07-04-2020, 06:12 PM | #67 | |
Rep 7,422
So imo there are only 2 systems out there that do all of the above properly and that is aquamist and torqbyte's cm5 lt and lts. But for the torqbyte system you will probably have to use aquamist jets since they are the best of the best, only issue is that they are BSP fittings not NPT so you will need adapters.
07-20-2020, 03:31 PM | #68 | |
Rep 200
07-27-2020, 06:11 PM | #69 | |
Rep 94
Thought I wasn't awake there was a revised version of the charge pipe! Have you seen an actual difference from the one they replaced to the broken one or did the dealer tell you it's a revised version of the old charge pipe (because it's a known issue ?) ? It's kinda weird if it's really a revised version as if it is, it should have been a recall not a fix for a problem once it brakes as it got to the point they made a revised one ahah *EDIT* where did your post go it was here 5 minutes ago |
Poochie9104.50 |
07-27-2020, 06:15 PM | #70 |
Luxury at the redline :)
9105
Rep 7,563
*Sorry, there are two active threads on the same subject, I replied to the wrong one.*
So, yes, below, is a photo I took today of the new, revised pipe and lower one is the original, broken pipe that they replaced. Photo of both juxtaposed; notice the enhanced lip, which attaches to the throttle body. |
07-28-2020, 08:53 AM | #71 |
Rep 1,389
does charegepipe flow on the N55 really matter so long as it isn't restrictive?
or put another way has it been proven that brands claiming higher flow with their chargepipes have proven any gains? trying to decide which pipe to get thinking of playing safe with the forge solution |
07-28-2020, 09:04 AM | #72 | |
Rep 94
Thou it's still weird they have a revised version for a product they know fails but do not make a recall for that product |
07-28-2020, 09:27 AM | #74 | |
Rep 1,644
I also think I answered my question from the other thread about how they were able to increase the length of the flange on the pipe and still have it line up with the clip opening on the throttle body. See attached image. |
Poochie9104.50 |
08-02-2020, 02:56 PM | #76 |
Rep 682
I joined the club yesterday. Appointment at the dealer on Wednesday.
Anyone try one of these? I may have an upgraded one in my future. https://x-ph.com/vr-speed-factory-vr...-m235-335-435/
08-02-2020, 05:21 PM | #77 | |
Rep 6,635
People also had fitment issues on xdrive n55 vehicles but I think that's been resolved. |
08-03-2020, 10:33 AM | #78 | |
Rep 682
Thanks.. if I go that route I’ll do the locktite on the meth bung before it goes on the car. Good tip.
08-03-2020, 11:39 AM | #79 | |
Rep 339
McGary911472.00 |
08-03-2020, 01:10 PM | #80 |
Rep 1,644
All the CPs are fine now. A few had some fitment options when the car first came out (common for aftermarket companies to rush things to market) but they've all been fixed. The VRSF you just need to tighten the meth bung plug. I think its even in the instructions they give you.
01-11-2021, 04:59 AM | #81 |
Rep 425
Been seeing a few cracked charge pipes on my local M2 Facebook group and I'm thinking whether I should replace my charge pipe with an aftermarket one even though I don't have any issues with the car at the moment.
My car is a 2017 6MT with 41,000km. No tune and the only mod is an MPE. Car has not done any track days and the car is no long under warranty too. I don't plan on tuning the car or doing any performance type mods, but I am considering to just change the charge pipe for peace of mind. Have people here been changing the stock charge pipe to an aftermarket piece just as a preventative measure? I just don't want to be caught out with a car that has to be towed away especially if I'm out with the family. I've never replaced a working component on a car as a preventative measure but this is the first bmw I've owned so it's a bit of foreign ground for me Even though the part and install will be around $450 USD, I'm leaning towards biting the bullet on this so I can avoid what pretty much seems like a a regular occurrence even for stock cars. Is that fair to say it's very common for stock n55s to have this issue over time? For stock cars, from what I've read on these forums and Facebook groups, it really seems like a luck of the draw type of thing? |
01-11-2021, 06:36 AM | #82 | |
Rep 1,644
We can confirm if it does break, bmw is replacing with a modified version that is beefed up in the problem area. I'm not sure if you can buy this version directly from bmw parts. The aftermarket ones I have not seen develop any issues, including my own. |
01-11-2021, 07:51 AM | #83 | |
Rep 94
BMWF87Melb201.00 |
01-12-2021, 07:26 AM | #84 | |
24178
Rep 190,750
BMWF87Melb201.00 |
05-14-2021, 03:45 AM | #85 |
Yoda of mods
1673
Rep 3,004
Drives: X5 RWD
Yep, 1st thing I will change.
03-23-2022, 10:01 AM | #87 |
24178
Rep 190,750
