M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > F8x CS DCT coding - who's had their cars flashed and how was it ?
      06-25-2018, 11:32 AM   #1
Bee Pee
1738
Drives: AW M2 DCT
Thinking about m4GTS DCT coding as, despite weird shift behaviour in slush mode, clamping pressure of dual clutches is increased by 10-15% - which is a good thing if upping the ante in terms of remapping etc as DME output responses rely mainly on load controlled inputs.
However, keen to hear from folks who may have had F8X CS DCT flash instead wrt shift behaviour etc....
Fettled M135i EB AT - gone but not forgotten:
AW M2 DCT
      06-25-2018, 10:28 PM   #2
Yiruna
Yiruna's Avatar
Drives: M2, C63s, 718 Cayman GT4
2018 BMW M2  [0.00]
I don't know if it's just me, but it feels a bit slower on the downshifts, at least when going WOT from 7th. On certain turns at the track it seems sluggish around 2-3, usually at that point I'd have to manually shift just to stay within an optimal power band.
Whether or not this is due to the larger density core I'm running, thus taking a bit longer to supply the boost pressure needed, I don't know, but for what it's worth, I liked the GTS flash for certain aspects.
Prior to that, on a long straight away, the upshifts would give me the jerk reaction, but the GTS transmission smoothes the shifts way more. Makes it more controllable on the track.
2018 MG M2 - Ohlins R
      06-26-2018, 07:29 AM   #3
cenz422
Drives: E46 M3
Yea so far I've heard more negatives with the GTS DCt tune vs positives. Reason why I haven't tuned mine yet.
      06-29-2018, 12:55 AM   #4
cookiesowns
cookiesowns's Avatar
587
CS should be a good compromise between ZCP and GTS
Feel free to PM if anyone needs to do this remotely.
      06-29-2018, 03:09 AM   #5
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
I didn't hear anyone flashed ZCP or CS gearbox to M2.
With GTS software, I think upshift is ok. But it's just way too lazy to downshift. You have to aggressively apply throttle for downshift, making a much less responsive car.
Lemania 2320
      06-29-2018, 05:48 AM   #6
Bee Pee
1738
Drives: AW M2 DCT
Sean,
thanks for feedback - is lazy downshift in auto mode or even in manual mode too ?
Might wait for M2Comp DCT SW although "F87CS" is showing in ISTA+
BP
AW M2 DCT
      06-29-2018, 06:26 AM   #7
SeanWRT
SeanWRT's Avatar
3179
Sean,
BP
Shifting strategy is all about auto mode. In manual mode, driver gets to shift itself.
Lemania 2320
      06-29-2018, 01:55 PM   #8
akkando
akkando's Avatar
5860
Sean,
BP
I want to figure out if there is a way to retrofit the buttons other M cars have to set the shift speed as you please instead of having to deal with the modes. Seems like it would be possible somehow.
      06-29-2018, 03:29 PM   #9
beppeM3+123d
beppeM3+123d's Avatar
202
Drives: bmw m3 dct + 123d e81
Sean,
BP
I am very attracted too, I have take the wiring schema, the problem is that kombi must be changed
      06-29-2018, 05:52 PM   #10
akkando
akkando's Avatar
5860
Sean,
BP
The instrument cluster would need to change?
      06-30-2018, 01:40 AM   #11
beppeM3+123d
202
Sean,
BP
I take a look at m2c and kombi have the same info of m4 m3 i don't think that flashing the pre lci kombi will be possible, maybe with lci.
      11-09-2019, 12:05 AM   #12
XSS11V
XSS11V
XSS11V's Avatar
277
Drives: M2 LCI - Mineral Grey
2017 BMW M2  [0.00]
Has anyone flashed the GTS/CS TCU tune using MHD and can report back? I’ve got MHD Stage 2+ (98RON) tune installed with cold start removed.
      11-16-2019, 04:53 PM   #13
MZWIE
Does not work correctly in our cars. Only works when paddle shifting. In regular D mode it is stuck in ECO. S and S+ don't work.
XSS11V276.50
