09-16-2019, 10:47 AM | #1 |
Rep 764
What DP to match AA mid pipe?
Hey guys, I need some help and advice on what to purchase. Believe I've looked at just about every catless, catted and even resonated DP's for the M3/m4 which are the same as our M2 Comp. Currently she's on stage 2 BM3 93 map only mod's are removed carbon filters and AA mid-pipe. One the reason I went with the AA mid-pipe was to increase some lower sound as well as remove some rasp which it did and I like it a lot. really don't want to put the stock mid-pipe back on just to run catless dp's which would defeat the purpose of the AA mid-pipe. But its time I do DP's since I'm choking the stage 2 tune, it seems if I run catless its going to be to raspy for my liking, plus added smell which I don't want if possible. I'd like to get a catted but I'm concerned of of the once I've seen (ER / AR) cat's may not hold up well, I was told the ESS catted pipes are like 4-6 week lead time which is crazy :-( Thought about running resonated but not sure how much it will help remove the rasp with the AA mipes and if its worth the added cost or just go Catted at that point. Any advice is welcome.
09-16-2019, 01:27 PM | #2 |
Rep 845
Instagram: @Project_F87
10-02-2019, 07:10 PM | #4 |
24140
Rep 190,689
Congrats
10-02-2019, 07:28 PM | #5 |
Rep 1,408
10-02-2019, 07:36 PM | #6 |
Rep 1,408
You will love the DP with stage 2. I was ran stage one for about 5K miles, and recently switched to stage 2, its crazy fun. I was waiting for it to pass at least 12K miles before going stage 2. So added cat-less DP, BMC air filter, upgraded the charge pipes, and NKG plug at .020. Planing on doing the mid in the future.
10-03-2019, 05:38 AM | #7 | |
Rep 764
10-03-2019, 05:55 AM | #8 | ||
Rep 1,408
10-03-2019, 10:26 AM | #9 |
24140
Rep 190,689
I dont not think VRSF has a set date yet on a release. I recommend checking with them direct for an ETA
10-31-2019, 10:43 PM | #10 |
Sorry, I'm new
Rep 41
I have VRSF catless downpipes and a AA midpipe, it required cutting the OEM exhaust diffrently than what's instructed but it fits fine
Also used spacers on the O2 sensors and never had a CEL in 4k miles |
11-01-2019, 12:21 AM | #11 |
24140
Rep 190,689
If you are using the midpipe with stock exhaust, you need to cut the stock exhaust (its all one piece from downpipe to muffler). If you are installing the midpipe with another aftermarket exhaust, no cutting is needed.
11-02-2019, 07:12 AM | #12 |
Rep 819
Whoa - I thought a tune or JB4 was absolutely mandatory to avoid CELs.
You can just add spacers? This will avoid CELs using both catless DPs and midpipe together?
///M
11-02-2019, 09:35 AM | #13 | |
Rep 1,477
If you replace secondary cats (on mid pipe), you won't have any CEL. |
Daytona_550463.50 |
11-02-2019, 10:44 AM | #14 |
24140
Rep 190,689
Midpipe does not throw a code so no need for any tune or spacers
Daytona_550463.50 |
11-12-2019, 05:03 PM | #15 |
Rep 764
Update after catles dp's where installed.
Wanted to update this thread for those that may be runing a similar setup as myself (BM3 stage 2 OTS 93, catless dp's and AA mid pipe). Well needless to say after driving with this setup for a few weeks now I didn't like it for multiple reasons. Mostly the drivablity. I like the volume of the sound but not when it releasing boost at part throttle from high boost. What I mainly was frustrated with was the spoil up was so quick it was near impossible to control partial fast acceleration at take offs to the point it was scary being uncontrollable. So yesterday I decided to removed the AA mid pipe and installed the stock mid pipe back on since I've never run the car with just DP's. Aside from the sound not being farty/blatty when stopping high boost, its night and day difference in controllable usable power "torque" down starts. Feels like its even stronger down stairs which could be all in my head, regardless its smoother tip in which I need to enjoy driving. Also ran just one dragy to compare 60-130 as well as 1/4 mph and the times where almost the same which made me even happier. So to cap this off, imo there is no need to do mid pipes if you have dp's which everyone suggested already in this thread and they were correct. What I'm surprised with is I still have some strong smell from the exhaust, not as bad but its still there, assuming those main cats do a lot for removing smell. Thank you for all that have listened and suggested. Currently loving the M2 Comp so much more now. Who would have though that an exhaust would make that much of a different in spoil up and throttle control. My guess is the shape change has a lot to do with it.
