03-26-2019, 03:24 PM | #1 |
Rep 247
AutoX tire pressure on stock PSS tires?
What is the optimal autocross tire pressure on the stock PSS tires? I have the staggered PSS setup.
Thanks for any advice! |
03-26-2019, 05:20 PM | #3 |
Rep 247
03-26-2019, 07:34 PM | #4 |
Rep 391
I ran higher in rear and softer in front by 4 psi. Used chalk to mark tires on my first autocross run, and looked how far the tires were rolling over. Then I Reduced the front pressure to 32psi and the roll over the side was nearly perfect on both. Was a cooler day though and cool pavement. Note I’m on 265/35r19 fronts star spec PSS and 285/35r19 rear PSS regular spec. I’ll continue to use chalk on first run to see what I need to adjust. For me it’s easier to go down in air than up as my pump is slow. So I start at 36
03-27-2019, 08:59 AM | #5 |
Rep 1,823
I would probably keep 32psi in all 4 corners. To me the handling balance is damn near perfect from the factory.
But you could get a bit more grip by dropping more, and then you have to chose front wheels if you want less understeer or rear if you want less oversteer. But the impact of these changes won't be easy to feel.
2017 BMW M2 German Spec
6MT, Driver's Package --> SOLD 2018 Camaro SS 1LE. Because race car! "Redline a day keeps the mechanics away" Last edited by 5.M0NSTER; 03-27-2019 at 09:34 AM.. |
04-24-2019, 09:39 AM | #6 |
Rep 125
Where does the M2C (stock) class for autocross?
2003 SGM SMG - Sold but not forgotten!
2010 JzB/DCT Moved on to next owner 2019 HS 6MT M2C |
04-24-2019, 09:42 AM | #7 |
Rep 3,335
Current Stable:
