M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Help with DIY MPE install
      01-13-2020, 02:19 PM   #1
taingy_sauce
Recently bought a used MPE off facebook market place but it didnt come with the bluetooth module(it really didnt come with anything other than the actual exhaust). I called my local BMW dealer and tried to order the missing parts but they said there is no way to get that stuff without ordering an entirely new exhaust from BMW. Anyone here know if this is possible? The seller works at BMW and bought it off a customer so he does not have these parts.
I really need:
- The bluetooth module and button that controls it
- The clamp
- Instructions would be nice
In retrospect i shouldve done more research on what i needed for this exhaust.
      01-13-2020, 04:26 PM   #2
///Monika
Drives: '18 X3 M40i & '18 M2
Hope this helps a little bit. Hopefully someone can assist with the BT controller. Someone on here has posted the actual installation instructions (photos).
https://www.realoem.com/bmw/enUS/sho...diagId=03_4010
I really need:
- The clamp
      01-13-2020, 04:46 PM   #3
Anthony1s
756
Drives: 2018 Mineral Grey M2
I haven't seen anyone successful in buying the MPE valve electronics yet. You might be able to swap in the OEM exhaust valves and run them to the OEM system. That might be the easier way to get working valves. There is a thread somewhere here about that.
      01-13-2020, 05:45 PM   #4
///Monika
Here is the company that produces the BT module: https://www.redarchmanufacturing.co.uk/contact-us/
Hope this helps. Anthony1s has a good suggestion. Take a look in this section for the thread on swapping in OEM valves.
Last edited by ///Monika; 01-13-2020 at 05:57 PM.. Reason: Removed link to instructions (was for BT pairing).
      01-13-2020, 10:36 PM   #5
taingy_sauce
thanks a bunch, ill have to find that thread and see how it they've done it. My main concern is that the 2 valves wont be able to talk to each other. To my understanding, the OEM only has one valve controller and it is controlled VIA the driving mode you're in. The MPE has 2 valve controllers so I would need the wire to get them to sync up
      01-13-2020, 10:38 PM   #6
taingy_sauce
thanks for finding that company, Ill have to try Anthony1s suggestion out first. if not then maybe i can order that module from them. The local BMW dealers were having trouble ordering the part because it had no part num associated with it. I'll post back if I come up with something!
      01-14-2020, 12:26 AM   #7
jayg80
jayg80's Avatar
Drives: M3
Is this what you are looking for?
https://www.getbmwparts.com/oem-part...b3J5IFBhZ2U%3D
      01-14-2020, 08:31 AM   #8
Joakim_79
Drives: BMW 230i 2018
Try this cable with the OEM actuators # 18302414899
the MPE actuators have the # 18302409515 printed on them
the OEM actuator has the # 18308632154 printed on it
Remember not to run the actuator when it is not screwed to the exhaustvalve on the exhaust. you might run it to far and break it. I accidentally did that.
      01-14-2020, 08:33 AM   #9
Joakim_79
Originally Posted by jayg80 View Post
That is only the blutooth button, he also need a electronic box and cables, those can not be bought separately. Atleast not from BMW.
      01-14-2020, 01:13 PM   #10
longbeachbluem2
longbeachbluem2's Avatar
Drives: '76 2002 / '17 F87 M2
2017 BMW M2  [0.00]
1976 BMW 2002  [0.00]
2004 Audi Allroad  [0.00]
Installed mine a couple years ago, but here are the links I used (in case the attachments don't upload). Like others have said, hardest/longest part was cutting the old one out. Local autoparts store lends tools, but sometimes you get the new one and other times you get the dull old one.
- PDF MPE Installation Guide - https://f87.bimmerpost.com/forums/at...8&d=1482894490
- PDF MPE Installation Guide (although in German) - https://f87.bimmerpost.com/forums/sh...&postcount=245
- F87 Installation - https://f87.bimmerpost.com/forums/sh....php?t=1451600
- F80 Installation - Helpful to see other people's experiences/procedures, but our installation is obviously different - https://f80.bimmerpost.com/forums/sh....php?t=1226950
      01-14-2020, 01:19 PM   #11
longbeachbluem2
2017 BMW M2  [0.00]
taingy_sauce Also just realized that BMW calls it the "M Performance tailgate silencer system retrofit kit" on the instructions I just uploaded. Even the German google translates to "flap silencer system"
      01-14-2020, 01:25 PM   #12
///Monika
Outstanding (+1).. These install instructions need to be referenced in this 'sticky' section:
https://f87.bimmerpost.com/forums/sh....php?t=1201088
      01-16-2020, 11:07 AM   #13
hypermatic
12
Drives: 2018 M2 LBB
I'm in the same boat - I bought my MPE second hand and it didn't come with any of the wiring or clamps. I found a company called CG precision that offers a valve control system for the actuators
      01-16-2020, 11:08 AM   #14
MZWIE
I mechanically fixed mine to be always open.
      01-16-2020, 08:19 PM   #15
taingy_sauce
sweet, what are your thoughts on this system? Also if you don't mind me asking the price range? Im reaching out to Red Arch, the company that manufactures the wiring harness and BT module, but haven't heard back from them yet
      01-16-2020, 09:13 PM   #16
Anthony1s
756
Here's the CG one he's talking about
cgprecision.com/#!/VSC-2-Variable-Sound-Controller-for-BMW-M2-M3-M4-X5M-X6M-Exhaust-Valve/p/47094105/category=34601206
While I was looking for that, I found a guy who said he was able to get the MPE harness, and provided a part number. Here's the link to that. Look at the last two comments
https://f87.bimmerpost.com/forums/sh...php?p=24459548
And the part number
https://www.realoem.com/bmw/enUS/partxref?q=18302414898
      01-17-2020, 07:44 AM   #17
hypermatic
12
Drives: 2018 M2 LBB
And the part number
I actually just went with a straight pipe setup with the MPE instead of connecting a valve controller. But if you want to go with the CG Precision, make sure you email them first because they have to modify the controller for the second valve.
      01-18-2020, 06:44 PM   #18
taingy_sauce
Ya I think i might end up doing that too. The did you completely remove all the wires connected to the exhaust?
      02-22-2020, 06:36 AM   #19
nelsdvn
Gangnam Member
nelsdvn's Avatar
Drives: '17 M2, '15 X5d
[QUOTE=longbeachbluem2[/QUOTE]
Totally unrelated but longbeachbluem2 your dm box is full. Can't reply to you.
Current: 2015 BMW X5d | 2017 BMW M2 | 1976 BMW 90S
Gone but not forgotten: 2016 BMW 228i, 2014 BMW 228i, 2008 BMW 535xiT, 1998 BMW 328iC, 1991 BMW 325iC
      02-22-2020, 11:40 AM   #20
Anthony1s
756
Originally Posted by nelsdvn View Post
Totally unrelated but longbeachbluem2 your pm box is full. Can't reply to you.
The PM box was antiquated, you have to DM now. At least that's the impression I get from all the kids these days haha.
      02-24-2020, 01:00 PM   #21
longbeachbluem2
2017 BMW M2  [0.00]
Thank you. Just cleared it out
      10-02-2020, 05:27 PM   #22
FiveDirtyFive
FiveDirtyFive's Avatar
Drives: 2017 OG 6MT M2
How did you do this if you don't mind me asking.
