12-13-2021, 02:50 PM | #1 |
2435
Rep 11,669
M2 CS Racing Splitter - Install hardware
Hey guys, looking at picking up the M2 CS Racing Splitter 51628328240 (plastic)
I found a hardware parts list but not the quantities. Fastening elements - 51118083744 Fillister head screw with collar - 41008436007 Hex bolt - 07119908547 Hex bolt - 07149213164 Anyone install one of these that can help with quantities & DIY tips? Thanks |
12-13-2021, 03:03 PM | #2 |
2435
Rep 11,669
just found a listing for the CF splitter.
I assume the mounting hardware will be the same.... https://parts.bmwnorthwest.com/a/BMW...t/51_Z030.html |
12-13-2021, 06:02 PM | #3 |
Rep 3,549
The CS Racing splitter has additional screw holes (all the front most screws with 8mm heads and washers) that the competition bumper doesn't have, so you'll want to add clips (51717065773) for those. You'll either want to cut slots in the bottom of the bumper to slide those clips onto, or see if the lower front bumper mount piece (51118054310) can be modified for the clips and the screws long enough to reach it.
inTgr8r2434.50 |
12-13-2021, 06:55 PM | #4 |
Rep 21
Just had one installed a few days ago, and even with the mounting brackets, parts of the bumper near the brackets will still have to be cut. Was a little hesitant about cutting a bumper, but figured I could always get another bumper. If the bumper is not cut, there will be a good one inch gap between the bottom of the bumper and the splitter.
inTgr8r2434.50 |
12-14-2021, 08:18 PM | #6 |
Rep 3,549
Alternatively you can install rivnuts on the bumper where the front 8mm head screws are supposed to go. You might have to use different screws than the 8mm head ones, but it's easier than cutting the bumper and sliding a clip on there IMO. The bumper is 3mm thick, and should be fine considering all the other mounts for the splitter.
inTgr8r2434.50 |
12-27-2021, 08:42 PM | #7 |
2435
Rep 11,669
01-16-2022, 01:49 AM | #9 | |
Rep 9
On CS Racing diagrams center supports are bolted to the bumper while CS diagrams show rivets instead, also CS Racing diagram, you can watch it on APMMotorsport, doesn’t show left and right bracket as part of the fastening elements. |
01-23-2022, 04:33 PM | #10 | ||
Rep 116
RamonRuiz0.00 |
01-24-2022, 11:02 PM | #11 | |||
Rep 9
05-15-2023, 07:23 PM | #13 | |
Rep 4,733
From the link above 2 x #6 2 x #5 4 x #8 I thought it was roughly 8 #7s. I didn't remember there being two sizes of these. |
