05-24-2019, 10:58 AM | #134 |
Rep 5,334
Is this car a 6MT or DCT?
When it let go, was the car in a taller gear, the rpms below 4,000rpm, and the throttle mashed? I have to wonder if the car had a super knock event and due to the increased power/boost and heat of these flash tunes, the DME safeguards simply can't keep up in a track situation, especially if you're not keeping the rpms high and the motor out of a high load situation.
05-24-2019, 03:56 PM | #135 | |
Rep 1,823
2017 BMW M2 German Spec
05-28-2019, 12:59 PM | #137 |
Rep 660
Good to know - I usually change every 10k (on the clock, even if the estimation has 1-2k left) and my service advisor has always let me. I only track 1-2 times a year. I feel that perhaps 10k is a bit long (might start doing 5k if track a lot more), but like you said, synthetics are really good these days.
05-29-2019, 01:30 PM | #138 | |
oooooo
53
Rep 320
2011 135i - Gone but not forgotten | 2017 M2 - Powering out of a corner near you!
eeyang92318.50 |
05-29-2019, 01:50 PM | #139 | |
844
Rep 1,962
Fully synthetic means it ages really well, and it doesn't break down if you roast it on a hot day at the track. It is designed to collect wear and combustion products and carry them back to the sump so that the oil filter can remove them. Change the filter more often if you're worried. |
05-29-2019, 01:59 PM | #140 |
844
Rep 1,962
Separately, noting the number of threads highlighting the quality or lack thereof of US pump gas (sulphur content, AKI rating), is this fixation with engine oil turning to wax and/or paraffin in a matter of days followed by the cam lobes/followers melting indicative of the 'oil' that used to be available in the US? The climate variations across a continent will mean the one size does not fit all, but still...
Last edited by M Fifty; 08-28-2019 at 03:22 AM.. Reason: spool Chucker pro bells |
05-29-2019, 11:36 PM | #141 |
Rep 130
this is why I never tune any of my cars, very dangerous for engine
eatingpizzainthef87rules253.00 |
05-30-2019, 01:56 AM | #142 | |
Luxury at the redline :)
9099
Rep 7,563
However, you can't get blood from a stone and same principle applies to the N55 in the M2, which is already tapped out to edge of its efficiency and with the little safety margin BMW left back in the motor, folks are attempting to exploit it with flash tunes, which would eventually lead to situations like this. Not just the M2, a couple of folks on the M235i section reported blowing their motor and turbo as a result of high-output tuning. If you really a tunable M2, the obvious option is a M2C which has the more flexible S55 motor. http://mywikimotors.com/n55b30/ |
05-30-2019, 07:44 AM | #143 | |
Rep 2,999
Do you have more information about how the S55 in the M2C is maxed at 400 HP but can do more in the M3/M4? |
05-30-2019, 08:57 AM | #144 | ||
9099
Rep 7,563
The S55 in any vehicle are all the same and is capable of way more than 400hp, as oppose to the N55. Not sure of what exactly the soft max on that motor is but I would guess somewhere around 500hp or so.. |
omasou2079.50 |
05-30-2019, 09:30 AM | #145 | |||
Rep 2,999
05-30-2019, 09:40 AM | #146 | ||||
9099
Rep 7,563
BMW has historically known to underrated their turbo motors, especially M variants but the N55 was never really intended to be an official M motor, it's a souped-up N55 with S55 pistons and oil pump, everything else is a standard fare. Pages 23 - 34 below has more details: https://www.bimmerpost.com/goodiesfo...l-training.pdf |
omasou2079.50 |
05-30-2019, 03:32 PM | #147 |
Rep 660
I thought about tuning, but seeing how much work is required to extract such small gains, I don't know if it's worth the risk. Maybe upgraded intake, intercooler and DP would be the most I would do since it isn't increasing the stress (much) on the engine.
To be honest, if I were to tune, I may just buy a used 2019 (2020?) supra in a few years... the B58 seems like an extremely promising platform for tuning. And it should be more "reliable" because Toyota literally annoyed BMW by inspecting/testing each component in the engine so thoroughly. Plus the iDrive will be familiar lmao. EDIT: Or maybe the next-gen M3/M2 if the Pure model doesn't feel too neutered and the S58 doesn't sound terrible (it'll probably sound similar to the S55 though). The S58 should be an amazing platform if the B58 is already that good. |
08-22-2019, 07:05 PM | #148 |
Rep 73
After a long few months I finally got the car back running. Wanted to rebuild with forged pistons but the companies either wanted too much or was too sketchy and I was afraid of bad fitment/complications. Initially ordered from Keystone Auto but they got the M240i and M2 motor mixed up which wasted me a bunch of time sending it back. Lesson learned: to always ask for VIN to double check. Ended up with an option Omasou brought up on EBay. Car-part.com was also a useful search engine for finding options as well but some didn't ship to where I needed. Did try to bring it back to dealership for warranty, they ultimately couldn't figure out the reason and simply denied the warranty due to mods.
***They figured it out from tracing my account on bimmerpost, so a word of warning to others in the future to be careful of what you post here*** My guess at the end of all this is that BM3 tune did not have a lot of head room and when coupled with really sticky tires it lead to increase in high load low RPM phenomenon that lead to super knocking. GG |
08-22-2019, 08:12 PM | #149 | |
Rep 361
08-22-2019, 08:14 PM | #150 |
Rep 1,899
08-27-2019, 05:26 PM | #151 |
Rep 228
Just discovered this thread and read every post on it. What i don't understand is why people get so hostile bashing the OP about what he did wrong and how ignorant he is. He simply made a mistake and came asking for help. No need to bash on him as he is already not feeling well.
Regardless of how smart some of you are, the fact is we ALL learned something from his mistake. Even the "pros" that's been posting on here about their knowledge of this stuff has learned something new. I for sure did. I was full on committed to tuning. I'm not that knowledgeable about this stuff i'll be frank. I would have done exactly what OP has done in terms of mods and how he approached this whole thing about his track duties. Until this thread I thought a nice conservative tune with cooling mods and DP would have been sufficient. Now i have this plethora of knowledge that will protect my car and my investment. All thanks to this thread! So why are we being so hostile?! OP, thanks for all of this. I'm sorry you had to go thru this. But because of your mistake I learned something valuable. I'm sure a lot of other people did as well. I'm glad you're back up and running and hope you enjoy your car in the future with what you've learned from this. In hindsight this experience will be valuable later down the road when you buy much more expensive and fast cars. |
08-27-2019, 05:58 PM | #152 |
Rep 73
likely by association on previous posts and location or they pay to get access to personal information from the forum servers. I am assuming they would it would be more than just speculations from posts if they are willing to use it directly to deny claims.
08-27-2019, 06:19 PM | #153 | |
Rep 73
Also for the angry people on the internet part... lol It's the internet, people have to look for validation for there own choices or opinions one way or another, can't blame them. Logic is not always a requirement here. No m2 owner wants to believe that a mild build/tune could push the car to run so poorly but here we are. |
