M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > What Winter-tire psi do you run?
      12-02-2019, 10:01 AM   #1
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
I'll be putting my Winter set on soon and wanted to know what pressures you guys are running. For Summer I run 35 psi, and was going to run 32 psi for Winter, but doing a quick google search I'm finding that some manufacturers are recommending to run higher than standard pressure in Winter, not lower.
Once, years ago, my TL was wearing its Winter set and the temps got up to 65° one day before I took trip to STL (300 mile round trip). Upon returning I found that the tires were worn badly in the middle because the combination of warmer temps, steady speed on the Interstate (extra heat in the tires), and super soft compound Winter tires basically destroyed them. So now I'm much more cautious.
So what do you run?
      12-02-2019, 11:07 AM   #2
Anthony1s
756
Drives: 2018 Mineral Grey M2
So what do you run?
I inflate mine to 40psi when I first put them on, as winter progresses and the temps get colder, the tire pressure lowers, so they are at 35psi now.
But I think that's why mfgs say to run a higher pressure in winter. Because ppl generally only check their psi when they first put their tires on, then the colder temps the air will condense and lower your psi.
VisualEcho6633.50
x233284.00
      12-02-2019, 11:19 AM   #3
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
I think that's probably true. My garage isn't heated, but it's attached, and when it's 25° outside it's 52° in my garage. So setting them to 32° will ultimately result in 30° or below once I leave.
      12-22-2019, 11:32 AM   #4
tokki
204
Drives: M2C
I run mine at 30psi. Mostly city/short commuting. If I were highway commuting more, I'd air up to about 32. Make sure you set and measure the pressure on a realistically cold day so that pressure stay closer to where you want it.
2019 M2C Sunset Orange 6MT
Eventuri Intakes
Eisenmann Valved Full Exhaust
VisualEcho6633.50
      12-22-2019, 07:26 PM   #5
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro SS 1LE
I stick to 35 psi to maintain stiffer sidewall for high speed stability. If you don't drive too fast lower makes some sense, but I still hit 160mph frequently even in the winter. At lower pressures the winter tires get a bit floaty and un-precise.
2017 BMW M2 German Spec
6MT, Driver's Package
--> SOLD
2018 Camaro SS 1LE. Because race car!
"Redline a day keeps the mechanics away"
VisualEcho6633.50
