07-08-2018, 10:14 AM | #23 |
Rep 624
A higher flow LPFP should generate more "drive" to the passive jet pump so to me that sounds like a better solution than the Dinan reroute kit. If I've understood the starvation problem correct that is :-)
Anyone have any link tips? |
07-08-2018, 10:21 AM | #24 | |
Rep 3,695
As for other options, I think you’re looking at stuff like this: http://www.fuel-it.com/bmw-f-series-...-lpfp-upgrade/ |
07-08-2018, 10:30 AM | #25 | |
Rep 624
07-08-2018, 11:05 AM | #26 |
Rep 2,523
This has been discussed at length. The HPFP is the issue, not the LPFP.
07-08-2018, 11:14 AM | #27 |
Rep 3,695
There’s definitely confusion out there on this, so let’s try to make it more clear:
-If you get limp mode while pulling hard in gears 3-5 on a straight away, it’s the HPFP. -If you get limp mode while pulling G’s around a corner and on 2/3 of a tank of fuel or lower, it’s the LPFP/saddle tank fuel pick up issue. |
Spartan King79.50 bsaez40.00 |
07-08-2018, 12:52 PM | #28 | |
Rep 624
ZM22810.50 |
11-12-2018, 04:08 PM | #29 |
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
I'm running a dinan stage 1 turbo, fuel it 450 lpfp, and meth. Still getting hpfp crash in WOT pulls. Is this tuning? Or am I missing something?
Log: https://datazap.me/u/kayblasto55/log...19&mark=50
Quiet M235i
11-12-2018, 05:13 PM | #30 |
Rep 2,523
You need to upgrade the HPFP
11-12-2018, 08:31 PM | #31 | |
Rep 2,577
Lemania 2320
11-13-2018, 04:08 PM | #32 | ||||
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
Quiet M235i
11-16-2018, 06:00 AM | #34 | ||
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
Quiet M235i
08-24-2019, 05:36 PM | #35 |
Rep 2,523
Very interesting. First post?! Please supply more info!
08-26-2019, 08:32 AM | #36 | |
Rep 699
This should have it's own thread. I'm sure there would be interest. |
10-25-2019, 03:09 PM | #37 |
Rep 30
HPFP solution
Hi to everyone I've been posting this on multiple threads to help people with the issue of their HPFP. I think this will be the best solution for everyone moving ahead much cheaper than other fuel pumps that are out on the market and it is OEM so it will last. Watch this link and I think you'd be pleasantly surprised.
10-27-2019, 08:10 AM | #38 | |
Rep 4,132
10-27-2019, 08:48 AM | #42 |
Rep 30
10-27-2019, 09:40 AM | #43 |
Rep 699
10-27-2019, 11:05 AM | #44 |
Rep 30
You can always bend it with a hydraulic handheld bender the same way you bend air-conditioning pipework.. but I believe it's a very close fit so we would only need a small amount of tweaking.. The only issue is the electronic solenoid on the side it's on the opposite side for the supra. If you look at engines in a The new Z4/140i in photographs. You can see it's different on a New supra. So the supra definitely uses a different fuel pump..
