02-20-2021, 08:15 PM | #1 |
Rep 44
Should I get my FE module replaced?
My 2019 m2c is still under warranty. It has a few things coded with bimmercode; Mirrors fold on lock, disable asd, and disabled rev matching.
I brought my car in for the free oil change and service and they noticed a fault code with the FE module, which is the module that controls the features that were switched. They first got tripped up by the change in engine start procedure when you disable rev matching. There were no check engine lights that came on, apparently this fault code is something else that shows up on their diag tools. They've ordered a new one and requested they replace it at no cost. It'll obviously overwrite the features to stock but I'm wondering should I bother getting the new module or not? Last edited by rjpiston; 02-22-2021 at 12:31 PM.. |
02-20-2021, 08:31 PM | #2 |
Rep 6,940
Drives: 2018 M2 AW DCT
If you can code your car, there is no downside to getting the module replaced.
02-21-2021, 12:35 PM | #3 |
498
Rep 697
Drives: Alpine White 2020 BMW M2C
Garage List 2017 BMW X6 M [0.00]
2020 BMW M2 Competi ... [0.00] 1993 Mazda RX-7 [0.00] 2006 Mitsubishi Evo ... [0.00] 2005 BMW M3 ZCP [0.00] 2016 Ducati Panigal ... [0.00] |
Brandt51889.00 |
02-21-2021, 06:23 PM | #4 |
Rep 380
What are your thoughts about dealership service?
02-22-2021, 12:05 AM | #6 |
498
Rep 697
Man.. So many horrible experiences.
At.Every.Single.Dealership. Every.Single.Time. Without.Fail. They are all the same. Smiles, handshakes, and reassurance from the service advisor. But the same fucking cunt kid takes the keys after you walk out of the room. I could rant for days about my horrible experiences, but neither of us have time for that... Just last month I took my E46 in for a simple battery swap, I tell them it's due for rod bearings and that its not to be driven anywhere except to and from the bay... I get it back with 10 more miles on the clock. They hit another car with it. they tried to wash / buff the white paint off of my fucking blue car so I wouldn't notice. Then denied everything. Brilliant. Fuck every last one of them. So yeah... I have strong feelings about dealership service. |
02-22-2021, 12:06 AM | #7 |
498
Rep 697
Brandt51889.00 |
02-22-2021, 01:10 AM | #8 | |
Rep 44
That's not my car anymore. That's your car now!!! |
02-22-2021, 08:11 AM | #9 |
Rep 1,358
You're going to have them replace a module which you know is fine and only showing a fault code because you changed some parameters. I couldn't in good conscious do that.
In addition to being a waste of time, money and resources there is always the chance something else will happen as a result. |
02-22-2021, 09:03 AM | #10 |
Rep 44
They kept insisting to change the fe module. I asked if I could get the codes switched back to stock could they test the module for the fault code again but they said they couldn't do that. They have to replace it or don't replace it and if anything goes wrong I won't be covered under warranty.
02-22-2021, 09:12 AM | #11 | |
Luxury at the redline :)
9105
Rep 7,563
The dealer really doesn't need to replace the FEM, just uploaded the latest firmware and the vehicle will programming will revert back to the factory beginnings, prior to the coding. But it's there time and resources, so I'll let them figure it out for themselves.. |
cptobvious2531.50 |
02-22-2021, 09:50 AM | #12 | |
Rep 504
02-22-2021, 11:42 AM | #13 | |
Rep 44
Trust me, I tried to get them to not replace it and check it after i get the codes reverted but they refused. they even mentioned that it could put a mark on my vin if I needed any additional warranty work. |
02-22-2021, 12:19 PM | #14 | ||
9105
Rep 7,563
This is the result from simple of faulty check values from what the coded, they simple need to reprogram the entire vehicle and I'm positive that all the errors will clear. I've messed around with disabling the auto rev-matching before and experienced similar symptoms to what you are encountering. If the FEM was bad, most of the vehicle major functions would not work, like the windows or all of the front lighting. I can't believe I can armchair diagnose this issue, while sitting in traffic and dealer just keeping spinning their wheels, by replacing everything under the hood. But whatever, if it's free, let them do their thing and pad the bill and just you go do donuts in their loaner car.. |
02-23-2021, 03:36 PM | #15 |
Rep 8,970
Dealers get paid by BMW to fix stuff if they follow diagnostic processes.
The dealer doesn't give a shit about your car or common sense or actually fixing it, just getting paid, several times if possible, that's all. Your coding has disabled clutch sensor reading, if they recoded the car it would fix it, but they don't get paid for that because that is not on the ISTA diagnostic path. |
cptobvious2531.50 |
02-23-2021, 04:10 PM | #16 | |
Rep 44
Brandt51889.00 |
02-23-2021, 08:12 PM | #17 |
Flavor of the month
889
Rep 716
Drives: BMW F87 M2C
So the lesson for Bimmer Code stuff is to revert it all back to stock for service, then re-code back to your preferences?
Does that sound legit? I haven't done any Bimmer code stuff, so I don't know if it's a pain in the ass. Swapping tunes through OBDII on diesel trucks takes 15+ minutes, but it's pretty cut and dry. And still annoys me. Bimmer stuff that easy and fast?
Samuel of the Internet
2023 F98 X4M Comp 2023 F95 X5M Comp 2020 F87 M2 Comp |
02-24-2021, 12:40 PM | #18 | |
9105
Rep 7,563
iCloud saves all Bimmercode backups, onto their server, even if you swap phones. I've changed phones like 10 times last year alone and all my backups, with their said time-stamps, are all there and I can revert back to any changes I need to, from day one of using Bimmercode. And yes, I've done a lot of mods for my friends and myself and by a country mile, opting for the Bimmercode APP is the best $27 I ever spent; they really did earn their keeps in value. I'm not sure why the OP didn't just upload the original backup but you know, it's the internet, so I expect that I probably wouldn't get the full story. I'm just putting the pieces together with whatever is available. |
02-26-2021, 09:16 AM | #19 |
Rep 44
In hindsight I should have been more aware and reverted the codes to stock. That's definitely on me. From what I've read from other people who have coded their cars it wasn't a problem bringing it to the dealer. And i had no idea of any fault codes since the check engine light never came on. Lesson learned and I get a free module out of it, albeit reluctantly.
02-26-2021, 09:40 AM | #20 |
Rep 8,970
There's 1000's of fault codes that will come up without a CEL / MIL. Only the important things that YOU, the driver, need to know about so you take it in will give a CEL.
You need to check and reset fault logs every time before taking to the dealers if you are coding / mapping. The fault logs will still be there anyway even if you revert the coding, and others from the past, unless you have diganostics tools to reset them. A few coding changes can leave dozens of fault logged which if the dealer is fussy they won't like and could bust warranty if its related to a faulty part. |
02-26-2021, 11:20 AM | #21 | |
Rep 3,842
02-26-2021, 11:35 AM | #22 | |
Rep 4,048
