07-23-2020, 09:18 PM | #23 |
Rep 4,551
Drives: 2015 328d xDrive
Not to be an ass but it's stories like this that make me 100% content with my stock tune
07-23-2020, 09:36 PM | #24 | |
Rep 855
Seems to me there is more to know from OP to potentially diagnose. Personally, I would get to a good indy shop to validate diagnosis and suggested remedy before making that substantial investment of replacement or loss from selling as is. |
CrashFL137.50 |
07-23-2020, 09:52 PM | #25 |
Rep 1,759
From my experience, regular motor hesitation and cylinder misfiring on a mild tune like yours will eventually lead to a motor rebuild. Some sooner and some later.
If one has to play around with plugs and gapping on a low mileage stock motor with a stock turbo to reduce misfiring and hesitation, it's time to sell the car if it has been modded. Cheapest way out is to get your local trusted mechanic to rebuild the motor or at least fix it to a point that it's driveable without codes and trade it in. |
07-23-2020, 10:13 PM | #26 | ||
Luxury at the redline :)
9105
Rep 7,563
You had a piggyback installed, you remove it, reset the adaptions - and voila; like magic, it never exist, without a trace.. 🤷🏻 Proof: https://www.bimmerpost.com/forums/sh...php?p=21988588 https://www.bimmerpost.com/forums/sh...php?p=21991389 The way you describe your timeline of events, you stated that you removed the Dinan Sport and then when with a BM3 flash tune. Did I miss something? |
07-23-2020, 10:19 PM | #27 |
Rep 2,505
Me too, but my stock M2c is kind of slow to me already. Have owned it for almost 2 years already. I'm getting the itch!!
07-23-2020, 10:29 PM | #28 | ||
Rep 929
07-23-2020, 10:39 PM | #29 | |
Rep 7,429
The reason behind this could be: 1) Anti-seize affects torque values leading to too much torque which could damage threads on the plug or cylinder head (unlikely unless you also have a off torque wrench and are really tightening the crap outta the plug) 2) Not exactly like you said unless you use a ridiculous amount. If you put too much anti seize on the plug it could get on the tip and the metal in the anti-seize can cause misfires. This is why most plug companies and car manufacturers also say not to use anti-seize. I'm not sure why people even use anti-seize, because the spark plug hole is supposed to be relatively clean and rust free. Unless the owner uses high pressure water to wash the engine bay, but even then most heads now a days are aluminium which should be ok with water. Here is a source as well: https://www.tomorrowstechnician.com/...er%2Dtightened.
Megator517.50 |
07-23-2020, 11:22 PM | #30 |
1287
Rep 1,675
Can you describe what is meant by the motor 'hesitation?
Like you floor it and you dont feel thr torque until a few seconds later? Isn't thst just turbo lag? |
07-23-2020, 11:24 PM | #31 | |
1287
Rep 1,675
07-24-2020, 12:41 AM | #32 |
9105
Rep 7,563
New short block:
https://parts.bmwnorthwest.com/p/BMW...002412514.html Used wholesalers: https://www.sharperedgeengines.com/r...bmw-m2-engines |
07-24-2020, 01:17 AM | #33 |
Rep 7,429
if the short block is ok (no holes in it, and no major scoring on the cylinder walls) then it would be cheapest to just rebuild the short block. Around $5K, maybe a bit more if machining is required.
07-24-2020, 02:36 AM | #34 | |
Rep 744
F87source7251.50 |
07-24-2020, 03:07 AM | #35 |
Rep 7,429
You know I keep thinking about this and something does not add up, especially since bm3 makes absolutely fantastic ots maps and op's m2 is really low mileage.
1) are you sure you flashed the correct map? 2) where are your data logs? If you do not have any at all, that likely is the problem. No data logs and running an ots map blind = huge Chance of blown motor. 3) how was your hpfp performing? It could have been your hpfp being super weak or you had a bad hpfp that couldn't meet the pressure demands resulting in low fuel rail pressure and therefore a misfire. This is the most common cause of a misfire on the F series n55 that I can think of, factoring in that all your other parts are in good working order. Again data logs are needed... 4) did you press the coil tab all the way down? And ensure the connector was plugged in properly? A little bit more info would be nice op, we are all trying to help you out in diagnosing this issue and point you in the cheapest path for repair.
DeadRabbitM216.00 |
07-24-2020, 05:38 AM | #36 | |
Rep 8
I've had first hand experience of excessive det on a previous engine that was probably a consequence of the fuel-pump having degraded with age and led to running lean at high load+revs. But the symptoms of misfire and then loss of compressions does sound very familiar. In my case part of the piston crown melted and bounced around the combustion chamber before exiting through the exhaust. IMO it's ok to tune a car as long as you understand the consequences to your warranty (and also you insurance as some will void if they figure out the car has been modified and not recorded with them, although this might be a UK thing only). Personally I wouldn't use something that modified the engine mapping without having first run some logs, or getting it onto some rollers, to check that the AFR, timing, and knock-sensor aren't doing stupid things. In terms of car tuning, breaking your engine is a kind of right of passage! It might be expensive but you learn a lot from it |
07-24-2020, 08:57 AM | #38 |
Rep 10
No not turbo lag feeling. More like when the suspension hits a bump but instead it’s the engine. I would describe it as missing.
07-24-2020, 11:11 AM | #40 |
Rep 1,115
Sorry for your luck.
Where's the datalogs? I really hope this wasn't another flash and full send situation. The fact the car was knocking when you hammered it in a roll makes me think you had LSPI and probably some knocking up top. If you don't verify the fuel quality in your area you are just asking for problems. Last edited by Pray for Mojo; 07-24-2020 at 11:17 AM.. |
07-24-2020, 11:19 AM | #41 | |
Rep 7,429
Just remember to do logs even with a custom dyno tune op, gas quality changes frequently. But the thing is it's weird that the ecu hasn't adapted to the crappy fuel quality and pushed a softer timing curve. Normally bmw ecus are really good at combating knock.
07-24-2020, 11:29 AM | #42 |
Rep 4,145
Low mileage M2 engine, $5,000 - https://car-part.com/cgi-bin/search.cgi
Mods: Yes.
07-24-2020, 11:51 AM | #43 |
Private NumNuts
522
Rep 321
Maybe you guys aren't aware, but the latest version of ISTA (4.24.x) now auto flags cars with "aftermarket software" without any manual intervention. I have seen at least two instances of this being reported. One on the instances was on the F80 forum and then the thread mysteriously disappeared. The other I saw the other day by this person (not me) in a Reddit group:
07-24-2020, 12:16 PM | #44 |
Rep 3,256
Suggest you take it to an independent place that specializes in BMWs. The dealer MO is to simply replace everything, which is probably why your quote is so high.
