M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > M235i vs M2 cooling
      09-12-2019, 07:15 AM   #1
AmuroRay
AmuroRay's Avatar
2283
Drives: M235i
M235i vs M2 cooling
Is there a difference between the M235i and M2 when it comes to cooling?
I thought the M2 comes with an oil cooler and aux radiator, but I think the M235i does as well.
      09-12-2019, 03:22 PM   #2
M Fifty
844
Drives: M2 & 330CI
Have a look on realoem.com. You should be able to answer your question.
      09-13-2019, 10:41 AM   #3
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
If M235i is "hot climate spec" then it has the additional radiator on front LHS + upgraded fan (600W -> 850W), both of which are standard fit on M2.
M2 has DCT cooler which I don't believe M235i ZF auto has.
Else pretty much the same as far as hardware is concerned.....
I believe engine temperature management FW maybe different ie more allowing M2 to being resilient than M235i at handling high temps.
Current '22 X3M LCI..
      09-13-2019, 11:22 AM   #4
AmuroRay
AmuroRay's Avatar
2283
Drives: M235i
Thank you!
