BMW M2 Forum > BMW M2 Discussions > LCI DSC Off
      10-20-2019, 12:45 AM   #1
O Haiii
Drives: Toyota Tercel
LCI DSC Off
Hello,
I have an LCI. When i hold down the traction off button, it goes to DSC off. What driving profile is DSC off mode? As in throttle response, oil cooling (comfort mode doesnt cool the oil as well as the other modes), steering, sound, gear changes, etc.
Is it equivalent to sport+ mode? sport? Judging from basic feel it feels peppier than confort or traction mode, but curious as to what mode it's equivalent to.
Thanks in advance!
      10-20-2019, 02:08 AM   #2
akkando
akkando's Avatar
5862
Originally Posted by O Haiii View Post
Hello,
Thanks in advance!
sport throttle. Inside the manual you'll find a chart.
      10-20-2019, 09:20 AM   #3
gandapanda
56
Drives: 18 M2 & 19 Sentra
It's similar to Sport but with no auto rev match and no stability control. There's a chart (as mentioned above) that shows you all the assist levels by drive mode.
      10-21-2019, 07:30 AM   #4
GasBurnlife(landapanda)
Traction control and stability are completely off, so be careful in the corner a getting in the gas, or the rear will come around on you.
      10-21-2019, 09:45 AM   #5
CTSean
Drives: LCI BSM MT M2
I don't know if there are different versions of the manual out there, but I can't find said chart in my LCI manual, but it is available here https://f87.bimmerpost.com/forums/sh....php?t=1206958 just scroll down a bit
      11-02-2019, 08:56 PM   #6
Hoverdog
It's not how fast you go, it's how you go fast.
Hoverdog's Avatar
Drives: m2 Black Shadow
DCS off is my favorite mode. It's the first button I push after buckling up. Drove all of last winter with it off and had no problem, even in the rain. I think the limited slip diff helps a great deal. The fact that it turns off rev matching is a plus.
      11-03-2019, 03:29 AM   #7
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro SS 1LE
I do the same thing. Click the belt and push and hold traction button to get into DSC off. I love the engine note and the burbles on decel, plus like you said I get to shift on my own, match revs on my own and slide around as I please with no annoying nannies.
One thing I love about this mode is a very loud POP after this scenario. Once the engine is up to temp and I floor it in second to about 5000rpm, then let off abruptly. Very loud shotgun blast out the exhaust. Every time. Love it in tunnels.
kingikra121.50
      11-04-2019, 03:35 PM   #8
Mosely
Mosely's Avatar
593
Drives: '18 M2 | '20 X5 | '07 E92
Just an FYI, the car warms up faster in Comfort and Traction mode than it will in Sport/Sport Plus/DSC OFF. The cooling system works overtime in the latter modes, so if you turn it on right when you get in the car, you will spend more time trying to get the engine up to temp. You can verify with any of the OBD dongles and one of the apps, get the car hot and then turn on Sport plus and you can watch temps drop.
IG Photo Gallery:
instagram.com/dr_m2sko/
5.M0NSTER3353.50
smknjoe234.00
///M TOWN15930.50
      11-05-2019, 08:02 AM   #9
5.M0NSTER
5.M0NSTER's Avatar
Good point and thanks for the tip. I remember seeing threads on this, and if I remember the data showed better cooling in Sport/Sport+ but not in DSC off. Or am I not remembering correctly?
2017 BMW M2 German Spec
6MT, Driver's Package
--> SOLD
2018 Camaro SS 1LE. Because race car!
"Redline a day keeps the mechanics away"
      11-05-2019, 02:07 PM   #10
eeyang92
Drives: LBB M2 LCI 6MT
DSC OFF is basically sport mode with no traction/stability control.
Btw, has anyone ever proven sport/sport+ mode take longer to get up to temp? It is true comfort temps get higher eventually because the target temp is higher for efficiency, but there's no reason why BMW couldn't make sport/sport+ rise to the (lower) target temp quickly then hold it there.
      11-05-2019, 03:18 PM   #11
5.M0NSTER
5.M0NSTER's Avatar
Here is the thread I was thinking about.
Mosely is correct and many thanks to landapanda for getting measurements in post #41
https://f87.bimmerpost.com/forums/sh...1513164&page=2
--> SOLD
Mosely592.50
      11-08-2019, 12:30 PM   #12
CTSean
No idea if it's been proven, but anecdotally I can say if I drive in comfort, my temp gauge gets up to the 205 mark (the major mark between 160 and 250) at an earlier point on my regular driving routes than if I switch immediately to sport.
      11-12-2019, 06:43 PM   #13
Hoverdog
Hoverdog's Avatar
Yup, checked the numbers on my bimmerlink app and the comfort mode is about 25 degrees hotter on the highway (205 vs about 180 in the others). Temperatures in MDM mode is the same as comfort.
Interestingly, oil temperature seems unaffected. To me, oil temp is the most important because you want it to get hot enough to boil off the water that condensates overnight. If you don't, it will mix with the combustion by-products and turn into an acid that eats into your metal bits. BMW also tends to use high viscosity oils that require proper warm up.
I feel safe using DSC-off mode Knowing the oil will warm up as normal.
I don't know if the sport modes make the engine take longer to warm up but I would think that the difference is negligible, especially if you have a long commute. It is likely the thermostat cause the engine to warm up the same in all modes and the computer adjusts coolant flow to change the peak temperature after warm-up. Anyone know better?
      11-12-2019, 11:54 PM   #14
MetalMK
229
Drives: BMW
Interesting numbers. If I drive in comfort my oil temperature would be at 235 to 240, if I drive in sport it would be at 205 to 220f, depends on the distance.
