10-02-2019, 06:48 PM | #23 |
Rep 177
You're still accepting the chance of your BMW warranty being voided, but Dinan agrees to warranty any repairs BMW refuses to cover after the flash.
10-02-2019, 06:52 PM | #24 |
Rep 3,124
A bit simplified but essentially yes. I would caution against going to ANY dealership though and would strongly encourage going to an authorized dealer instead. First thing a non-dealer will do ( especially true at a dealership) is flash back to stock and they will have no way of loading the software back on.
10-02-2019, 06:52 PM | #25 |
Rep 112
10-02-2019, 07:19 PM | #26 | |
Rep 177
IMO the Dinan warranty is to be used for the worst case scenario fixes. |
10-02-2019, 07:24 PM | #27 | |
Rep 112
My dealership used to carry Dinan before. Will talk to them later in the month to see if they still do |
10-02-2019, 09:53 PM | #28 |
Rep 1,360
I've been waiting for this for a long time!
I am concerned about if I go with the fully warrantied version and want to go more "extreme" after 4 years - is there a process to do that? Also, what if I added an aftermarket intake, or cats, etc, would that void the Dinan warranty? Last concern is that the tune will not be adjustable at all (meth, etc). Of course, you know that going in, but maybe that would be my plan. Dinan for 4 years, then switch to an aggressive BM3 type solution that opens up all the goodies. Sweet stuff though!
2021 ///M3
2019 X3 |
10-03-2019, 10:21 AM | #29 | |
Rep 3,124
Running parts outside of the Dinan formula will always introduce gray area in terms of the warranty just because it is not our responsibility to warrant products outside our own (or BMW's) nor can we guarantee results on products we did not test. As an example if a problem can be traced back to a DP we would not warrant the claim or if an open air intake is causing issues we would not warrant that either. |
10-03-2019, 12:53 PM | #30 | |
HALA MADRID!
937
Rep 2,877
But then again, I don't work in the Business side at Dinan, so I'm sure you guys did market analysis and figured out the potential value offering may not be cost effective to the average customer.
F87 M2 Competition, Sunset Orange, Exc, DCT. **SOLD** F80 M3 Mineral Grey/Sakir Orange, Exc, DCT... ED 6/2015 **SOLD**E90 M3, Interlagos Blue / M individual two-tone, ZCP, ZP2, ZCV, DCT, ED. |
10-03-2019, 02:27 PM | #31 |
Rep 3,285
Drives: 2002 M5;2007 M Coupe;2020 M2C
Does installing the Dinan heat exchanger mean the car will also take longer to warm up? I wait until the oil temp reaches the fully warmed up point (1/4 way up the gauge) before I do any semi-aggressive driving.
Thanks.
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
10-03-2019, 03:02 PM | #32 | |
Rep 3,124
Dinan + = Warrantied albeit neutered Stage 1 91 Octane file.The reason for this low output of power is without the heat exchanger to combat heat you are immediately running into heat soak issues at power levels above this. Dinan +HE = Warranted version of the full Stage 1 91 Octane file. Dinan Stage 1 - 91 = Same file as above just doesnt have the factory matching warranty. Dinan Stage 1 - 93 / 100 /104 / E85 - Just higher octane adjusted maps to take advantage of the better fuel but these wouldn't have the factory matching warranty. If the "problem" you are referring to is not having a warranted E85 map for full power that is simply because we have to be able to control all the variables in order to effectively manage warranty costs. If you have an engine seize because you are running the E85 map on 89 octane --- that shouldn't be our responsibility and we can't control that. Hence why the warrantied files are limited to the lowest common denominator (aka - safest). |
10-03-2019, 05:14 PM | #33 | |
Rep 8
10-03-2019, 08:23 PM | #34 |
dentite
339
Rep 758
Drives: 718 GT4, M2C, JLU392, e92 M3
Does the Dinan +HE tune come tuned to 93 octane? I see in the product options chart listed 91 or 93.
10-04-2019, 08:42 AM | #35 | |||
Rep 3,124
10-04-2019, 11:15 AM | #36 |
Rep 453
Is the heat exchanger on your website for the M2? In Houston all cooling mods would be appreciated ... I'm convinced this engine pulls a ton of timing over 90degrees F.
10-04-2019, 12:23 PM | #37 |
Rep 269
@Dinan_Engineering
If I obtained a warranty tune and your Dinan cooler, and no other bolts on, what does the warranty cover? Would the warranty cover a crank hub slip on your warranty tune and the only bolt on being your cooler? I have been told you all refuse to cover crank hub slips and tell customers to claim with BMW, the issue is BMW will not cover a crank hub slip with a tune.... Last question, would a crank hub upgrade (like maximum PsI) for the crank hub slip problem void Dinan warranty on the engine with a Diann tune. Also where can I find a list of authorized Dinan dealers in Southern California? Thanks. |
10-04-2019, 01:40 PM | #38 | ||
Rep 3,124
As far as the crank hub goes --- generally speaking it would be covered under the warranted file when run to spec however there are variables which may affect that. As an example, if the hub was spun as a result of a money shift and the logs tell us as much the claim would be denied, the same as BMW would deny it (regardless of it being tuned or not). In the same vein a 3rd party part doesn't necessarily void the Dinan warranty but we also do not warrant 3rd party products and their possible effects on other components. Dealer locator is on the website (https://www.dinancars.com/authorized-dealers/). Just put in your ZIP and it will output dealers nearby. |
10-04-2019, 02:41 PM | #39 | |
Rep 112
10-04-2019, 03:19 PM | #41 | ||
Rep 3,124
10-04-2019, 08:32 PM | #43 |
Rep 198
When you get to the top of a gear and accidentally downshift instead of upshifting. Top of second gear into first gear, for example.
10-04-2019, 08:59 PM | #44 |
Rep 7,594
Drives: '19 M2C
It's the mechanical Over-rev of the engine.
www.ReTuneTheDeTune.com
