M2 Technical Topics > Track / Autocross / Dragstrip > 18x10 et40 fitment?
      04-01-2019, 08:16 PM   #1
monochrom3
Former P-Car Owner
Drives: 2018 M2 (TBD)
18x10 et40 fitment?
Anyone try a 18x10 et40 fitment? Friend has a set with slicks sitting around, so thinking of using them if they'll fit. I'm on stock suspension except eibach springs and GC plates -2 in front
Thanks in advance!
2018 BMW M2, Orange wrapped!, Journal
1999 BMW M3, Cosmos Black, S54 swapped
      04-01-2019, 10:05 PM   #2
boony1968
boony1968's Avatar
18
No issue for the rear of course. The fronts may have brake clearance issues depending on the wheels and you would likely need to run a spacer. I'm running 18X9 +29 with 275/35's and no rubbing - shock suspension.
http://rimsntires.com/specspro.jsp?i...9&text1=Sample
      04-02-2019, 06:56 AM   #3
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
18x10 et40 fitment?
It depends on the wheels. Not all 18" wheels will clear the M2 brake calipers.
Barring that, The rears should be fine, but you'll likely need large spacers in the front.
Motorcity BMWCCA Member
Instagram | YouTube
      04-02-2019, 07:28 AM   #4
monochrom3
Former P-Car Owner
Thanks for the replies. I'll let y'all know how they fit. I have a few sets of spacers ready.
Wheels are BBS BMW GT4's by the way:
http://alekshop.com/products/bbs_racing_wheels_bmw_gt4
      04-02-2019, 03:19 PM   #5
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Those may fit. I know a handful of people running 18" BBS wheels with no contact with the brakes. Not that specific model, but you'll find out I'm sure.
Good luck
Instagram | YouTube
      04-03-2019, 10:39 AM   #6
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
Fronts will need a spacer for sure, ideal offset in the front is around 27-30 for a 18x10
      04-17-2019, 07:31 AM   #7
mariusc
Norway
32
Drives: 2010 335i, 2009 M3, 2019 i3s
I bought a set of these BBS wheels. GT4 RE1243.
The wheels were used, and unfortunately one of them were slightly bent. Even if it just a small damage, the rim rubs the metal weights on the OEM rear brake pads. In other words, it is a very tight squeeze!
The wheels will however fit on the front axle, of course with spacers mounted. Not sure how wide spacers you will need.
