06-15-2018, 12:19 PM | #1 |
Meh
926
Rep 781
Drives: M3CS & Cayman S
Dinan LPFP fix HPFP crash?
At Bimmerfest West this year, i was talking w/ Brandon from Dinan, and he said that their LPFP should fix the HPFP crashes we see in our datalogs for those of us in the 400whp club. that would be a relatively cheap mod (compared to upgraded HPFP) for extra reliability when upgrading the turbo. but since i was talking to a Dinan rep about a Dinan product, i need to take his recommendation w/ a grain of salt.
anyone w/ the Dinan LPFP have logs showing the HPFP meeting its target pressures? |
06-15-2018, 12:40 PM | #2 |
Rep 3,695
Before the confusion begins, let’s call this a LPFP mod. It’s not a higher flowing LPFP. It just flows more fuel into the saddle tank via some hose rerouting to resolve the fuel pick up/limp mode issues when running under a half tank of gas on track.
I used to have fuel pick-up issues constantly on track, but it went away after I did Dinan’s LPFP mod, and I’m able to run the tank dry in hour long sessions. All of this out of the way, I do not know the answer to your question. I’m only Stage 1 right now and have not had any HPFP crashes. I will be Stage 4 in a couple weeks tho, and at an open track day in Aug, so I’ll find out. To make another point, a few of the Stage 4 guys that track have commented on HPFP crashes, but they’re also running aftermarket downpipes. I’m hopeful Stage 4 with all other stock bits will not cause HPFP issues. We will see. Last edited by ZM2; 06-15-2018 at 01:00 PM.. |
06-15-2018, 03:03 PM | #3 |
Rep 2,523
BS. I've got Stage 4 and I've done the mod and it still goes into limp mode on the track like clockwork. On 400+hp applications it's a fuel flow issue, not delivery.
06-15-2018, 03:15 PM | #5 | |
Rep 2,577
JB4 can have similar problem but less likely. Because unlike Dinan, JB4 allows for AFR leaning out with additional boost. Still it's too rich. It's kinda funny how hard JB4 has been trying to have N55 run richer all these years and now with M2 it just can't lean out enough. Flash tunes suffer much less on LPFP/HPFP issue. That's why.
Lemania 2320
06-15-2018, 03:17 PM | #6 |
Rep 2,523
Fewer issues with Stage 3 map
06-15-2018, 03:17 PM | #7 |
Rep 599
Drives: M2, C63s, 718 Cayman GT4
There's the new HPFP upgrade if you need it
2018 MG M2 - Ohlins R
06-15-2018, 03:18 PM | #8 |
Rep 2,577
That's because STG3 see less boost. Same AFR, less fueling stress.
Lemania 2320
06-15-2018, 03:19 PM | #9 |
Rep 3,695
06-15-2018, 03:20 PM | #10 |
Rep 2,523
Yessir
06-15-2018, 03:25 PM | #11 |
Rep 3,695
Dinan Stage 4 is right there with the 400-whp tunes, but pushes more of the power up top. I wonder if your DP is just enough to tip it over the edge and cause HPFP crashing on track.
My car is stock, except for the Stage 4 bits going on soon. I’ll find out if it holds up on track or not. |
06-15-2018, 03:27 PM | #12 |
Rep 2,523
Could be. Frustrating as hell when it happens though.
06-16-2018, 08:48 AM | #13 | ||
Meh
926
Rep 781
06-16-2018, 09:15 AM | #14 | |
Rep 2,577
1) HPFP and LPFP are completely different things. LPFP feed gas flow to HPFP to make pressure. It's the rail pressure that HPFP can't keep up, not the insufficient gas volume to make pressure. There is some pressure, albeit too low, when HPFP fails. And you can easily break HPFP at lower rpm with super high boost, when gas flow (GPM) demand is still low. 2) Any tune running lean can GREATLY relax LPFP. If you do your math, STG2 tune load with proper mixtur require about same amount of gas or even less (and thus lpfp stress) than the super rich stock tune. That's why you barely hear LPFP issue from flash tune user. I know a few tunes running richer (won't name them here) than others, but most certainly anything is better than stock. However, things are two folded blade, with bad gas like in CA and the likes, vendors better play safe being rich with their OTS tune that do not offer datalog tracking ability. Running lean can cause way way more serious issues than lpfp starving with rich afr, especially with piggyback on bigger turbo.
Lemania 2320
DrKevM52272.00 |
06-16-2018, 05:05 PM | #15 |
Rep 328
BM3 Stage 2 Race Gas Tune NO HPFP CRASH!
http://f87.bimmerpost.com/forums/sho....php?t=1506904 I have not done any fueling mods to car. |
FSociety3812.50 |
06-17-2018, 05:11 PM | #16 | |
587
Rep 898
Short answer: a LPFP will not solve any HPFP specific crashes due to tune. A LPFP could solve fuel pickup issues with an appropriate fuel pickup upgrade like the holley hydromats. A proper track tune should target the minimal amount of boost, with a good AFR curve to not run super rich, and have appropriate consistencies in place for IAT/Timing to prevent additional stresses on the motor. This will all keep HPFP happy, as the car will enrichen fuel if it detects knock which will exacerbate HPFP deficiencies.
alscks0414690.00 |
06-17-2018, 05:36 PM | #17 | |
Rep 196
06-17-2018, 06:15 PM | #18 | |
Rep 328
07-08-2018, 09:38 AM | #21 | |
Rep 624
07-08-2018, 09:47 AM | #22 |
Rep 3,695
