05-21-2021, 08:37 PM | #23 | ||
Rep 1,490
But, once you are back on street for longer period of time I would switch to regular street oil. Street oils have more dispersants and detergents. They are better for grocery shopping, school runs etc. Motul Sport is designed to be good on track but also good on street. That is why price is close to 300V. I was test driver for oil company and later for car magazine in Europe. Worked on oil, brake fluids etc. development, on ground testing. |
05-22-2021, 12:53 AM | #24 | |
Rep 7,321
05-22-2021, 01:07 PM | #25 | ||
Rep 1,490
M1 0W40 is exceptional oil, but I would not use it in anything with direct injection. SAPS levels in that oil is ridiculous, and SAPS is your carbon build up. SAPS level in M1 0W40 is 1.34% and in Castrol 1.13%. That is HUGE difference. I personally used M1 on track, but I have N52 engine. If I had N/S55 I would not use it. |
05-22-2021, 05:37 PM | #26 | |
Rep 344
07-06-2021, 11:59 PM | #27 |
Rep 344
In case anyone is curious what BMW 0W 30 is like after ahem a few track days, I received my UOA a few weeks back. I switched to Motul 8100 X-cess Gen 2 5W 40 (potentially a record for the length of name of an oil) for better track durability while keeping under warranty for the time being. I spoke with Blackstone over the phone and they reiterated that since this engine is new enough it's likely I'll see trace amounts of metal from break in. According to them, no concerns at this time.
07-07-2021, 08:11 AM | #28 | |
Rep 1,490
Iron is uber high for that mileage but let's give it a pass since vehicle is new. |
07-07-2021, 11:02 AM | #29 | |
Rep 1,823
2017 BMW M2 German Spec
07-07-2021, 03:47 PM | #30 | ||
Rep 1,490
07-07-2021, 06:33 PM | #32 |
Rep 1,490
No. But, my take is that they are using racing only fluids. Very (if at all) low on dispersants and detergents and very thin to lower parasitic losses. Probably heavy Ester based with high initial oxidation. You really don't want that stuff in an engine or transmission for a long time.
07-07-2021, 10:39 PM | #33 | |
Rep 1,823
I might use that Blackstone bottle to test a jungle juice I just mixed in a Camaro. Car came with (I assume) synthetic 5W-30 from a dealer, with less than 1K miles on the oil. It takes 10QT. Then I drained 5.5 quarts, and added 3.5QT Mobil 1 15W-50, 1QT Castrol Syntec 5W-50, and 1QT Valvoline 5W-40, that last one is what the manual calls for if you're tracking. 5W-30 street use, 5W-40 track use.. I had a bunch of stuff sitting on the shelve and didn't want to waist perfectly good oil in it already. So I should be running 8W-38 right now.... ish. Curious how it stands up to 5,000 street miles and 3 track days I'm planning between now and end of September. I might run this one by Blackstone to see what they think. I've done plenty of oil analysis after "extended" drain intervals, and it taught me to trust synthetic oil of 40+ viscosity rating. This is why I get this brave. But the mixology is new for me too, so let's see.
6MT, Driver's Package --> SOLD 2018 Camaro SS 1LE. Because race car! "Redline a day keeps the mechanics away" Last edited by 5.M0NSTER; 07-07-2021 at 10:55 PM.. |
07-07-2021, 11:16 PM | #34 | ||
Rep 1,490
07-07-2021, 11:30 PM | #35 | |
Rep 1,823
But does a bit more Zink, or a bit less Molybdenum make that much of a difference? In the end, in my book Good Oil is Good Oil. So I see little risk. Let's hope my hunch is right.
6MT, Driver's Package --> SOLD 2018 Camaro SS 1LE. Because race car! "Redline a day keeps the mechanics away" Last edited by 5.M0NSTER; 07-07-2021 at 11:37 PM.. |
07-07-2021, 11:42 PM | #36 | ||
Rep 1,490
ZDDP is basically last line of defense. If HTHS is not enough, ZDDP and other additives are what protects engine. |
5.M0NSTER3359.50 |
07-08-2021, 01:40 PM | #37 | |
Rep 7,321
07-08-2021, 06:12 PM | #38 | |
Rep 1,823
The way I think about it is that if you can run either Shell, or Castrol, and you get enough protection, than it will also work with a mix. On the chemistry level if one has a lot Titanium, and one doesn't, in the end you'll end up half way in the middle in terms of PPMs. The big question is if any of the other chemicals interact with each other in a non-desired way.
07-08-2021, 08:05 PM | #39 | ||
Rep 1,490
5.M0NSTER3359.50 |
