTW I recomend the MALO crank seal guard over the kies plate, that's my personal preference and I talk about why on my review if you wanted to know my thinking process. But either way you probably should get a guard, they're pretty cheap insurance imo.
///MPhatic13862.50 |
01-31-2022, 04:08 PM | #20 | |
The Seeker
13863
Rep 3,325
F87source7253.50 |
01-31-2022, 04:11 PM | #21 | |
Rep 7,431
It is always hard to diagnose issues on the internet with only partial bits of information.
02-01-2022, 02:54 PM | #22 | |
Rep 6
After priming is finished, do you trust the oil level measurement in the display or do you empty the system and refilling the correct amount? I more or less only drive on track and have experienced when the measurement shows correct level I have filled in couple of dl, and the measurement will still show the same level. |
