01-07-2023, 08:48 AM | #3 |
Rep 647
I was told by my wrench to keep one of these handy as it’s a common occurrence and they’re not always in stock locally.
Good reminder for me to follow through on that. |
///MPhatic13958.50 |
01-07-2023, 09:04 AM | #4 |
Rep 402
01-07-2023, 09:15 AM | #5 | |
The Seeker
13959
Rep 3,353
Did he give you a part number, or is there a superior part available? |
01-07-2023, 10:38 AM | #6 | |
Rep 647
https://www.ecstuning.com/b-genuine-...iABEgLnMvD_BwE That appears to be it. BMW 17128570061 |
01-07-2023, 11:31 AM | #7 | |
The Seeker
13959
Rep 3,353
terrywang94.00 |
01-07-2023, 03:19 PM | #8 |
Rep 501
Drives: 2018 M2 6MT
Good to know! I’ll write this down as an additional task when I change the oil at 50K or 60K miles.
Would this necessitate bleeding the cooling system? Something like this?: https://youtu.be/zXhwpFzsySw |
01-07-2023, 03:25 PM | #9 |
Rep 7,468
This is a very common issue on higher mileage cars unfortunately. It's just typical bmw plastics and heat cycling.
4
01-07-2023, 04:40 PM | #10 |
The Seeker
13959
Rep 3,353
I don't drive my car much, but I collect things like this just in case I ever make it to that mileage (I'm just weird like that). Every time I open my hood after washing my car (to wipe the underside and engine bay) I look for the oil gasket leak. Takes 2 seconds.
01-07-2023, 04:43 PM | #11 | |
Rep 7,468
terrywang94.00 |
01-08-2023, 04:37 PM | #12 | |
Rep 501
Drives: 2018 M2 6MT
The Q&A on FCP Euro’s page for the replacement hose says: “Yes. It is recommended to bleed the system while replacing this hose.” |
01-08-2023, 06:03 PM | #14 |
Rep 211
Drives: 2021 F87 M2 Competition
Happened to me on my E60 535i; they use a very similar (or identical?) overflow/return line on the N54. Was trying to be very careful when moving it and disconnecting it, but obviously I forgot about it for a minute when working on other parts of the engine that when I looked at it next, it was snapped. Did a DIY solution luckily at home and has been holding up since!
Even the repair instructions that I was using at the time mentions their fragility: https://www.pelicanparts.com/techart..._Replacing.htm
2021 F87 M2 Competition, Sunset Orange, 6-speed
2010 E60 535i xDrive, Space Gray, Auto (sold, but still in the family) |
jefe2000775.00 |
01-10-2023, 10:49 AM | #16 |
Rep 124
had one pop on my 235 at 70k-needed a tow which they didnt charge me for even thou i was way over miles
I now have that spare in the trunk of my m2 such as easy fix...unclip reconnect do a quick bleed and off you go in 10 mins |
01-10-2023, 11:47 AM | #17 |
The Seeker
13959
Rep 3,353
01-10-2023, 01:18 PM | #18 | |
Rep 7,468
No it doesn't tell you how much coolant you've lost, you will have to top off the expansion tank until the level stays stable at the middle mark, which is the seam. |
///MPhatic13958.50 Fred Conoway365.00 chris7197353.00 M2RAW121.00 Stylin.M2296.50 qnet683.00 ///M TOWN20150.50 |
01-10-2023, 01:24 PM | #19 | |
The Seeker
13959
Rep 3,353
I wish my Lotus had a system like this, it's such a PITA that I've never done it in 13 years of ownership. It has "lifetime" coolant, but I'm sure it should be changed. |
01-10-2023, 02:46 PM | #20 | |
Rep 7,468
The m2 is also supposed to have life time coolant as well, but that's definitely not true at all. Iirc the makers of the coolant stipulate a change interval as well. |
///MPhatic13958.50 chris7197353.00 |
01-10-2023, 05:25 PM | #21 |
Rep 554
I changed my hose at 70K km as a preventative measure, is a simple diy job on a cold engine (though the part costs double down here like everything else )
01-10-2023, 06:10 PM | #22 | |
Rep 211
