03-22-2021, 12:18 PM | #1 |
Rep 26
TPMS temperature reporting precision/accuracy?
Has anyone taken an opportunity to compare the TPMS reported tire temp to the actual tire temp? I've read several threads stating the pressure readings deviate around 5-10% (usually low) and I'm curious if the report temp shares a similar deviation. I'm also curious if anyone knows what the TPMS reporting interval is?
2020 M2C
Be healthy. Be nice. Do interesting things. |
03-22-2021, 12:28 PM | #2 |
Rep 6,937
Drives: 2018 M2 AW DCT
My TPMS readings are 1-2 psi low as compares to my digital gage. From what I understand this is normal.
03-23-2021, 10:02 PM | #4 |
Rep 26
Thanks for the responses. I did some tests today and the IR thermometer confirms that surface tread temp is about 15 degrees F hotter than TPMS reported values. That 15 degree temp differential is pretty consistent at all four corners. I'll do a few more tests but it seems that the data is enough to get a generally accurate picture of what the tires are telling you.
Curiously, My RF tire is consistently about 5-7 degrees warmer than the LF and RR tires. The LR tire is a couple of degrees warmer than the other two as well. TPMS reports as much and the IR thermometer confirmed it. This is generally on flat interstate. Can anyone else chime in with some average tire temperatures? I'm specifically curious about the difference between different corners of the car and which corners are usually warmer or cooler. Thanks again!
2020 M2C
03-23-2021, 11:00 PM | #5 |
Rep 4,672
Around town today.
I adjust my tire pressure for cold weather. Now that it's warming up I'll pull 2psi from each tire to target 38psi for normal diving. I found the TPMS to not be linear I it's report of temp. Its not uncommon to see 20 to 25psi difference. 30 is that max I've seen. This was in colder weather. The response might be better when ambient isn't 35F Last edited by medphysdave; 03-23-2021 at 11:08 PM.. |
Noh Wan24.00 |
03-24-2021, 07:51 AM | #6 | |
Rep 151
Noh Wan24.00 |
03-24-2021, 09:11 AM | #7 |
Rep 230
Guys, understand the factory recommended tire pressure is 35psi. Does this mean 35psi when at operating temps (say 80 degree tire temp) or cold? Trying to gauge the right pressure when I'm inflating tires before heading out for a drive.
03-24-2021, 09:29 AM | #8 | |
Rep 6,937
03-24-2021, 03:53 PM | #10 |
Rep 8,970
Relax, TPMS idrive display is just a fun gauge not some scientific instrument!
It measures tyre air temperature not tyre carcass temperature. The carcass temp will always be higher because its the heat from the carcass that in turn heats the air inside the tyre. Puncture detection works on relative changes so the absolute pressure accuracy is not important for that purpose... |
03-24-2021, 05:41 PM | #12 | ||
Rep 26
...and it potentially adds knowledge to the community... even if that knowledge is that the tire temp readout is garbage. So what are your tire temps? Measured vs reported. Thanks again everyone!
2020 M2C
03-25-2021, 03:17 AM | #13 | |
Rep 8,970
If you use it as a reference value rather than absolute it is more useful I feel. Eg, last lap it was 35deg, this lap its 38deg, the actual temp doesn't matter whether it's tyre air temp or wheel temp or tyre carcass temp, but rather how it's changed that matters. (if that makes sense?) My front curbside is always 2deg higher than the rest, even when cold and as they get warm is gets 3 or 4 deg higher, so I just put that down to measurement error and that's ok as I know that and can spot if it varies from that difference. |
