02-21-2020, 03:07 PM | #45 | |
Rep 6,635
beanfritter34.50 |
02-21-2020, 07:25 PM | #46 | ||
Luxury at the redline :)
9105
Rep 7,563
There is not such thing as "no blind spot" in a moving vehicle, as the Blind Spot/Field of View is constantly changing, when a vehicle is in motion, encountering various obstacles, at different angles. Depending on the size and make up of a vehicle, one car's blind spot might be more severe than another but it's naive to assume they don't exist or a properly adjusted mirror would completely eliminate it and that's the kind of overconfidence that can lead to accidents. Last edited by Poochie; 02-21-2020 at 07:35 PM.. |
02-21-2020, 08:08 PM | #47 | |||
Rep 6,635
02-21-2020, 08:27 PM | #48 | ||
Rep 500
02-21-2020, 08:44 PM | #49 | ||||
9105
Rep 7,563
There are instances where other vehicles are out of my field of vision, depending on my seat angle, height or mirror but even if I shift positions to eliminate one, it just creates another blind spot. Logically, there is no way around this.. I use situational awareness, the mirrors and at times, my rear view camera/ PDC sensors are coded to remain on, at all speeds, if i desire. Those tools, for the most part, helps reduce potential blind spots but I'm still always hypervigilant when switching lanes, especially towards the right. |
02-21-2020, 09:30 PM | #50 |
6637
Rep 4,145
Drives: '18 M2 6MT
02-21-2020, 09:47 PM | #51 | ||
9105
Rep 7,563
Not to dampen the mood but I've wittiness a person die before my eyes, in a car accident. It's a very humbling experience to see a human get ejected from a vehicle, twitch on the pavement for a moment, as their soul leaves their body. Then the paramedics show up a few minutes later and place a white sheet over their corpse - then they go smoke a cigarette and shoot the breeze.. I might off come as an asshole, in a attempt at humor but I'm solemn when need be.. |
02-21-2020, 10:00 PM | #52 |
Rep 336
“It is a concept dreamt up by people that use their mirrors to check if their own car is still there. It usually is. If not, you'd likely notice.”
This satire seems to suggest, correctly, that if you can see your own car in your side mirrors, your mirrors aren’t adjusted properly. Amazingly, this went right over some posters heads. Or through. |
02-22-2020, 12:29 AM | #53 |
Rep 179
I was actually so relieved the m2 doesn't have BSM. I have it on my daily and I cannot stand it. It's wayyy too conservative and does nothing but blink all the damn time when I change lanes. If you can feel your car and especially one this small there's a problem.
-2020 M2Cs
-2020 GLS450 |
02-23-2020, 02:20 AM | #55 | |
Rep 3,072
Honestly. The blind spot believers are up there with flat earthers, anti-vaxxers and climate change deniers. All four are easily answered with science. I gave you a link that explains it. I know you are an old timer but a link is something you can click on and it takes you to a web page. You can read this and learn stuff. It's well worth it and may even prevent you from crashing into someone when you are looking backwards instead of where you are actually going. This has been a public service announcement. |
02-23-2020, 02:21 AM | #56 | |
Rep 3,072
02-23-2020, 09:50 AM | #57 |
Rep 825
I will say, it is only very recently that I've learned how to set my side mirrors properly. Honestly, THIS forum has taught me so much about basic driving that I never knew before. I am not too proud to admit that for going on nearly 29 years, I had the following basics completely F'ed up: a) Seat position, b) steering wheel position and height, and c) side mirrors.
With regard to side mirrors, I did what I think 90+ percent of the driving population does: I positioned them to show me the sides of my own car!!! And driving the M2C, it was always unnerving to me to be constantly looking over my shoulders at "the blindspot" to change lanes. Thankfully members on this forum have helpfully shared videos and articles, etc., etc., and I finally learned to position them properly. Chris Harris videos on seating and steering wheel position have been invaluable. And with the side mirrors positioned properly, with the M2C's short wheel base, visibility and awareness of other lanes and drivers is amazing. The only thing I'm still working on now is drifting. As clear as the explanations are in this Chris Harris video, I still don't seem to be able to pull off the same tire shredding drifts as Mr. Harris! I don't get it! |
02-23-2020, 11:14 AM | #58 | |||
Rep 2,672
The only way you can adjust the field of view is by changing a sitting position. My assumption is the driver is in an optimal sitting position. Each mirror has a specified field of view that cannot change. We adjust mirrors and seating position to maximaze the field of view. What is changing when driving are conditions on the road and landscape. This is the information received by looking through windows and at mirrors. I hope nobody relies on BSM. If you are positioned correctly in your seat with properly adjusted mirrors, and check both mirrors AND look over your shoulder before initiating/signaling a turn you will complete the visual check. |
02-23-2020, 11:36 AM | #59 | ||||
9105
Rep 7,563
Or not related to the mirrors, the A-pillar can be a huge blockage, when making a turn.. I will agree that properly adjusted mirrors works very well, almost eliminating most blind spots but to say all, is a stretch, in my humble opinion. Knock on wood, I was never involved in a related accident because most of all, I use situation awareness, at all times and it has never fail me, in all aspects of my life. |
02-23-2020, 11:48 AM | #60 |
Rep 1,369
Clearly there are two camps here...
Group 1: setup mirrors correctly and you will have "no" blind spots. Group 2: love the BSM feature. Both groups can coexist peacefully and both are correct to a degree. I for one I'm a big fan of BSM because it gives me another layer of security, I really appreciate that. Maybe I could have setup my mirrors "better", but I also like the security nanny 😀. In fact, I just pulled out of a incredible deal because I want to take the gamble and see what "features" or special editions will be announced for MY21 (other than the M2CS). So let's get BSM for MY21! (Wishful thinking 😏
IG: @rise_n_drive
02-23-2020, 01:51 PM | #61 | |||||
Rep 2,672
Speaking of A pillar that is a known blind spot but it is very small and impacts driving in cities with large vehicles that can block a view of a pedestrian crossing the street as an exmple. |
02-23-2020, 03:17 PM | #62 |
6637
Rep 4,145
Drives: '18 M2 6MT
You lot are just about worthless to even talk to.
Go sit in a Miata with the top up, and adjust your seat and mirrors to any position you like, and THEN tell me there is no such thing as a blind spot. Until then, shut your idiot philosophical pie-holes, you're only making yourselves look like fools. |
02-23-2020, 04:04 PM | #63 | |
Rep 1,369
I believe BSM should be standard for new cars similar to ABS, seatbelts, airbags and traction control! Or at least make it an option available to all new cars. I do believe most new cars now do offer this feature.
IG: @rise_n_drive
02-23-2020, 05:50 PM | #64 |
Rep 336
“Until then, shut your idiot philosophical pie-holes, you're only making yourselves look like fools.”
What a jerk... |
02-23-2020, 06:09 PM | #65 | |
Rep 3,528
02-23-2020, 06:14 PM | #66 |
Rep 336
https://f87.bimmerpost.com/forums/at...1&d=1582502244
I’m confident that if I were driving a Miata with the top up, the mirrors adjusted correctly, I could see all the cars around the Miata as depicted in the picture. I’ve driven other convertibles with poor visibility with the top up, and I could spot all traffic around the convertible, in adjacent lanes, by looking in the correctly adjusted mirrors. If the surrounding cars are two lanes over, it’s more difficult. If you only turn your head to look back, most cars have blind spots. CORRECTLY ADJUSTED MIRRORS ALLOW SURROUNDING CARS TO BE SEEN IN THE MIRRORS, WHILE THEY MAY BE HIDDEN BY BLIND SPOTS, IF ALL YOU DO IS TURN YOUR HEAD TO LOOK BACK. |
Davil6524.50 beanfritter34.50 |
