04-10-2021, 12:07 AM | #463 |
Rep 658
04-10-2021, 01:40 AM | #464 |
Rep 4,516
yes
Current '22 X3M LCI.. |
04-12-2021, 02:36 PM | #467 |
381
Rep 731
I believe its 595mm Front, 600mm Rear, from the bottom wheel lip to top of Fender arch.
At a Point above 7,000 RPM.
04-14-2021, 10:41 AM | #469 |
Rep 658
Here is my experience.
MP coilovers vs M2CS adaptive suspension: https://f87.bimmerpost.com/forums/sh...0#post27471550 Post 21 + post 23 A strong recommendation to those, who are about to choose the suspension: Please very carefully choose what you read on this forum as well as on other forums. I highly recommend checking also other post of those forum members, who give their advice. Some of them might be just die-hard fans of a specific car brand and their advice has very little in common with the real world experience. Some may also be buying their first sports car of certain price niche and for them everything will look just perfect. Probably the best advice you will find from those, who own several different sports cars of different car brands as they tend to be the most objective. So carefully choose what you read. Last edited by kart driver; 04-14-2021 at 11:01 AM.. |
05-08-2021, 04:20 PM | #471 |
Rep 52
05-08-2021, 04:49 PM | #472 | |
Rep 658
Here is what I found
05-09-2021, 03:53 AM | #473 |
844
Rep 1,962
The MPS uses different colour adjusters, there are additional spring seat components, different springs and the design of the rear spring on the MPS is one-piece while that on the KW V3 is two piece.
What - if anything - has been changed internally is open for debate. https://f87.bimmerpost.com/forums/sh....php?t=1590553 |
05-09-2021, 05:29 PM | #474 | |
Not great. Not terrible
7445
Rep 2,700
The other poster mentioned bushings, I think it could be that.
Current: 2024 BMW X3 M40i.
05-10-2021, 03:03 AM | #476 | |
Rep 566
JustinHEMI7445.00 |
05-10-2021, 06:26 AM | #477 | |
7445
Rep 2,700
05-10-2021, 09:52 AM | #478 |
Rep 31
I have M performance suspension on M2C with front milway camber plate street (front camber -2,4 and rear camber -1,5)...
On very bad condition roads with big bumps, sometimes i got "klonk" sound from front dampers... it was on BMW recommend settings (front bump -6 and rebound -9, rear bump -6 and rebound -12).. So i change front dampers on bump -10 and rebound -12 and its like OEM suspension... for track session i will harder front dampers again on recommend bmw settings Last edited by oranzada_m2c; 05-11-2021 at 03:03 AM.. |
05-11-2021, 05:33 AM | #479 | |
Rep 76
Honestly I'm not that impressed with the M perf coilover, they are quite harsh on the road but too soft on track. I'll be looking to swap to some ohlins R&T in the future |
goforwand68.00 |
05-11-2021, 04:56 PM | #480 | |
Rep 31
I am happy on track i always settings hard settings on front suspension - 9 rebound and -4 bump... |
05-11-2021, 11:04 PM | #481 |
Rep 839
6K miles on my 2020 M2C with MPERFORMANCE Suspension. Everything set to BMW recommended specs. O issues so far- my shop took there time to get everything dialed- in. You can have issues if the dealer or who ever installed them did not take time to install them to BMW recommended.
05-15-2021, 10:35 AM | #484 | |
Rep 1,262
Drives: BMW 1M
I swapped mine out for Nitron's and they work perfect with zero squeaks/clonks or knocks at what ever settings I choose. |
goforwand68.00 |
