07-21-2020, 01:12 PM | #23 | |
Rep 339
08-08-2021, 01:26 AM | #24 |
Rep 9
I've also experienced intermittent shuddering when engaging 1st gear that seems to happen more often when it's hot outside.
The worst seemed to be in heavy stop and go traffic which makes it seem like something is heak soaking. Are other people experiencing this with stock cooling setups? My car is fully stock when I experienced these. Haven't had any hot weather recently or tried upgraded intercooler/other cooling in hot weather but it seems to never happen anymore. |
10-06-2021, 09:37 PM | #26 |
Rep 553
Mine was done under warranty back in Jan 2019, after removing transmission dealer assessed flywheel was causing shudder.
Anyone with shudder problems, if not warranty work I would recommend the first option is to remove the Clutch Delay Valve. I did this several weeks ago and immediately noticed dramatic improvement to how the clutch engages when moving off from stationary. I'll type the long story below but any hint of shudder has disappeared. Even after the new clutch/flywheel I could induce shudder in city driving, moving off using say 6-700 rpm the car is far from stalling but often there would be shudder, it was like it created a resonant frequency. Using around 1Krpm & not letting them drop there was no shudder. Similarly if I was moving say 5-10kph with clutch in and then started engaging clutch with revs enough to smoothly accelerate I could get the shudder and have to disengage clutch, give more revs then re-engage clutch there was no shudder. So I've been driving the car like you would an old modded carburettor/lumpy camshaft car (ie easier to stall), keeping revs around 1K+ to move off avoided any shudder. At least with my M2 it didn't like the clutch engaging in 1st at low rpm even though the engine has plenty of torque with no risk of stalling. Then I removed the CDV and city driving has been transformed, I'm now moving off in 1st like I have the last 42yrs without any hint of shudder. Out of lockdown next week so can't wait to see what if any difference there is spirited and on track. |
10-17-2021, 10:03 AM | #28 | |
Rep 4,133
Did you get a new Master Cylinder? |
10-18-2021, 04:20 PM | #29 |
Rep 553
No, followed the procedure in the video in link below, don't change/swap any parts but just remove a rubber spacer & the metal restrictor piece from inside the slave while leaving the slave in situ. Not that you would want to, but you could re-install the cdv if needed.
https://f87.bimmerpost.com/forums/sh...7&postcount=50 |
AmuroRay2267.50 |
10-18-2021, 04:49 PM | #30 | |
Rep 4,133
Mods: Yes.
