08-24-2023, 09:17 AM | #419 |
Rep 3,696
First session: https://bootmod3.net/log?id=64e7625ed10b4303a95c0ae6
Ambient not too hot and a wet track, so about 5sec off pace. But, check out how much closer together oil & coolant temps are vs my other track logs. Open track day and it’ll dry out, so more to come. |
F87source7253.50 |
08-24-2023, 10:30 AM | #420 |
Rep 3,696
Second session: https://bootmod3.net/log?id=64e7740bd10b430714656de8
Dry session with new PB at NJMP Thunderbolt (1:29.4). Ambient still not too hot, check out how close oil & coolant temps are together. Have never seen that before, oil usually skyrockets and then coolant. Coolant still getting above 250F tho, and power was being pulled. The car didn’t go into meltdown tho and cooled off quickly. Altho, prob still need more coolant temp reduction for hot track days. Overall, much better, tho. |
08-24-2023, 11:02 AM | #421 | ||
Rep 4,146
WOW - this is an improvement: Quote:
48F vs 75-77F Coolant 233F vs 251F Oil 251F vs 253F Maximum Speed 135mph vs 141mph
Mods: Yes.
F87source7253.50 |
08-24-2023, 11:06 AM | #422 |
Rep 3,696
Third session: https://bootmod3.net/log?id=64e77f05c090c66295afc088
A short one, higher ambient, coolant still getting too high, but as least the oil temps are staying in check and keeping coolant temps from running away. |
08-24-2023, 12:20 PM | #424 |
Rep 3,696
08-24-2023, 02:28 PM | #425 | |
Rep 4,146
What's the acceptable cold weather range for your oil?
Mods: Yes.
08-24-2023, 05:16 PM | #426 |
Rep 3,696
Last two logs confirming similar behavior:
https://bootmod3.net/log?id=64e79931d10b430714658c01 https://bootmod3.net/log?id=64e7c187c090c66632f032b3 Overall, best track day I’ve had in a while. More 1:29s with non-traffic optimal of 1:28s. That’s fast for a M2 on Thunderbolt! The guys in ZL1’s and Z06’s were shocked I was passing them. Altho, my added power without overheating and my knowledge of that track helped a decent bit. Those cars should be faster. Still would like to determine best option to get coolant temps down. Still in my head that a shorter IC and more clean air to the radiator would help. |
F87source7253.50 |
08-24-2023, 06:39 PM | #427 | |
Rep 7,431
ZM22813.50 |
08-25-2023, 02:41 PM | #429 |
Rep 4,146
I did some reading - I don't think that heat exhanger is really needed unless you're in absolute fridgid temps. I think 0w and 5w oils will still flow and protect even as low as 0F
edycol
Mods: Yes.
08-25-2023, 03:12 PM | #430 |
Rep 3,696
Part of me wonders if the exchanger is removed, would coolant temps stay lower for a bit but then actually go higher than oil temps bc there’s no exchanger in place to balance thermal load.
At this point I don’t think we know if coolant temps are going too high bc there’s not enough coolant loop capacity/airflow, or if it’s bc oil temps routinely go higher than 240F and the exchanger is dragging coolant temps up. That said, here’s two examples of previous track logs when I was running the CSF radiator and oil cooler, one with ambient similar to yesterday’s track day and another from last summer with higher ambient, oil, and coolant temps. You’ll note that oil and coolant temps are clearly not connected as they are now, showing a big improvement bn the CSF and do88 oil coolers. https://bootmod3.net/log?id=63553febae729b63d8d8bc16 https://bootmod3.net/log?id=62f00755c090c6b3130e6c5d Altho, my interpretation bn these logs and my logs from yesterday is that we now have enough oil cooling capacity on the car, so much so that it’s also absorbing heat from the coolant loop as coolant temps get up to 250F and not allowing them to go higher, compared to when I used to see both oil & coolant temps go >270F & >255F with the CSF hardware. I think if we remove the exchanger, peak oil temps would stay the same or come down a little, and peak coolant temps would go up. Last edited by ZM2; 08-25-2023 at 03:36 PM.. |
F87source7253.50 |
08-25-2023, 03:41 PM | #431 | |
Rep 7,431
08-25-2023, 03:51 PM | #432 | |
Rep 3,696
Logs from last year (CSF) https://bootmod3.net/log?id=63553febae729b63d8d8bc16 https://bootmod3.net/log?id=62f00755c090c6b3130e6c5d Log from yesterday (do88) https://bootmod3.net/log?id=64e7c187c090c66632f032b3 What I’m also seeing is how much more spikey coolant temps are now vs oil. When I’m back on the gas, coolant temps jump 20F and hit power pulling levels while oil only moves 5-10F and is comfortable at 250F. That tells me there’s not enough coolant system capacity or airflow, and the exchanger is stopping coolant temps from running away even worse like they used to, before the recent oil cooling system improvements. Last edited by ZM2; 08-25-2023 at 04:10 PM.. |
F87source7253.50 |
08-26-2023, 11:26 AM | #433 | |
Rep 1,485
It is a liability in this case too. There is too much heat here. Gaskets will fail, mix oil and coolant etc. I do not know what modifications were done on cooling system, but the coolant temperature is too high. As for protection you mentioned, 0W and 5W do not have anything with exchangers. That si cold start. 5W will do good until -30f, I started X5 35d at -42f having Valvoline 5W40 in the engine. 0W is obviously better choice in those temperatures. Protection depends on HTHS. |
08-26-2023, 11:30 AM | #434 | |
Rep 1,485
08-26-2023, 11:48 AM | #435 |
Rep 3,696
Current setup and cooling mods:
Power - 470whp BM3 Stg 2++ Multimap with E50 TTE460 turbo Dorch Stg 1 HPFP Turbosmart plumb back BOV HJS 300-cell downpipe Akrapovic Exhaust MST v2 inlet 3.5-bar TMAP Stock airbox & filter Cooling do88 radiator do88 aux radiator do88 oil cooler BMS oil cooler valve Stock DCT cooler with larger M2 CSR DCT oil pan Evo3 IC Suvneer GTS vented hood BM3 MaxCool setting E39 in line additional coolant pump (with F87source help) E50 fuel 10w-40 300V (new formulation) 100% water + wetter in the summer Good to hear the exchanger isn’t needed, but I still think you all are thinking too much about what the exchanger does on the street vs what is happening in my logs on track at peak temps. No doubt the coolant is following oil temps as it warms up, and could be lower in the beginning of the stint without the exchanger. But seeing how quick coolant temps jump under WOT tells me the extra headroom from the lower coolant starting temps might get you an extra lap? I’m more concerned about peak temp management, and now that oil temps are in check it’s clear to me in the latest do88 logs vs last year with CSF coolers that the cooling bottleneck is on the coolant side and the exchanger is actually helping keep coolant temps from rising above 250F by letting the oil side absorb excess heat from the coolant. I need you guys to read thru my comments above and review the logs in detail and throw out the traditional thoughts about what the exchanger does during warm up, and instead focus on peak temp dynamics and management, so we can all decide if the coolant system efficiency (capacity & airflow) or the exchanger is more of the issue. Last edited by ZM2; 08-26-2023 at 12:21 PM.. |
08-26-2023, 12:19 PM | #436 | |
Rep 1,485
But, oil doesn’t dissipate heat as fast as water. So, effects of cooler oil is questionable in heat exchanger. You could run open system or lower temperature thermostat. But, that is band aid. The cooling system is not appropriate for heat your engine makes. By how much those coolers increased capacity of coolant? |
F87source7253.50 |
08-26-2023, 12:33 PM | #437 | |
Rep 3,696
https://www.do88performance.com/en/a...-aluminum.html https://www.do88performance.com/en/a...-aluminum.html So, if we can’t increase capacity, that pretty much leaves: -Removing the exchanger (if it’ll actually help and not hurt peak coolant temps) -Improving airflow to the radiator with a shorter & less thick IC -Water injection to lower combustion & engine temps Seems like a roll of the dice at this point to know which will help the most. |
08-26-2023, 01:27 PM | #438 | |
Rep 1,485
08-26-2023, 01:38 PM | #439 | |
Rep 557
- turbo blanket - maybe insulating the coolant line on the hot side of the block?? |
08-26-2023, 08:21 PM | #440 | |
Rep 7,431
edycol1501.50 |
