08-24-2016, 09:21 AM | #23 |
Rep 1,541
Map 1 and 2 have small autotune adjustments like all maps. You will run up to the boost limit designated by the map. Your boost may not hit the targets. It will auto adjust and/or look at FF, PWM, FOL, IAT, avgIGN, etc to determine actual boost up to the targets designated by the map.
FSociety3810.00 |
08-24-2016, 09:43 AM | #24 | |||
IG @bmwF9xG80
3810
Rep 7,593
Map1 on M2 is like Map5 or 7 on M235 Map2 is def going to run like shit on 93, its a must to have DPs and e85 blend for this one. ** Requires EWG-add on connector not included in JB4 OBD2 so need to be purchased extra for Map2+ ** Map3 - Meth Map Map5 stutters and is not smooth w/o EWG-add on connector (Keep this in mind, if you intend on running map1 or 2 only you will be ok ) Map6 (Custom Map, Require Expertise in Tuning and JB4 parameters) (i wil be using this one for my Backend Flash and it will be my Race Map) Map7 on M2 will def require EWG-add on and e85 blend (not recommended for 93 applications) in my opinion after testing it and Terry seeing my logs Quote:
Boost Safety: 18 on M235 is fine but for M2 and X4 M40i needs to be raised to 20-21 I agree any map will run according to your cars condition (FF, FOL, iAT, avg_ign)
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 08-24-2016 at 02:06 PM.. |
Anthony235715.00 |
08-24-2016, 01:00 PM | #25 | |
BD_e92
357
Rep 1,748
08-24-2016, 02:05 PM | #26 | |
IG @bmwF9xG80
3810
Rep 7,593
So the JB4 will work as it would on a normal N55, map1 will add 4psi over stock (whatever the M2 makes at that location/weather/condition) and so on. My map1 hits 18psi and spikes to 20, my Map2 18-20 as well.
08-24-2016, 03:56 PM | #27 |
Rep 1,835
Drives: 2020 X4M CS
Apologies Ive just been researching...I literally am leaving now to get my car which has been at a body shop for 2 months....Im installing my JB4 tomm...I meant the user definable map. Even with BMWs built in precautions....fast change in climate or quality of fuel, all it takes is one pre detonation. Im just stating the obvious. As BMS says proffessionals only.
Leaning AFR, Advanced timing, More Boost, all the things that add power increase knock potential. So some kid/man trying to add power does one of all 3...bye bye birdy lol...
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 |
08-24-2016, 03:58 PM | #28 | |
BD_e92
357
Rep 1,748
08-24-2016, 07:10 PM | #29 | |
Rep 4,496
Map 1 is additive whereas maps 5 and 7 are both absolute - your note may be misread by others thought best to clear it up. At present map 1 is all that's recommended and upping boost cap beyond 18psi needs to be done do knowing that m2 charge pipe is the same as m235i. Some have failed on m235i at 17-18psi hence my words of caution for m2 users. BP
Fettled M135i EB AT - gone but not forgotten:
AW M2 DCT |
FSociety3810.00 |
08-24-2016, 07:25 PM | #30 | |
Rep 4,496
BMS m2 FW will no doubt allow jb4 to address overboost
AW M2 DCT |
FSociety3810.00 |
08-24-2016, 07:26 PM | #31 | ||
IG @bmwF9xG80
3810
Rep 7,593
08-25-2016, 11:28 AM | #32 | |
Rep 1,541
While you can do harm with map 6; it would be very difficult to do. You're right though; I've seen some scary user maps. Take it slow and do lots of reading and you should be good.
08-25-2016, 11:27 PM | #33 | |
Rep 571
* map4 is the best map for 93 oct after install the Dp,intake,cooler.... ** If any one want to tune the M2 you won't see a big difference over stock till u run meth or race gas or pure stg2. Last edited by 135iDCT; 08-26-2016 at 04:32 AM.. |
CosmosMpower2048.50 |
08-26-2016, 04:31 AM | #35 |
Rep 571
08-26-2016, 10:42 AM | #37 | |
Rep 1,541
08-26-2016, 01:46 PM | #38 | |
IG @bmwF9xG80
3810
Rep 7,593
I've posted all the map info on page 1 on this thread or you can also find it here http://www.n54tech.com/forums/showthread.php?t=18588 As other have said map4 is OEM Performance w/ JB4 active for logging Here's my 4455lbs (Driver + Full Tank) weighed X4 M40i with the same M2 engine except no DCT or Overboost 347whp/339wtq on 93 pump (stock) 355whp/376wtq on map1 371whp/395wtq on map2 These runs were with 0 adaptation since I wanted a realistic idea http://www.n54tech.com/forums/showpo...84&postcount=2 Then you can see here with hotter weather and humidity but a little e85 goes a long way both in 4th gear and 5th gear. 352whp/351wtq in 4th gear 382whp/412wtq in 4th gear map2 & e27 blend 378whp/424wtq in 5th gear map2 & e27 blend 372whp/450wtq in 5th gear map7 & e27 blend http://www.n54tech.com/forums/showpo...57&postcount=9
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 08-28-2016 at 01:03 PM.. |
08-26-2016, 02:43 PM | #39 |
Rep 571
08-26-2016, 02:49 PM | #40 | |
Rep 571
like i said on race gas or meth u will feel the difference. |
08-26-2016, 07:02 PM | #41 |
Rep 85
08-26-2016, 07:28 PM | #43 |
BD_e92
357
Rep 1,748
08-26-2016, 07:38 PM | #44 |
23785
Rep 190,128
Lets hear it!
