10-23-2019, 11:19 AM | #111 |
Rep 1,823
I find it difficult to shift fast. I find I need to pause a fraction of a second after the clutch pedal hits the floor to pull of a smooth shift.
I never notice this at the track, because I make sure to have the clutch all the way down and I’m deliberate to make sure I’m hitting the next gear. But on the street in DSC off when I’m just cruising I notice it’s easy to let the rpm drop a bit too much so you get a bit of a jerk on clutch release. Then when I’m joining around I have to slow my shifts down. Otherwise I will get grind on 1-2 shift. |
10-23-2019, 11:54 AM | #112 | |
Rep 1,466
In this thread, about the removal of the CDV, I talked about my thoughts on the effect of removing the CDV, and I think they're relevant to this thread. My comments are copied below, but the thread is worth reading:
2018 ///M2 LCI, LBB, 6MT...
VisualEcho6632.00 |
10-23-2019, 12:01 PM | #113 |
Rep 1,466
For the record, I initially had the Burger clutch stop, and found that this improved the long throw a lot, making shifts more comfortable.
I then did the CDV delete and this improved the smoothness of shifting a lot, particularly with rev-match disabled. Finally, I added the Ultimate Clutch Pedal, and this does make a difference, but I wouldn't recommend spending the money... (sorry to the manufacturer). Contrary to what others have said, I felt that moving the spring tension to anything other than the stock position actually made the clutch feel less linear, and the shorter throw makes the bite point smaller in the throw, and therefore slightly harder to control in stop / start traffic. I've got used to the UCP now, and with the spring in the stock position it's fine, so I'm leaving it in place. My point is simply that it's not worth the money because the biggest benefits come from the CDV removal, and the clutch stop. Combined those two cost less than $30 if you have the tools, and less than $100 if you don't.
VisualEcho6632.00 |
10-23-2019, 03:16 PM | #114 | |
Rep 2,505
10-23-2019, 03:49 PM | #115 | |
Rep 1,466
Pressure bleeding (must be with an auto refilling system) from the top is the BMW suggested way in ISTA+, and I've successfully done it on my own by simply refilling the reservoir after every other pump of the pedal. It's difficult to work out the process, or to see why it's problematic, which is why I wrote the thread, but once you know how, it's really very quick and easy.
10-31-2019, 08:45 PM | #116 |
It's not how fast you go, it's how you go fast.
26
Rep 23
I installed the ultimate clutch pedal and it helps a lot. Feel is much better though 1 - 2 shift is still sloppy.
10-31-2019, 10:30 PM | #117 |
Rep 558
At first I thought it was a little hard, but now that I'm used to it I find it very smooth. Easier to drive smoothly than my MK7 GTI was.
2017 F80 ZCP - Mineral Grey Metallic
11-01-2019, 01:22 AM | #118 |
Rear Admiral
1485
Rep 1,706
Drives: Bavarian Milk Wagon
It's fine to me, same as the F80 and very similar to the E46 M3 clutch feel. There is definitely adjustment period if you're coming from JDM slick shifters (ah Honda I love your MT)
11-02-2019, 07:06 PM | #119 |
Rep 444
This is literally the easiest MT I've ever had. So many nannies.
2018 F87 LCI gone but not forgotten
2021 G80 6MT BSM |
Sedan_Clan25022.00 |
11-03-2019, 02:48 AM | #120 |
Law Enforcer
25022
Rep 22,269
Drives: '22 Chalk Gray Porsche C2S
You know it's funny......back when I was big into Honda's and street racing, the S2000 was touted as having the slickest manual transmission on the market. I spent a lot of seat time in the S2K back then, but couldn't, for the life of me, see what the hype was all about. I'll take my F8X's manual over any manual I've driven thus far.
Kankles1484.50 |
11-10-2019, 04:16 PM | #121 |
Rep 969
This may sound nuts, but by accident I found the car is a whole lot more enjoyable for me with the throttle set to normal/comfort. I spent the first 1000 miles driving in sport or sport+, and while the power and acceleration is intoxicating, I accidentally discovered that the car is more fun to drive in normal/comfort. The throttle tip-in is smooth, the power comes on linearly, and I can wind up to higher RPMs in everyday driving. It feels more like a sports car that takes some driver involvement, and is more inline with some of my past sports cars.
I still put it in sport when I want to haul off the line, but darned if normal/comfort isn’t smoother and more engaging on an everyday basis. This would be the first modern BMW I have owned where I don’t immediately put it into sport as soon as I start the car. |
11-10-2019, 07:13 PM | #122 | ||
6632
Rep 4,145
Drives: '18 M2 6MT
11-11-2019, 11:42 AM | #123 |
Everyday I'm shuffling
449
Rep 1,098
I may be a bit late in this thread, but wanted to add:
I have the DCT on both 135i and M2. The DCT in the M2 is much improved, in about all aspects. DCT completely takes care of the smoothness as far as the gas pedal is concerned - shifting, rev match, etc. Default in the M2 it is the Comfort mode, which I almost never use because it's boring for a car like the M2, but comes in handy when you have passengers in the car that don't like to be driven, not shaken. It's not just rpms and shifting points. The gas mappings are also changed, so the gas pedal feels different. I guess if you have the 6M manual, you only have one mapping and that's the equivalent to the Sport+ mode in DCT. DCT does nothing for the brake pedal - I still find the M2 much harder to brake smoothly. I can't get the "limousine stop" as easily as in the 135i. Maybe that gets better as the pads wear off a bit. Last edited by MPBK; 11-11-2019 at 03:51 PM.. |
11-11-2019, 03:43 PM | #124 |
Luxury at the redline :)
9105
Rep 7,563
Some dude in the F30 section discovered that the clutch slave cylinder from the E-Series BMW, without a CDV built in, works directly on the F-Series setup.
This is the easiest route in eliminating the CDV and still maintaining OEM specs. I never had an issue with shifting before but when the weather warms up in the springtime, I'm going to try this mod, just for the hell of it and see if it improves the overall shift feel.. *Newer* CDV Delete Method (Easier Way!) https://f30.bimmerpost.com/forums/sh....php?t=1666477 |
VisualEcho6632.00 LuvMyE923000.00 |
11-12-2019, 07:47 AM | #125 |
Occasionally frequent poster
3000
Rep 2,744
Thanks Poochie!
Current inventory:
Poochie9104.50 |
11-12-2019, 10:21 AM | #126 |
Rep 2,956
04-13-2020, 07:23 AM | #127 |
Rep 1,599
just me or are smooth starts tough?
bringing this thread back from the dead as it doesn't touch on my sense that I find it a little hard to get moving from dead stop smoothly with this 6MT?
but maybe that's just me |
04-13-2020, 09:45 AM | #129 |
Rep 1,485
when i removed my cdv it smoothed out the transition and i could shift into gear faster...its a nice cheap mod
Current Ride=2008 BMW 335xi
2017 BMW M240 Xdrive 2017 BMW M2 N55 6spd 2018 Infiniti Q60 Redsport AWD 2008 BMW 335ix |
04-13-2020, 11:35 AM | #130 |
Rep 7,295
From my experience with the CDV in the Z4M, it was really only noticeable when modulating the clutch from a stop or in reverse. So, if that’s what you’re looking for I think it would be worthwhile for you.
04-13-2020, 12:28 PM | #131 |
6632
Rep 4,145
Drives: '18 M2 6MT
I just wanted to update this thread with my experience now, since when I made the thread I had owned the car for just a month and 3 days, and now I've had it a little over 7 months.
Taking off is a breeze. The 1-2 shift I get right about 85% of the time, which is fine. The rest of the shifts are easy. I still think the gaps between the gears, side to side, is too wide, but the throw is fine. And I now really like the auto-rev feature. |
04-13-2020, 01:10 PM | #132 | |
Rep 308
