M2 Technical Topics > Suspension | Brakes | Chassis > M Performance Coilvers, worth it???
      05-16-2020, 05:19 PM   #155
PLF69
PLF69's Avatar
3768
Drives: 2023 M3
The M Performance kit is well sorted out and you have the OEM attention to detail, they take time to make sure it's ok with there nvh tolerance.
I ordered my Ohlins with lower springs rates for more compliance only to discover that if I want to benefit 100% from my rates I will have to revalve my shocks. Ohlins uses the same shock valving throughout many applications. So I have the same as an M4 with 230nm springs, I run 140nm.
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp
Daily: 2023 X5 45e
Daily/Family: 2021 Atlas Cross Sport 3.6
      05-16-2020, 05:30 PM   #156
mchoy
Drives: LBB LCI M2
Is the ride essentially the same as stock at recommended settings? My hope is it can be made slightly more compliant with different settings. Totally get these are for increased performance but wondering if there is anything conclusive on improved ride quality which would be a bonus for me.
      05-16-2020, 05:37 PM   #157
AZ-Wildcat
AZ-Wildcat's Avatar
620
Drives: BMW HS M2C DCT
What does everyone have theirs set at for street driving? Getting mine installed Tuesday. TIA
      05-16-2020, 06:13 PM   #158
PLF69
PLF69's Avatar
3768
Drives: 2023 M3
When I test drove an M-tour M2 equipped with M performance Coilovers and 763m wheels I found the ride more compliant than my stock M2.
It was stiffer but more controlled and less crashy/bouncy
Daily: 2023 X5 45e
      05-16-2020, 07:31 PM   #159
mchoy
Drives: LBB LCI M2
Thanks! City roads are tough for any suspension but any bit of improvement helps.
      05-17-2020, 07:59 AM   #160
M Fifty
844
Drives: M2 & 330CI
Go with the BMW recommended ride heights and geometry.
I run 2 clicks softer on both ends for rebound and compression than the recommended street setting. But that's personal preference.
      05-19-2020, 09:06 PM   #161
AZ-Wildcat
AZ-Wildcat's Avatar
620
Double post from the general M2C section, but wanted to share on this thread as its relevant:
Before and after pics - Mperf coils installed. Then rear is maxed low, and isn't that much lower than stock. Guess we will see how this settles. I checked as many threads as I could and it's sitting to spec. Front is 595mm, 600mm rear from bottom of rim to top of wheel arc. Any thoughts for those who are in the know. Handling is outstanding as other have said without sacrificing the ride.
      05-19-2020, 10:00 PM   #162
flybigjet
Remove Before Flight
flybigjet's Avatar
Drives: M2C & Boeing's light twin
Before and after pics - Mperf coils installed. Then rear is maxed low, and isn't that much lower than stock. Guess we will see how this settles. I checked as many threads as I could and it's sitting to spec. Front is 595mm, 600mm rear from bottom of rim to top of wheel arc. Any thoughts for those who are in the know. Handling is outstanding as other have said with sacrificing the ride.
Did you mean "WITHOUT" sacrificing the ride?
      05-19-2020, 11:25 PM   #163
AZ-Wildcat
AZ-Wildcat's Avatar
620
Edited. Cheers!
      05-20-2020, 02:58 AM   #164
krizze
Czech_Republic
928
Drives: 718 GT4 -Skoda Octavia VRS
Originally Posted by M Fifty View Post
Originally Posted by krizze View Post
Both, expensive and you can't adjust them, just awful especially how hard the ride is.
You can adjust them - both bump and rebound - as well as the ride height. Or was that not what you were referring to?
Also, as they are KW V3 in a different colour, it's always possible to try different spring rates.
Separately. The price is about the same as KW V3, and hence, quite a bit cheaper than many (but not all) alternatives. At least, in many markets. Not where you are maybe?
@ex12psi said it in a previous thread,
" I should preference... I have the m perf coils and they are sorta lame. The spring diameter is so retarded big in the front that the required neg camber for track duty is unachievable because the damn spring hits the inside of the wheel well, stupid.
The ride height setting sucks. Running 18" track wheels, trust me you want to go lower but you can't unless you forego the rear spring adjuster perch then, wtf is the point?".
I too tried both the adjustability with the M Performance is very limited because BMW don't want you going too low so they can't get into trouble if you break something where as KWV3 you can do a lot more. Hence my point expensive and not very good. It's good if you want to keep warranty but that's about it for me.
      05-20-2020, 04:59 AM   #165
VIERsr
Switzerland
2623
Maybe you missed the point.
It's a compromise option for road and occasional track use and does a great job for what it's been designed for, but if you look for something focused for a track use there are other and better options. And more expensive of course
KW put the v1/2/3/4 under the Street Performance category, for double the price you can get the Clubsport and you won't be disappointed.
      05-20-2020, 02:26 PM   #166
Big Fabri
Big Fabri's Avatar
Italy
95
Drives: Lamborghini Huracan
mperformance is very good for the track. it depends on the settings.if you want to be serius about track there is the gr00 made by Ohlins and it's 10 gs. it's a full coilover back and front
      05-22-2020, 09:53 PM   #167
csbear
csbear's Avatar
1118
Drives: SO M2C
I'm sure it's posted somewhere, but I am thinking to get the M Perf coilovers. Anybody running spacers with stock wheels (788m) with the coilovers?
I might go 10 mm spacers all around, but don't mind something more aggressive as well.
      05-24-2020, 09:18 AM   #168
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
What's the best price you all are paying now a days? Cheapest I found is $2197 with required hardware.
Also on stock 788 wheels but went 255/275 route, anyone running this setup have any issues with rubbing?
      05-24-2020, 09:44 AM   #169
PLF69
PLF69's Avatar
3768
Drives: 2023 M3
my friend is running M perf suspension with 15mm spacer all around, 437m wheels and 245/265 PS4s and all is fine
Daily: 2023 X5 45e
csbear1118.00
      05-24-2020, 10:39 AM   #170
AZ-Wildcat
AZ-Wildcat's Avatar
620
Price, yup. Wish I pulled the trigger from Sun Motors months back, I think it was closer to $1900 or something. Oh well
255/275/35. Absolutely. That's what I'm moving to after these stock ones wear out. I was chatting with another member on here runs that set up w/ 5mm all around, no issues. Check out his insta: am319_m2c
m20e30871150.00
      05-24-2020, 10:54 AM   #171
Montaver
Montaver's Avatar
Drives: G87 M2 & M340i LCI
Given the memorial day sales, you can pickup Ohlins for around $2900. Personally I would stump up the extra to get the Ohlins as they are superior dampers overall.
      05-24-2020, 12:17 PM   #172
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
Has anyone done a DYI for our M2's. There are DIYs for f80 and f82, ours should be easier since we don't have any wires connection to the struts.
      05-25-2020, 09:22 PM   #173
2020M2Competition
2020M2Competition's Avatar
429
Drives: Yes
This is a pretty good one
https://f87.bimmerpost.com/forums/sh...hlight=install
For the M2C you will also need to take into account the additional bracing in the engine compartment
In any case, I always like to consult with this
https://www.newtis.info/tisv2/a/en/f...mpetition-cou/
m20e30871150.00
      05-29-2020, 10:25 AM   #174
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
So called my local BMW and was quoted $1050 plus $189 alignment for labor plus tax to install the MP kit. I am going to the DIY route and taking it in for the alignment. Wasn't expecting it to be this many hours for labor the kit.
      05-29-2020, 02:18 PM   #175
AZ-Wildcat
AZ-Wildcat's Avatar
620
That's high. Should be closer to $650
      05-29-2020, 10:58 PM   #176
johnnyace
Drives: M2C
Anyone running this size with MP coilovers at stock drop with no spacers or camber plates?
