M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Brown Spots/Leaks On Garage Floor
      09-12-2019, 07:09 PM   #1
VFK_by_Midnight
VFK_by_Midnight's Avatar
79
Drives: BMW M2 Comp
Hey guys, I've got an M2C with <1k miles. Recently just noticed there were two new brown/rust colored spots that appeared on the garage floor, one on each side. They look to be roughly where the front wheels are (see attached pics).
Any idea what these might be? Brake fluid? Oil? Unfortunately I found these already dry. Can't seem to find the origin under the car either. Has anyone run into anything similar?
      09-12-2019, 09:22 PM   #2
tux2005
234
Drives: 2017 M2
Could it be rain run-off water from the brake rotors? Have a look for any similar drips on the wheel rims?
      09-13-2019, 06:26 AM   #3
CTSean
Drives: LCI BSM MT M2
It does look like dirty water. wet it and see if you can wash it from the floor. If so it's definitely not something oil based.
      09-13-2019, 01:03 PM   #4
aguy
Drives: 2020 BMW M2 Competition
It's just rust from the brakes.
I have identical spots in my garage from pulling the car in wet after washing it.
      09-13-2019, 03:02 PM   #5
VFK_by_Midnight
79
Drives: BMW M2 Comp
Thanks guys, this makes sense as I've washed it a couple times & pulled it straight in afterwards. Just wanted to be sure it wasn't part of a larger issue.
