M2 Technical Topics > Cosmetic Modifications > 55w HID upgrade?
      07-18-2018, 11:30 PM   #1
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
55w HID upgrade?
Anybody attempted upgrading the oem bulbs and ballasts from 35w to 55w?
      07-19-2018, 09:34 PM   #2
ipeefreely
Drives: 2023 BMW XM, 2024 M2, 2022 GT3
why...? Are the stock headlights not sufficient?
      07-19-2018, 09:42 PM   #3
atlas
383
I thought the headlights are LED?
      07-20-2018, 01:41 AM   #4
AndrewC1989
They are, I was just curious. Always looking for new projects.
All Pre-LCI cars in the USA (MY 16+17) have Adaptive Xenons.
LCI/LED didn't arrive here till MY 18. Might've been different in Australia.
      07-20-2018, 03:23 AM   #5
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Can you buy reliable [Osram/Philips] 50w+ D1S bulbs ?
~ 6:45mins into YT vid shows a delta between 35w v 50w retrofitted HID ie separate ballasts as believe bulbs are the same, its the ballast that's swapped for higher wattage.
Current '22 X3M LCI..
      07-20-2018, 08:13 AM   #6
AndrewC1989
Already saw that video coincidentally, lol.
Bulbs need to be changed as well AFAIK.
Just need to find a compatible kit (something like this):
https://headlightrevolution.com/star...-000k-hid-kit/
Main reason I'm asking about it here is I need to know if a mod like this is plug and play or if I need to code something to accommodate for the voltage changes (so I don't melt anything or get a bunch of warnings/lights etc.)
      07-20-2018, 10:08 AM   #7
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
You'd need to know 2 things from the supplier:-
- Is the Starr 55w ballast true PnP into OEM harness ? ie no wire splicing or connector changeovers ?
- Once fitted, does canbus need coding to amend any parameters and or remove any errors ?
      07-23-2018, 12:15 PM   #8
tenkies
Drives: 2017 M2 LBB 6MT
I did a similar swap to my S2000 when the OEM ballast crapped out on me. Most kits are not plug and play and usually require a separate digital ballast/igniter to accommodate for the larger initial power draw. But I must say the 55w bulbs lit up the streets much better.
I bought my kit from:
http://retro-solutions.com/
I am in no way affiliated with the company
