M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Vrsf 5" intercooler upgrade
      11-16-2019, 07:32 AM   #1
akahn221
akahn221's Avatar
Drives: 2018 BMW M550i
Hey guys, this is my first post due to the fact that I finally cannot find an answer to one of my questions. Accidentally posted in S55 section as well.
About a month ago I installed VRSF 5" stepped intercooler and their catless downpipe on my MY17 LBB M2.
Had a big boost leak at first but fixed it by getting the clamps on correctly. These days my check engine light is coming on and reading code P120D and I have a feeling it has something to do with a boost leak because I do not have an aftermarket air intake just the K&N air filter.
Now my question is, when you folks were Installing a VRSF intercooler did you use any couplers or O rings? I still feel like I'm leaking in the higher rpms. I just can't figure out what exactly it could be. Wanted to ask around first before I spend money on a smoke test that probably won't do me much.
Let me know what you folks have done if you have been in this situation!
I am MHD stage 2+
Thank you!
      11-16-2019, 09:58 AM   #2
chief1richard
chief1richard's Avatar
2018 M2  [0.00]
Will be installing my intercooler when it arrives. If I recall from some of the videos on how to do this, there is a rubber O ring on the intercooler end, and one going to Air Mass on the Charge Pipe. Did you install an aftermarket Charge Pipe? The OEM is cheap plastic, and prone to leaks and cracking.
      11-17-2019, 01:09 PM   #3
akahn221
akahn221's Avatar
I am going to be checking those O rings today. I have not replaced the charge pipe, did not have any issues yet but I guess from hearing what people are saying I should get new ones soon. I'm originally from Swampscott! Bet the M2 is a blast up there. Good luck on your instal! Are you doing charge pipes as well?
      11-17-2019, 02:50 PM   #4
chief1richard
2018 M2  [0.00]
Yes. Am waiting for the Evolution Raceworks Charge Pipe along with my AA Intercooler. The Charge Pipe is a weak point and should be changed if you track or not. Any aftermarket Charge pipe would be better than stock. As far as being up here in Boston, its cold and has already snowed. Makes for a shorter track season.
      11-18-2019, 07:48 AM   #5
cecaa850
Just be sure you put some sort of lubricant on the O-rings so they don't roll and be sure the clip fully seats in the groove.
      11-18-2019, 07:55 PM   #6
akahn221
akahn221's Avatar
So yesterday when I went under I looked at the right side of the charge pipe and the O ring was in. On the left side though the O ring was just hanging outside of everything. Not sure how it didn't fly off. This was just an error on my part when I was installing. Also Good point with those clips, you really have to have the intercooler piping go all inside as far in as possible or the clips will not seat as tight as possible. I put the O ring in with some lube and made sure those clips were fully in there and the charge pipe was on all the way. We are now boost leak free and where I was noticing the power loss up high it now just pulls and pulls and pulls. Very happy. Thank you for your input.
JTO245274.50
      11-18-2019, 07:57 PM   #7
akahn221
akahn221's Avatar
I got it. It is very prone to cracking I hear. I will have to place an order on one. I heard you folks already got a little snow!! Crazy! It has fallen down into the 20s here in Austin already, reminded me of back home. Got used to the year round warmth living in California for a little bit. Good luck on your install! Will be very nice. Thank you.
      11-27-2019, 02:56 PM   #8
logan528i
Drives: BMW 528I
can you put on a FMIC straight to the stock charge pipe?
      11-27-2019, 06:33 PM   #9
cecaa850
Yes. Inlets and outlets are the same.
      11-29-2019, 02:15 PM   #10
mikeyymonster
mikeyymonster's Avatar
Drives: 2021 M2C
When you guys say "lube the o-rings" what do you use for lube?
2021 M2C
2014 M235i
Instagram: @mikeyymonster
      11-29-2019, 02:47 PM   #11
cecaa850
I used silicone paste but I'm sure motor oil would work just fine. Just needs a light film. WD-40 would probably work just as well also.
