07-26-2023, 02:20 PM | #67 | |
Rep 8,972
Pilot Sport Cup 2 standard sizes are unstickable, even on stage 2 BM3 they don't spin up, Maybe in 1st gear if you provoke it. Unbelievable grip and feel. Cup 2 in summer, winters in winter if you drive it in winter. |
07-26-2023, 02:24 PM | #68 | |
Rep 81
07-26-2023, 04:23 PM | #69 | |
Rep 1,348
When you try a tire with a minimum of grip you will be amazed. |
07-27-2023, 01:41 AM | #70 | |
Rep 8,972
As you already run winters then it makes sense to me to get ultra high perf summers like cup 2, yes they cost more but i suppose depends on your mileage etc. |
07-27-2023, 01:45 AM | #71 | |
Rep 8,972
I was just saying in the search for extra grip putting crazy wide tyres on just spoils the poise and feel of the car. Cup 2 at standard sizes make an unbelievable difference to traction and improves the feel and drive of the car without extra tyre width. If you're just thinking for track though then cup2 will be expensive. |
07-27-2023, 09:47 AM | #72 | |
Rep 81
Could you provide specific reasons for recommending the Cup 2 tires over the PS4s? My M2C has 30k miles, and I primarily use it for daily driving in the NYC area, where road conditions are less than ideal, and wet weather is common. For a Stage 1 tune, or at the very least Stage 0 (M4 GTS Map)--What tire sizes would you recommend? |
07-27-2023, 10:15 AM | #73 | |
4697
Rep 2,548
Wheel size is going to dictate the tires as well. The F87 can be a bit tough at times to fit. What size wheels planning to run? |
chris7197342.50 Hank Scorpio8.00 |
07-27-2023, 10:16 AM | #74 |
Rep 7,301
I would probably not run Cup 2 on the street unless you are really unhappy with your current dry grip. The reduction in hydroplaning resistance is not really great for a daily driver.
Hank Scorpio8.00 OG Shark4697.00 |
07-27-2023, 10:18 AM | #75 | |
Rep 81
OEM M2C wheels So, I'm thinking it's 19" |
07-27-2023, 12:55 PM | #76 | |
Rep 8,972
Also michelin chased comfort and wet ratings with the ps4s, making them more of an "all rounder" not quite as good as previous pss in the dry. Softer sidewalls too. For track tyres you could go more extreme than cup2 but they are best uhp for road use. And are fully road legal. Remember they came standard on several bmws, wheel sets and porsches etc. For your non-track DD routine just stick with standard sizes, do you envisage hooning around full throttle launches with your tune? If not don't worry...regular ps4s will be great. Last edited by doughboy; 07-27-2023 at 01:07 PM.. |
07-28-2023, 09:05 AM | #77 |
Rep 3,843
If you live in an arid temperate climate then the cup2s can be used all year. Having run the MPS4S and Cup2 240 Connect, the 4S has softer sidewalls which forced me to use too much air pressure for twistie driving. I just couldn't get it right for feel and grip. I switched to the Cup2 and problem solved. The stiffer sidewalls allowed me to use the proper air pressure and the twisties are a joy. I tend to value a fun playful car over a tire monster. Huge tires can cause the car to feel heavy and reduce the feeling of tossability.
If I were just commuting and didn't care about the tires rolling over in hard cornering then I'd probably get the 4S but I want my M to feel crisp and stick as much as possible while keeping its playful nature. |
chris7197342.50 |
07-28-2023, 09:38 AM | #78 | |
Rep 8,972
I keep cup 2 on all year, but the car is in the garage from late Oct-March so I don't need winters. It's not just outright grip (which is remarkable) but the way they change feel of the whole car, they way it turns and moves over bumps and crests etc whilst remaining super sharp, quiet, compliant and civilised the whole time. Even on stage 2 BM3 I struggle to unstick the rears in 1st or 2nd unless provoked when warm, it just goes. Whereas PSS would spin up in 3rd. |
07-28-2023, 10:51 AM | #79 |
Rep 3,843
Yeah, I actually find the Cup2 240 quite civilized. They ride fine since I can use a lower air pressure. I start out at 31 cold and end up at about 34 warm. Of course a hot day In the mountain twisties and I have to let some air out. I guess I'm off topic ...
07-30-2023, 07:08 PM | #80 | |
Rep 424
Also personally am not a fan of cup 2s. Just go with ps4s, it’ll last 4x as long and have more grip that cup 2s have cold (cup 2s you will rarely ever get hot enough to grip enough on the street!) |
07-30-2023, 07:41 PM | #81 |
Rep 4,686
The 240 has a reasonably low operating temp, but I agree that it's unlikely to hit the max grip zone unless they are being worked or a lot of braking to get heat into the wheels. 80F to 180F is their "green zone" for the track connect sensors. I run them 4 seasons in NC. In my second set with the first set lasting a little over 17k miles. A couple track days on them too. I'm on my second set.
07-31-2023, 01:37 PM | #83 |
Rep 8,972
Cup2s are primarily designed as a fast road tyre, they get warm at road speeds unlike track specific tyres.
After a good run out mine are hot to the touch, much warmer than any pss / ps4s 3000 miles so far and no perceptible wear. |
07-31-2023, 04:01 PM | #84 |
Rep 424
Wow, maybe they improved a lot since I used the 240s last year. I went through mine after about 6k miles. The car was awd and high powered than our cars so I’m sure it didn’t help
08-03-2023, 06:31 AM | #86 |
Rep 4,686
I don't believe BMW developed star marked 180 treadwear tire?
08-03-2023, 10:30 AM | #87 |
Rep 8,972
All 4 are star oe sizes and 180.
It took me a while to track them down in non connect versions. I never looked at treadwear rating though. But strange nowhere on the tyre data sheet or even on the Michelin website tells you the treadwear index. Sorry a bit dirty, it's way due a wash.... Last edited by doughboy; 08-03-2023 at 11:12 AM.. |
08-03-2023, 12:19 PM | #88 | |
Rep 4,686
