04-16-2020, 05:50 AM | #6073 |
Rep 936
AndrewC198910931.00 |
04-16-2020, 09:21 AM | #6074 |
840
Rep 1,271
Adjusted the suspension further, stupid thing had understeer, now it sits pretty neutral, but have not pushed it with the new set up to point of grip loss.
Lower front by 1mm, one click to soft on front for a bit more bite. |
04-16-2020, 10:09 AM | #6075 |
Rep 224
04-16-2020, 10:38 AM | #6076 |
Rep 4,551
Drives: 2015 328d xDrive
ae03440240.00 NYC Bimmer259.50 |
04-16-2020, 11:22 AM | #6077 |
Rep 392
Nothing exciting but took some time to clean up the rust that collects on the hubs so the brake rotors come off when they need changing in a few years.
I was only able to do the rears - realized the 5mm allen wrench I needed for the fronts, I broke a few weeks ago fixing my son's car. before - this is after only 14 months (2018 model bought new in feb. 2019) and I already cleaned and sprayed what you can reach with the rotor in place last year. after |
akkando5864.50 FractalFootwork142.50 |
04-16-2020, 11:23 AM | #6078 |
Rep 309
Drives: 2018 M2 LBB - 6MT
How many clicks front vs rear now?
04-16-2020, 11:24 AM | #6079 | |
840
Rep 1,271
gphung193.50 |
04-16-2020, 11:25 AM | #6080 | |
Rep 1,466
04-16-2020, 12:09 PM | #6081 | |
Rep 392
I used whatever black primer/paint was in the house - I think it's rustoleum, but nothing special. If I planned ahead, I would have gotten an actual rust inhibitor. I "masked" it by poking he hub through the bottom of a box to contain the overspray. After that I just wiped the wet paint away from the machined surfaces with a paper towel wet with brake cleaner. "paint box" (my grease gun leaks) |
dtmurf481.50 |
04-16-2020, 03:59 PM | #6082 | |
Rep 1,466
2018 ///M2 LCI, LBB, 6MT...
04-17-2020, 01:56 PM | #6083 | |
Rep 757
'17 M2 DCT Long Beach Blue
04-17-2020, 02:14 PM | #6084 |
Rep 139
Had my calipers painted same colour as my Kona MTB
04-17-2020, 04:38 PM | #6085 | |
Rep 1,466
The front and rear calliper bolts have different torque specs, which is odd, though they probably equate to the same result: Front Caliper Bolts - Torx screw with washer - M12X1,5X43 ZNS3: 34106864424 x 4 - Renew 110 NmCTSean, did you replace yours, did you find a way to remove the disc without removing the callipers, or did you simply re-use the bolts?
Poochie9104.50 |
04-17-2020, 07:16 PM | #6086 |
Rep 392
I just put them back in. Reading a bunch of posts and it seemed like some people reused then with no issue, others replace them. I might order a few to do it right. I did find a video after than suggests removing the pads provides enough clearance to get the rotors off but haven't tried it. I'll try that way if I have time to do the fronts this weekend.
Regarding replacements, mine are traditional bolt heads. some of the replacements appear to be torx (or inverted torx - I don't know the right name. the torx are almost twice the price of the older part# and of course require the right socket to install them. If anybody knows what size torx the new bolts are can you post it? Last edited by CTSean; 04-17-2020 at 08:39 PM.. |
04-18-2020, 07:32 AM | #6087 | |
Rep 2,736
Looks great... how does the Dinan exhaust sound?
'19 M2C HS, 6-Spd, Slick Top, MComp Wheels
'18 GT3 White, 6-Spd, Buckets, PCCBs |
04-18-2020, 08:43 AM | #6088 | |
Rep 392
Also worth noting maybe is that, while the TIS says to "renew bolts", it also says the same on caliper bolts for the E36 and e46 and I reused those several times over a couple hundred thousand miles |
04-18-2020, 10:50 AM | #6089 | |
Rep 1,466
Nevertheless, I’ll probably try to get hold of some replacement bolts myself for when I do the job. Hope it didn’t cost you too much! |
04-18-2020, 11:33 AM | #6090 | |
16525
Rep 8,423
Do the light markers on the side of the road still light up at night like it use to?
04-18-2020, 12:09 PM | #6091 | |
Rep 392
I also figured having bought the 4 from FCP, I never have to buy any again. Extra convenient given the fronts use the same bolts. |
04-18-2020, 12:12 PM | #6092 | |
Rep 1,466
04-18-2020, 02:41 PM | #6094 |
Rep 251
M Performance Shift Knob!
Just received my new shit knob from IND!!! Looks and feels good.
