M2 Technical Topics > Track / Autocross / Dragstrip > Wheei studs
      11-06-2018, 09:33 PM   #1
chief1richard
chief1richard's Avatar
2018 M2  [0.00]
Wheei studs
Anyone using wheel studs for track or DD? Just bought a set and am deciding on using red Loktite or not. Have heard Pros and Cons.
      11-07-2018, 05:11 AM   #2
GasBurnlife(landapanda)
Yes on the locktite.
      11-07-2018, 09:24 AM   #3
pal
pal's Avatar
433
Drives: Z4 M Coupe
+1 on the Loctite
      11-07-2018, 09:53 AM   #4
dvas
dvas's Avatar
518
I used loctite on mine.
      11-07-2018, 10:41 AM   #5
twin fed
Doc Brown
twin fed's Avatar
1176
Drives: 2016 MG MT M2
I used Loctite on mine
      11-08-2018, 07:36 PM   #6
M2guru
2018 BMW M2  [10.00]
I used Loctite on mine. DD (this will be my first winter with them) and HPDE.
      11-09-2018, 03:58 PM   #7
Expert@ApexWheels
Expert@ApexWheels's Avatar
3510
Drives: M3
Loctite is definitely required for proper installation. Because the tightening torque of the studs to the hub is relatively low (around 27 ft-lbs), as well as the repeated forces involved in tightening and loosening lug nuts (often with air tools), thread locker is required to keep the studs in place.
      11-10-2018, 09:17 AM   #8
gsrbri
gsrbri's Avatar
Drives: F87 6MT
The only clarification I'd add is that I used blue Loctite vs Red. Red requires heat to remove.
The load on the studs is tensile and lateral, which isn't likely to rotate them out during driving.
After 100+ track days using this approach, I've never had a wheel stud back out
      11-10-2018, 10:04 AM   #9
M Fifty
844
Drives: M2 & 330CI
Interesting point on the heat - how hot does Red need to be before it softens?
      11-10-2018, 10:53 AM   #10
I used blue during three seasons tracking my bike and never had issues, but we also safety-wired most bolts. I would recommend checking with tour local race shop and read the instructions before deciding.
http://henkeladhesivesna.com/blog/th...threadlockers/
