05-15-2022, 07:10 PM | #23 |
The Seeker
13998
Rep 3,361
mikeyymonster526.00 chris7197356.00 |
05-19-2022, 07:54 AM | #26 |
The Seeker
13998
Rep 3,361
That was my first thought, but CarboTech recommends against it, and they have made their backing plate thicker to compensate.
When I called them they said that the weights (for vibration), backing plate (for noise), and any lube were purely for noise issues, which the 1521 doesn't have. They said that noise from pads was 99% the material used, and that I didn't have to worry about it. I asked about anti-seize, since BMW recommends none on the 2NH, and they said that they do recommend it (Permatex copper) on the sliding surfaces (top and bottom) and on the back plate as well as the pistons. |
05-19-2022, 12:54 PM | #27 |
Rep 231
Interesting have had mine on for 4-5 track days.
Noisy on the street when they're not cold. Looks like I only have another 2 or so left on front pads good to know about lubricant. Can't beat there price point. Can't remember how they fit in the caliper without backing plate. |
05-19-2022, 01:18 PM | #28 | |
Rep 1,078
05-21-2022, 04:43 AM | #30 |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
Nice I also ordered a set of XP10 front/rear for the track and 1521s for the street.
How do you like them? Im coming from Ferodo 3.12s / 1.11s for the track and 2500s for the street
-2021 M2C, HS, 6MT
-AST 5100, AP Racing 9660, BMW-788M, RF-GT4, BW-TA5R, APR GT 250 Wing & Front Splitter -TMS Diffuser, TMS F80 Skid Plate, HEX Armor PPF, CAN-Checked Data Logger, RaceBox -Recaro Pole Position , 2kBody Half Cage, Pinnacle Motorsports Half Cage (On order), CAE Shifter -Remus Race + BR EL Mid |
05-21-2022, 05:18 AM | #31 |
Rep 1,078
Where is the best place to order these pads? From Carbotech directly?
05-21-2022, 05:24 AM | #32 |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
Thats what I did. I forgot which site I was going to initially order from, but had a question so I just gave them a call.
-2021 M2C, HS, 6MT
mikeyymonster526.00 |
05-21-2022, 01:11 PM | #33 |
Rep 231
First track pads so don't have a reference. Definatly up to the task and wear well. Front caliper such a PITA to remove and have short drive to work so leave them on. Noisy once warmed up on street
Bimmerworld I where I got mine |
05-21-2022, 02:27 PM | #34 |
The Seeker
13998
Rep 3,361
06-12-2022, 10:57 PM | #37 |
Rep 1,078
I've had about a week to test the 1521's. I had a shop swap the brakes for me and they didn't transfer anything from the old pads or used any lubrication. Brake pedal feel is slightly reduced, but after a few days I don't really notice a difference. I did bed the pads the day of install and experienced horrendous squeal a few days after install, but that hasn't happened again. They do squeal a bit from time to time, but not as bad as oem pads. I'm still testing the brake dust, but here is a picture after 7 days of driving. I drive about 10 miles a day. Im not sure if the lower dust will allow you to last weeks without washing, but it probably saves a few days. I'll post again in 7 days since my only comparison is from oem pads after 14 days.
chris7197356.00 |
06-14-2022, 09:32 AM | #38 |
Rep 7,315
Did you do anything to the rotors before you swapped the pads in?
Your pic is interesting because the Carbotech dust is usually referred to as gray but there still appears to be some old OEM pad dust around with the cinnamon color. I used to think it was partially the rotor or rust but I sprayed the wheel with Sonax that turns purple in the presence of iron and the dust is almost completely non-ferrous. That makes sense because I believe BMW is now specifying NAO material to meet regulatory requirements. All new BMWs have this brown dust, used to be black on my Z4M. |
06-14-2022, 09:41 AM | #39 | ||
The Seeker
13998
Rep 3,361
chris7197356.00 |
06-14-2022, 01:40 PM | #40 | |||
Rep 1,078
///MPhatic13997.50 |
06-17-2022, 04:16 PM | #41 |
Rep 1,644
The squeaking is the pad to metal contact with the rotor. At that point it's scraped off any layer of bedded pad material which is not ideal, but expected for track pads as they need to heat up substantially to bed and grip correctly.
06-17-2022, 05:09 PM | #42 | |
Rep 1,078
chris7197356.00 |
06-17-2022, 05:12 PM | #43 |
Rep 7,315
Carbotech recommends you resurface the rotors if any other pad has been used, but I really don't know how important that is if you've been using the OEM pads that primarily rely on abrasive friction anyway. Given enough time, I would assume any old pad material would be worn away.
06-17-2022, 07:08 PM | #44 | |
The Seeker
13998
Rep 3,361
chris7197356.00 |
