M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > ☛ MHD Flasher F Series (F87) discussion ☚
      12-24-2017, 10:38 PM   #23
nomade30
Drives: 18 M2, 91 325, 05 DMAX
With MHD flashing method does it increment the flash counter? Meaning you would be limited to 60 flashes before the ECU won't allow it anymore?
How can you become an MHD tuner?
      12-26-2017, 04:18 PM   #24
MHD Tuning
MHD Tuning's Avatar
Germany
1621
Drives: M3F80#M5F90#340iF31#SupraA90
We'll work on freezing the counter.
If you are a professional tuner just email us. Or did I misunderstood?
      12-26-2017, 09:26 PM   #25
nomade30
Not looking for a job, just curious if I can upload my own files with MHD. Would be nifty to be able to flash via mobile rather than have to pull out the laptop, and if someone is interested in me tuning their car for them, this might be a viable option for distribution. Still email?
      12-28-2017, 02:12 AM   #26
cookiesowns
cookiesowns's Avatar
Taiwan
422
Drives: M2C 6MT, 535i N54, X3 N55
I've applied for the MHD Beta on my M2, and also the X3. hoping I get accepted.
With that said, will XDF files be provided for the M2 like it was on E series N55/N54?
BM3, MHD, ECUTek Calibrator | 2019 M2 Competition 6MT SO | Suntek Ultra | Gyeon Syncro + CarPro Skin
      12-28-2017, 03:12 PM   #27
NOLAGUY
Drives: LBB M2
That, or I have contact with 2 vendors working of upgraded HPFPs (which I would definitely prefer over PI).
Are you working with TuningTechFs? I've been in contact with them for the last couple months. They are close to releasing a HPFP upgrade for the N55.
      12-28-2017, 06:31 PM   #28
SeanWRT
SeanWRT's Avatar
2496
Drives: E90 M3 & F87 M2
Is it the s55 dual pump solution?
Lemania 2320
      12-28-2017, 07:13 PM   #29
NOLAGUY
Drives: LBB M2
Yes, that's what they did for an M2 a couple months ago.
      12-29-2017, 03:57 PM   #30
MHD Tuning
MHD Tuning's Avatar
Germany
1621
Yes you can edit and flash your own file. Most self tuners set up a dropbox or google drive folder so they can edit their maps with tuner pro on PC, and files are updated on their mobile device for easy flashing with MHD.
Yes tables definitions will get released when the beta goes open.
I knew TTFS did a one shot s55 dual pump retrofit, I did not know they were preparing a kit. Now that makes 3 upgrades in the making
      12-29-2017, 04:13 PM   #31
MHD Tuning
MHD Tuning's Avatar
Germany
1621
Testing status
We have received for the closed beta way more inquiries than expected (300+). We are processing them as fast as we can (during our holidays) so we can start OTS maps testing as planned early January.
The full OBD (no DME unlock needed) method has been working flawlessly on the two dozens cars so far that received the initial MHD install flash, be it for a custom map or the stage 0 map (OEM calibration) while waiting for the OTS maps.
bollinm23.50
      12-31-2017, 03:39 AM   #32
Gimmethecash
Gimmethecash's Avatar
138
Drives: F90 M5 Comp
Android device flashing, turbo upgrades, hpfp kits coming...exciting times.
MHD Tuning1621.00
      12-31-2017, 07:36 AM   #33
velociti
Drives: 2009 E90 M3
Would an upgraded HPFP be beneficial for a stock turbo car, or really only for upgraded turbo and/or ethanol setups?
      01-04-2018, 05:28 AM   #34
MHD Tuning
MHD Tuning's Avatar
Germany
1621
Originally Posted by brooke1972 View Post
I would guess you could push the stock turbo safer with more fuel pressure but doubt anything more than 6psi over stock..
In out testing, the hpfp is more limiting than the stock turbo (especially if you tune with a safe AFR, more on the rich than lean side) from 15psi with 12.3 AFR. Even on pump gas, not for ethanol mix, so it's going to be even more critical for e85.
      01-04-2018, 08:49 AM   #35
Bee Pee
1212
Drives: AW M2 DCT
Read somewhere that OE S55 dual HPFP's had been successfully grafted onto N55 to give a stealthy, robust OE solution alternative to PI and TBI ....anyone got any more details ??
Fettled M135i EB AT - gone but not forgotten:
AW M2 DCT
      01-04-2018, 02:06 PM   #36
NOLAGUY
Drives: LBB M2
Yes, that was TuningTech. They are actively working on a package to sell to the public as a DIY kit. You will have to run some sort of tune to make it work. They expect to have something available in several more weeks.
m2ruder1124.50
      01-05-2018, 02:24 AM   #37
cookiesowns
Taiwan
422
Yes, custom fueling table is required to activate the secondary pump. Currently this is possible on BM3. I'm sure once XDF's are released and someone tuning on MHD gets their hands on the kit it'll trickle down.
It's funny that just a few days after I was looking into this TTFS releases info
FSociety3226.00
      01-09-2018, 11:11 PM   #38
RedCarrot
RedCarrot's Avatar
Drives: '18 AW M2
MHD, will the tune have the ability to adjust or get rid of throttle delay (particularly in comfort and sport modes)? Thank you
Gone but not forgotten:
'14 Corvette Stingray (2014-2017)
'05 Boxster S (2005 - 2014)
'00 S2000 (2000-2005)
      01-10-2018, 01:37 AM   #39
Lukeni
If the delay is caused by physical limitations (turbo spool up etc) i doubt it will be possible
      01-10-2018, 02:31 AM   #40
cookiesowns
Taiwan
422
Yes, throttle maps should be mappable on MHD. I'm sure the guys will create a flashtime option for throttle maps once out of beta like on the N54 flasher.
RedCarrot208.00
      01-10-2018, 11:01 AM   #41
RedCarrot
RedCarrot's Avatar
Drives: '18 AW M2
I think the turbo lag is minimal in the M2, esp after my sport cat install. Its the throttle lag that makes it seem much worse. I am perfectly happy with the response in sport+ mode but Id preferred not to have to switch to it every time I start the car
That saves me from considering the Sprint Booster
      01-10-2018, 03:56 PM   #42
MHD Tuning
MHD Tuning's Avatar
Germany
1621
Hopefully soon we will have some good options to target the fuel issue on the m2. Now when that happens will mhd have an alternative map option so the m2 can be pushed a little more?
We'd be the first to enjoy more fueling!
You don't absolutely need BM3 nor the xdf to edit the tables. There are there. I don't know bm3 much though, can you add tables / edit raw hex?
Do you mean lag, or pedal position to torque request mapping?
      01-10-2018, 04:53 PM   #43
RedCarrot
RedCarrot's Avatar
Drives: '18 AW M2
Definitely the former, which is what something like the Sprint Booster addresses. Sport+ and Sport (to lesser extent) modes also reduce such throttle lag. The latter is just fine at least to me.
      01-11-2018, 01:53 AM   #44
cookiesowns
Taiwan
422
It's all load based tuning. There should be some neat things soon from MHD coming for the M2
Tags
flash, mhd, tune
Copyright ©2000 - 2020, vBulletin Solutions Inc.
