09-02-2020, 07:48 PM | #353 | ||
Rep 52
Cary Jordan 91 Oct Tune~ CSF FMIC, DCT Cooler~ VRSF Chargepipe~ MST Turbo Inlet Pipe~ Fabspeed Sportcat Downpipe~ Turbosmart BV~ Ohlins R&T~ do88 Oil Cooler, Radiator, Remote Radiator~ Girodisc Rotors
09-02-2020, 08:04 PM | #354 | |
Rep 2,526
On a 35 series tire, the sidewall height is equal to 35% of the tire width. For a 265 width tire, that's 265*0.35 = 127.75mm sidewall height. Or just over 5 inches (total). The diameter of the tire on the other hand is directly related to the wheel size. If you take the sidewall height and add the size of the wheel, you get the total diameter of the tire. An 18 wheel and a 19 inch wheel are exactly 1 inch apart in diameter give the same size tire. For the ride height, you're effectively a half inch lower with this setup than you would be with the same tire on 19s. How this affects alignment and suspension geometry I am not sure. I also run a completely different size on the track (265/35r18 square) than I do on the street (oem sizes). |
09-02-2020, 10:42 PM | #355 | |
Rep 1,092
bentom2335.50 |
09-03-2020, 01:27 AM | #356 | |
Rep 624
I run both 18 and 19 on my M2 https://www.willtheyfit.com/index.ph...=10&offset2=40 Change in stiffness. Yes. Possible. Change in alignment or height. None whatsoever. Last edited by MagnusT; 09-03-2020 at 01:33 AM.. |
09-03-2020, 01:38 AM | #357 |
Rep 624
If you are using the wrong size of tires within reason (I've run 265/35-18 square too) you still don't need to change anything.
The only real change is that when you run square you change the rake of the car slightly and also give DSC som other input due to change in the front/rear size relationship. But as long within reason the car has no problems with this. |
09-03-2020, 08:09 AM | #358 | |
Rep 350
But I do also run a 265/35R18 for the track which does result in a smaller tire because of more tires available at that size. In the end while the ride height will vary based on the different wheel & tire combos most of us don't worry about adjusting ride heights to match, you just either compromise both or target a specific setup and miss out on the other. |
09-03-2020, 08:29 AM | #359 | |||
Rep 2,526
tux2005234.00 |
09-03-2020, 03:43 PM | #361 |
Rep 5,728
Drives: 2019 M2 Competition
Anyone have suggestions for front camber on an M2 Comp with the following:
M Performance suspension, lowered all the way in the back and 4-corner balanced. Occasional track days - 4 a year or so. Mostly drive for fun, so more of a weekendish car Only drive about 5k miles at best. Goals = Very good handling, not too concerned on tire wear SHould i even get camber plates for the front? |
09-03-2020, 03:54 PM | #362 |
Rep 177
are the PFC08's really worth the extra money over some HAWK pads? Daily the car and also starting to track
2018 M2- Alpine White 6spd
some two wheeled fun and a tow rig |
09-03-2020, 09:24 PM | #363 | |
Rep 427
I haven’t personally tried any of the Hawk compounds, but friends tell me they have a much shorter life. So while the PFC and Pagids are more expensive upfront, they’re probably more affordable when you factor in pad life. |
09-03-2020, 09:32 PM | #364 | ||
Rep 2,526
A lot of us that track and daily our cars swap out pads. It's a quick and easy job. I personally run Ferodo DS1.11s in the front, and DS2500 in the rear. It gives a good balance of brake responsiveness and they wear at about the same rate on the track. Additionally, if you decide to get new street pads, the DS2500s all around are good. They produce less brake dust than OEM, and are quiet. They also share a similar compound to the DS1.11 so there's no need to rebed the pads after switching from track to street. |
09-04-2020, 12:22 PM | #365 | |
Rep 1,823
I have 7 days on my PFC08 and they are at 60% thickness. Never experienced fade with them, and they bleed speed nicely without overpowering 200 thread wear tires. Also there are stickers which say BRAKES SQUEAL BECAUSE RACECAR if you’re concerned about noise. |
09-04-2020, 01:32 PM | #366 |
Rep 177
Ground control or Millway camber plates for my OG M2 on MP coilovers. Car is a DD
09-04-2020, 01:33 PM | #367 |
Rep 624
PFC08 is my favorite. Love the initial bite, good modulation for me on my car, low pad wear (as long as kept at non crazy temps), low disc wear. Do squeal hilariously loud in periods. Thanks to the low wear and totally okay friction at street temps I don't bother swapping, I actually drive them year around even in winter hehehe. Making loud noises. Lazy bastard me haha.
5.M0NSTER3353.50 |
09-07-2020, 05:52 PM | #369 |
Rep 658
Installed the camber plates + installed the racing brake pads instead of OEM.
They shop could do the following camber: Front: -2.2 degrees Rear: -1.8 degrees I got the following: 1) My lap time became worse, being almost 2 seconds slower (on a 85 minute racetrack) that comparing to OEM set up with no camber plates in place 2) I didn’t like how the tires worked: - the car was not able to slow down at the same points as I did with OEM setup last week - the car became extremely tail happy, I had to catch it a lot when it oversteered comparing with last week when I had all OEM set up 3) The bite of the brake pads is better comparing to OEM, you can feel it immediately. 4) With the camber that I have now, the wear of the tires is more in the middle, than it used to be before with OEM set up. What could be wrong? Any ideas? I have a feeling that if I just go back to OEM camber angles, the handling will be better and the lap time will also be better. P.S. I am really pushing the car a lot and use the brakes quite aggressively. M2C, OEM everything (except for the camber plates, racing brake pads, castrol SRF fluid), michelin cup2 tires 245+265 (this I can’t change due to regulations of the time attack event) |
09-09-2020, 04:02 AM | #370 | |
Rep 744
Brakes: Did you feel you needed to brake earlier or later (you did not specify this). Sounds like you either did not get them up to temp or didnt apply enough pressure. The OEM pads are quite grabby at the top of the pedal vs. say Pagid RSLs. Alignment: Your camber is barely different from stock. Cup 2s need much more agressive camber to work well. 3.5 front 2-2.5 rear. Toe specs? Remember that more front end grip without corresponding increases in the rear will give oversteer. You may also be feeling more confident and stepping on the gas a little sooner than before or carrying more speed into corners resulting in sliding on the way out. Oh and how old are the tires? cant compare "fresh" lap times to "part worn". I notice that fuel for example makes a noticable difference in lap times.
09-09-2020, 04:43 AM | #371 | |
Rep 1,092
How did the toe change with the new alignment? In my experience it affects the handling more than the camber. Do you have the alignment report that would show before and after? |
09-10-2020, 05:29 AM | #372 |
Rep 658
09-10-2020, 05:34 AM | #373 | |
Rep 658
Tires were absolutely new. The shop said they can’t do -3.5 front on the stock suspension of the M2C using just the camber plates. They said they need some aftermarket steering rods to do so. Last edited by kart driver; 09-10-2020 at 11:31 AM.. |
09-10-2020, 05:38 AM | #374 | |
Rep 744
