05-12-2018, 11:55 AM | #1805 | |
Rep 4,541
Drives: 2015 328d xDrive
Okay I see what you did now, you changed road edge warning from not active to active. You're right, that feature should work with cars that have lane assist as it is not front camera/pdc based. The thing is i've never heard of road edge warning before and haven't seen it appear on any esys cheat sheets for the f22/f87. https://drive.google.com/file/d/0Bwv...hKSWdRTDg/edit But like you said, if the feature appears based on a vin reading why wound't it work? I guess what happened then might not be related to what you coded, and it might have been because of a connection disruption during the coding process itself. This has happened to a few others before you and has led to problems like the nav not working amongst other things. Never seen a vin change though, that's new. What kind of connection are you using? Wifi? Bluetooth? Was your car running at the time? It definitely appears as though whatever dongle you're using was defective or the connection wasn't stable enough to be coding wirelessly. I would always make sure to code over wifi (not bluetooth) while sitting in the drivers seat with the engine running. It minimizes the risk of a dropped signal. If you had the engine running and were seated in the car and were using a wifi connection then you may just have a defective/poorly working dongle and that might have been the cause of the failure. I've had plenty of dropped connections but luckily none occurred mid coding. I would feel much safer if there was a cable we could use, but this seems like the only option available for bimmercode/carly, unless of course you want to learn how to use esys. Sucks that this happened to you but unfortunately it's a risk that comes with coding/coding wirelessly. If the connection drops mid code, all sorts of crazy things can happen. All you can really hope for is that bmw sorts it out and you keep your warranty. I'm sorry that I don't have any other helpful advice other than just a few tips on how to reduce the risk of this reoccurring in the future. |
MSurge83.50 NYC Bimmer259.50 |
05-12-2018, 12:04 PM | #1806 | |
Rep 8
I was using wifi, sitting in the driver seat and car turned on but not with the engine running. I did not know it could be done with the engine running as that is not what directions said. I guess I just did not realize that this could be such a bad problem with possibly voiding my entire warranty. Since so many people in forums said it wouldn't and that so many people were doing it, that I figured it had to be ok as long as I wasn't doing expert, out of this world changes. Is there anything I can do to fight it or prepare to fight it while I wait to hear back on Monday? Does BimmerCode give that kind of warning? Not to throw the great work the developer did not this but if he is charging money for something that could destroy $10k worth of warranty then I have some type of assurance that it is partially ok/allowed. |
05-12-2018, 12:36 PM | #1807 | |
Rep 4,541
I don't know that the dealership can/will void your warranty, but you may have to pay them out of pocket to recode the car/fix the issue since it was your fault. It totally depends on the dealership and what bmwag says about it if they are contacting them about it. A while ago when I was new to the app like yourself I accidentally turned off rev match. Backups didn't fix the issue so I had it brought in for service. The dealer I go to fixed the coding issue I had for free and didn't void my warranty if that makes you feel any better. He just said next time it happened i'd be paying for the istep update out of pocket. Hopefully your situation takes a similar route. Best of luck. Let us know how it goes. |
NYC Bimmer259.50 |
05-12-2018, 03:53 PM | #1808 |
Rep 1,608
Andrew, as youve said, you have a mod-friendly dealer, who would be very forgiving for a situation like Gallahad's. But situations like his, and they are not unique, present exactly the reason many of us have chosen to use the harness bypass method to rid ourselves of ASD, for instance, rather than coding. Coding is great, and convenient when it works, but its not foolproof and dealerproof.
Boostm3
05-12-2018, 04:23 PM | #1809 | |
Rep 8
05-12-2018, 04:37 PM | #1810 |
Rep 1,608
Its a 15 minute installation which physically bypasses the ASD amp.. From what I understand it accomplishes exactly what the coding does, but without the failure opportunity.. Harness price is about $60 from a company in Fl. which makes them up.. Very happy with the result!
http://www.2addicts.com/forums/showt...php?p=19019063 http://f87.bimmerpost.com/forums/sho...hlight=technic
Boostm3
05-12-2018, 06:15 PM | #1811 | |
Rep 4,541
If you don't want to take the risk of losing your connection while you're coding (and having something like this occur) you should be using ESYS instead of mobile apps like carly and bimmercode. It's a more involved but much safer alternative. That being said the failure rate for coding via mobile device is low and there are only a handful of people with stories like the one above. The vast majority gets everything done without an issue. Last edited by AndrewC1989; 05-12-2018 at 06:29 PM.. |
NYC Bimmer259.50 |
05-12-2018, 07:26 PM | #1812 | |
Rep 1,608
Boostm3
05-12-2018, 07:44 PM | #1813 | |
I used to be conceited, now I'm perfect.
570
Rep 1,826
Drives: 2018 M3 CS
2018 M3 CS - Alpine White l l
"I used to be conceited. Now I'm perfect" |
05-12-2018, 07:57 PM | #1814 |
Rep 4,541
Weird, it should work.
Check here and make sure this setting is active: Front Electronic Module > Expert Mode > 3053 PwMaster > KOMFORTSCHLIESSUNG_FB > Aktiv If this is active then I'm not sure what else you could do. It should be working with these settings. Maybe adjusting the delay would help. Front Electronic Module > Comfort Closing Delay > No delay |
NYC Bimmer259.50 |
05-12-2018, 08:43 PM | #1815 | |
570
Rep 1,826
Drives: 2018 M3 CS
05-13-2018, 09:21 AM | #1816 |
Rep 23
I am having a couple of weird issues I think are related to some coding I've done, but can't figure out how to resolve.
Symptoms: 1) Auto high beam button does nothing any more (100% sure it used to work as normal. 2) Rear fog button no longer does anything. I coded this/modded the physical button months ago and used it several times and it worked perfectly as well. I can only think of a couple of things that have changed recently that could have any impact. Last coding update I made to my car was to change the comfort close delay to 0.5 seconds instead of 0 seconds so that my mirrors wouldn't fold every time I locked, only if I held briefly. I also tuned my car recently with BM3. I am fairly certain (99% ish) that the 2 issues above had appeared before I did the tune, though. Any ideas? Also, is it possible to download backups made with BimmerCode so that I can compare and see what was changed? It's really tough with just a date to recall what might have changed. |
Dabozo624.50 |
05-13-2018, 05:24 PM | #1817 | |
Rep 23
Per Stephan's advice, I restored my oldest backups, but that didn't fix anything. My headlights are still buggered. Only other thing I could think of that changed recently that could remotely be related is that i installed the MPE which does add some wiring to the rear fuse box, but I can't fathom how that'd be related. Please, anyone have any ideas? Headlights stuck on all the time (and the other issues) is driving me batty! |
05-13-2018, 05:53 PM | #1818 |
Rep 1,466
I thought I'd jump in here and make a comment, because there are now two people (gallahadd, and lyric911) finding issues with coding, and I'm often quoted as one of the people that had issues with Bimmercode in the past, which is true.
I think it's important to understand how the coding is happening with Bimmercode, and why backups aren't working for you, or are confusing. I'll try to contrast this with E-Sys, which works in a slightly, but important different way. First though, I'll explain the issue I was having, and what I believe to be the root cause. I got my car in November, and had BimmerCode already installed, and a vGate iCar 2 WiFi ready to do some coding pretty much as soon as I picked up the car.So, the way BimmerCode works, is to read out the data from a module, backup this data, and you then make changes to this data before loading it into the module again. If anything goes wrong with the initial reading, there is no backup to restore from. If you loose your backups, there is no backup to restore from... you're in trouble. If you mess up your coding and that change gets put into your backup, when you restore it will still be there... you're in trouble. E-Sys works differently. Within E-Sys, it's possible to generate default factory coding files for every module, as long as you have a couple of files that provide details of your vehicle, which is the very first thing that you backup and keep safe. Most of what you do with E-Sys is offline, not connected to the car, and the flashing process to load your changes to the vehicle takes literally seconds. It is more complicated, but not excessively so, and it provides you with a fail safe if things go wrong. It's also more reliable from the get go. I'm confident that if gallahadd and lyric911 were to send me a couple of files from their car created by E-Sys, even in it's current non-functioning state, I'd be able to talk them through getting things back to stock. With BimmerCode... they're stuck with having to request the dealer for help.
2018 ///M2 LCI, LBB, 6MT...
05-13-2018, 05:57 PM | #1819 |
Rep 1,466
One thing that I did early on, was to keep a record of the changes that I made through coding. I did this on Google Sheets, so that I would know what was changed from default, and I also have backup files for each module and each date in my document so that I can really easily go back to stock, or to a date, any time I want.
As I explained, in E-Sys, for going back to stock, this isn't necessary, but I do keep backups of the stock module data anyway; I'm just anal about keeping backups I guess. I thought it might be helpful to users on here to see the sort of documentation that I'm talking about, so here's a link to my real document. It's read only, because I don't want you messing with it, but feel free to take a look:
boostm3683.00 CanadianDriver98.50 |
05-13-2018, 07:55 PM | #1820 |
Rep 29
Not sure if this has been posted - but had a question and someone had posted it in another forum.
Our iDrive screens have auto-dim controls - just like iPhones, etc. If you ever are driving in overcast weather or a garage, you might notice the brighness level isn't quite 100%. To adjust brightness manually, and turn off the auto settings, go to this module in Expert Mode: HU_NBT2 - 3005 Display PIP Info - DIM_VARIANT And once in that module: - Value will be set to NEW - Simply change the value to OLD The "old" will change the iDrive display menu setting for brightness in day - AND night. The "new" setting only allows you to change the brightness level at night (when you navigate to the setting now, it says "brightness at night" or something like that). This makes a BIG difference during the daytime - no more washed out, dimmed iDrive screen. Just make sure you turn brightness to 100% in iDrive display settings (it defaults to 50% after you code). Background: http://f30.bimmerpost.com/forums/sho...php?p=20325296 |
AndrewC198910910.50 |
05-14-2018, 04:23 AM | #1821 |
2018 BMW M2
230
Rep 149
Drives: 2018 BMW M2 - Widebody
This question is for the Android app which I assume is the same with updates etc. If I get the bluetooth adapter, I'm still able to connect to bluetooth via iDrive and play my music while coding right? Also, after I code my car, do I need to keep the adapter plugged in?
MJE60678.00 |
05-14-2018, 05:03 AM | #1822 | |
Rep 874
Reading this thread has been VERY helpful. I had bought a WiFi dongle before I got my LCI M2 two months ago and was planning to use BimmerCode as soon as I took delivery. But I started reading about issues here just before receiving the car so I didn't pull the trigger on buying the App immediately, and now and I don't think I ever will. Not trying to discount the great work the developers of BimmerCode and other apps for that matter has done, but on the losing warranty risk spectrum for this car, I am being very conservative. It's crazy for me to treat my $55K+ car like a $700 iPhone that I'm jailbreaking to add a couple of features that Apple doesn't want to give me. I know the analogy is not perfect, but it has enough similarities. Of course each person will have their own risk tolerance. I will at most use the ASD harness. If I keep the car past the warranty, I may play with coding. Best of luck to gallahadd and anyone else facing a risk to their warranty after coding. I hope your dealers/BMW cooperate and reset the software for you without issues.
2018 F87 M2 | LBB | Executive | Moon Roof | Apple CarPlay [2018 F22 M240 (sold) ; 2015 F22 M235i (sold); 2006 E90 330i (sold); 1983 E30 Coupe 320i (sold)]
randyt224.50 |
05-14-2018, 07:09 AM | #1823 | |
Rep 58
05-14-2018, 08:23 AM | #1824 | ||
Rep 874
05-14-2018, 08:52 AM | #1825 | |
Rep 4,541
Not something I'm aware of that you can do. Never heard of anyone doing this.
Headunit > Expert Mode > 3005 DISPLAY_PIP_CONFIG > DIM_VARIANT > OLD |
NYC Bimmer259.50 outerbelt69.00 |
