BIMMERPOST Universal Forums > General BMW News and Cars Discussion > What engine oil is your BMW running?
      01-08-2021, 09:57 AM   #177
MightyMouseTech
MightyMouseTech's Avatar
4338
Drives: 13 135i 6MT LeMans Blue MSport
Originally Posted by Wolf 335 View Post
Dimensionally speaking, they seem to be identical.
Although dimension C is not listed on the HU8011
M2 Filter (MANN HU 8011)
E90 Filter (MANN HU 816)
Unless quality of the filtration medium is different i don't see a dereference.
When you look at the two of them, they look identical. Just one has an "M" logo on it. Must be a slightly different filter media.
      01-09-2021, 09:01 AM   #178
Efthreeoh
General
Drives: The E90 + Z4 Coupe & Z3 R'ster
Originally Posted by iqraceworks View Post
Not true at all. Sure, I will agree that a good Blackstone report won't keep you from blowing up your motor....nothing will.
But if you can get several reports done over a period of time in order to establish a baseline, if your "normal" readings start trending out of range, their reports will let you know that you are getting more fuel than normal in your oil (leaky injector), you are getting coolant or combustion gas particles in your oil (head gasket issue), you have abnormal amounts of lead/tin/brass in your oil (bearing issues), etc, etc, etc.....and then you can address the issue before it destroys the motor.
But I agree....one single test sample doesn't tell you much....you need several to establish a baseline for your motor.
I just have to say, as I've stated in other threads recently, I have well over 1 million driven miles in 40 years. I've never had engine oil analyzed by a company such as Blackstone. I've followed each of my vehicle's manufacturer's oil change interval and oil/filter requirements for the model I had and have yet to lose an engine, or have an engine require a repair related to oil performance. And almost every vehicle I've owned I've driven well past 150,000 miles and three past 200,000 miles. It adds $25 to an oil change for no real benefit.
An oil analysis tells you how the oil performed under the last oil change interval. It is no better a predictor of oil performance looking forward than the manufacturer's recommendations. For fleet operators, an oil analysis may be beneficial, but fleet operations are much different than private auto operation.
F32Fleet3571.50
      01-09-2021, 09:06 AM   #179
iqraceworks
iqraceworks's Avatar
2001
Drives: 2007 335i
It detected a head gasket leak on my 05' F250 diesel with 225k miles on it (trace amounts of coolant in the oil). Saved my block/heads from any real damage. I might have not know it had an issue until I was towing something out in the middle of nowhere and had the motor overheat and lock up.
I was able to pull the heads off and replace the gaskets.
It was worth $25 to me......
      01-09-2021, 06:22 PM   #180
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Originally Posted by David70 View Post
Originally Posted by MightyMouseTech View Post
Except BMW has now returned to Castrol.
"That’s why Pennzoil is the recommended supplier of genuine BMW Engine Oil in North America. "
https://www.pennzoil.com/en_us/performance/automakers/bmw.html
Scuttlebutt is that it ia changing back to Castrol once the current contract expires.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
Efthreeoh17309.00
      01-10-2021, 09:17 AM   #181
Efthreeoh
General
I've used BMW's oil all along for the E90. It started as Castrol, then switched to Pennzoil. Now I guess it'll go back to Castrol. Let's just hope they keep the bottles in the 1-liter size (which happened when BMW swapped to Pennzoil).
F32Fleet3571.50
      01-10-2021, 10:10 AM   #182
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro SS 1LE
What oil is in my M2? Dunno. Whatever BMW put in it 2 year ago. Last oil change March 2019. Next oil change March 2021 per BMW suggested use interval. iDrive tells me every morning I still have 10,000km left till next oil change. Had to top it off once in-between.
BMW Germany believe in every 2 years on 25,000km. So every ~15,500 miles. I do about 7,000 miler per year a few track days. Who am I to argue?
2017 BMW M2 German Spec
6MT, Driver's Package
--> SOLD
2018 Camaro SS 1LE. Because race car!
"Redline a day keeps the mechanics away"
F32Fleet3571.50
      01-10-2021, 05:42 PM   #183
David70
Drives: 06 Z4M Coupe - 13 Cadillac ATS
Averaging well over 25k miles per year for 40 years is surprising.
Like getting specialized health checkups, you can find many people that never did them and still lived a long time. It doesn't mean the check is worthless, especially if you have a family history of a problem. I also haven't paid for a Blackstone but with some engines prone to certain problems, like the S54 (the family history) and it's rod bearings that have shown to wear through, finding the problem before there is a problem has value. We have seen engines following the manufacturers recommendations still have problems, especially regularly tracked cars.
2006 Z4M Coupe - Stromung exhaust, ZHP knob, stubby antenna, clutch delay delete
      01-10-2021, 09:13 PM   #184
MX Racer
MX Racer's Avatar
Drives: 2012 E90 M3, 2010 550I, 2015 3
For leased cars that will be dumped that is fine. If you decide to keep it long term a shorter interval would be recommended.
      01-10-2021, 09:28 PM   #185
cooolone2
cooolone2's Avatar
625
Drives: 20' M240iX B58, 01' 330XI E46
Ummmm, just no! The oil oxidizing while sitting in the engine still requires it be changed every 6 months even while sitting! Lmao, unless of course it isn't yours, or you just don't care! And yes, you can get away with longer intervals, but it's a crapshoot depending upon the oil you use and the quality of the filter. Have fun!
      01-10-2021, 09:51 PM   #186
tracer bullet
tracer bullet's Avatar
Drives: '11 135i , '15 X3 35i
Sources / evidence?
David701567.00
      01-10-2021, 11:52 PM   #187
Teutonic
Teutonic's Avatar
Drives: BMW
Regardless of the warranty, bla-bla's and other manufacturer suggestion, the golden rule is:
* Replace the engine oil always at 10,000 km (6,000 miles) - maximum 15,000km (9,000 miles). If you love your car do it more often. A new oil will just help.
* If you are making less km than that per year YOU MUST replace the oil once a year, even if the car sits in the garage.
Don't be cheap an oil. You will pay dearly later....
      01-11-2021, 09:25 AM   #188
tracer bullet
Even then you can have issues. I'm a 5k miles / 1 year / whichever comes first person. I still ended up getting a new Valvetronic motor & eccentric shaft replaced. Only 29k miles on the car (2011). I have started to wonder if I actually drive it too infrequently because at least every other trip in it I make sure to drive 20 - 30 minutes to get it fully warmed up (no milky oil from lots of short trips).
      01-11-2021, 09:38 AM   #189
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
2657
Drives: 11' 335is DCT
I doubt changing your oil let's say 7k miles instead is going to prematurely cause issues with that.
Shit just breaks over time it is what it is. I don't think it's because you're not driving the car enough lol.
      01-11-2021, 09:46 AM   #190
Boltar
Sourkraut
29
Drives: E92 former, now F87C
That is actually possible. A BMW dealer once explained that to me:
Moving parts, all kinds of materials, tend to get "stuck" when you dont move them frequently. So when you then move them again, after a longer period of time, small bits and pieces will be teared off the surfaces. That way, leakage can and will happen. This applies to air conditioning compressors, for example.
Also, rubber parts of all kinds will lose their ability to flex when they are not flexed for some time.
In Germany theres even a word for that, Standschäden. Its a bit hard to translate it, "stand" means standing still and Schäden is damage. So you get the point: A car is made to be driven. Not to stand still.
Also, the oil I use is Ravenol 0w40, replaced every 12 months (i'm at ~8000 miles per year)
      01-11-2021, 10:41 AM   #191
tracer bullet
Generally there's always a thin layer of oil between metal surfaces i.e. crank journals and bearings. Obviously when running, but it stays behind afterwards. I wouldn't find it hard to believe that eventually however, gravity brings the metal parts together and gets 100% of the oil out of the way, at least in spots. My theory anyhow. Not sure if it's a week, a month, a year, but at some point (?).
      01-11-2021, 11:01 AM   #192
David70
I agree and also don't know the answer to it. A friend of mine has a Alfa Romeo Giulia Quadrifoglio (505 hp) that he doesn't drive in the Winter, I have a BMW Z4M that I also don't drive in the Winter. I put my car on a battery tender and it sits for 3 months, he start and pulls his car out of the garage I think every other week. I honestly don't know if my car starting at the end of sitting for 3 months is better than him starting his car every other week (6 times over 3 months), or if either matters. It would be difficult to get it to normal operating temperature when it is idling in the driveway in the Winter in Ohio.
      01-11-2021, 12:21 PM   #193
5.M0NSTER
5.M0NSTER's Avatar
I own it. I'm not worried at all. Modern oil is quite good these days. Filter is the weaker point.
I've had Blackstone analyze my oil after 9000 miles telling me that all is fine, and I should try a longer drain interval. On more than one occasion, with a couple different cars. Stopped subscribing to "change it sooner" after that. BMW know what they're talking about. I have 0 worries.
--> SOLD
David701567.00
      01-11-2021, 12:39 PM   #194
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Anti-wear (extreme pressure additives) additives stay behind and offer added protection.
https://www.machinerylubrication.com...cation-regimes
https://www.sciencedirect.com/topics...ry-lubrication
      01-11-2021, 12:44 PM   #195
MightyMouseTech
4338
Here in Canada, we follow the 1 year rule.
5.M0NSTER3353.50
      01-11-2021, 12:45 PM   #196
MightyMouseTech
4338
Starting the car once a week like that is the worst thing you can do for a car in storage. The oil will get loaded with fuel and water, exhaust will get filled with water.
Put in Stabil, fill the tank, fill the tires to 50 psi, put a battery tender on it and forget about it till spring.
5.M0NSTER3353.50
chris7197334.00
      01-11-2021, 01:06 PM   #197
ky0u
ky0u's Avatar
Drives: e92 335i, f22 m235i, e30 325is
2015 BMW M235i  [0.00]
1988 BMW 325IS  [0.00]
2007 BMW 335i  [0.00]
Agreed, The cost of oil is so cheap compared to damage caused by oil issues, always better to play it safe.
I do my e92 at 7,500mi, half of the indicated interval. My e30 gets 1 per 3500-5k depending on driving. I use liquiMoly on both and both running strong at 122k miles and 320k miles respectively.
      01-11-2021, 01:12 PM   #198
Mosaud1998
Mosaud1998's Avatar
Drives: 2019 BMW 540
2019 BMW 540  [0.00]
I use Liqui-Molly 5w-40 along with a Mann oil filter. I did add Liqui-Molly CeraTech at 70k miles. I am at 72k miles right now. I have not noticed any difference. Idk If I'll use Ceratech again. But, I change my oil every 5k/6 months and buy an oil change kit off fcp (lifetime warranty on everything).
Oil change kit: https://www.fcpeuro.com/products/bmw...427566327kt-lm
