07-21-2022, 01:30 PM | #2 |
Rep 35
Drives: LSB E46 M3, AW F87 M2, Model 3
That does not look right. The sensor should be flushed to the rim. These images do not have a good angle but I hope you get the idea.
I have a white f87 m2 and a blue e46 m3
07-21-2022, 01:37 PM | #3 | |
Rep 346
I actually message TPMS direct and they told me it's NOT supposed to touch the surface of the rim since every wheels has different barrel. |
riko///m241.00 ///MPhatic14152.00 |
08-15-2022, 04:59 AM | #5 |
Rep 1,337
Not supposed to touch the barrel however it should generally run parallel to the barrel.
I think you can adjust the angle on those.
M2RAW121.00 |
09-12-2022, 10:39 AM | #6 |
Rep 753
This post seems to have an appropriate title for my TPMS related question. I am looking at OEM TPMS sensors for the M2 (2018, LCI). Huf appears to be around $44 a piece and VDO around $55 a piece.
Then I see what riko///m2 posted and that is available on Amazon for $25 a piece. Riko, did you have any issues with this sensor? Did the installer need to do any "programming" to make it work with your M2? TIA. https://www.amazon.com/BH-SENS-315MH.../dp/B08LLGB5CZ |
09-12-2022, 05:32 PM | #7 | |
Rep 1,337
2. It says "must be programmed prior to install" So based on point 2 it needs to programmed. The programming units are not cheap so either your fitter needs the tool or better off buying a pre programmed set. I bought a set HUF's pre programmed a while ago, no issues.
pal435.50 |
09-12-2022, 08:51 PM | #8 |
Rep 753
Thanks. Looks like only one of the pre-programmed units from Huf (https://www.amazon.com/gp/product/B0...BCDVBKB7&psc=1) are available on Amazon; and its back ordered even on Apex Race Parts (https://www.apexraceparts.com/store/...ms-sensor.html).
I'll probably order up the VDO (OE manufacturer) one from FCP Euro. https://www.fcpeuro.com/products/bmw...90#description |
09-12-2022, 08:59 PM | #9 | |
Rep 346
09-12-2022, 09:58 PM | #10 | ||
Rep 346
pal435.50 |
09-12-2022, 10:53 PM | #11 | |
Rep 1,337
https://www.ebay.com.au/itm/392202068020
pal435.50 |
12-17-2022, 02:02 PM | #12 | |
Rep 35
I purchased the sensors from tpms dot com along with 8mm valve stems (for the BBS LM's). It's direct fit, no programming done. I spent a bit more, and it's working good to date. Beware of fake sensors. They are out there.
pal435.50 |
