11-01-2023, 12:11 AM | #1 |
Rep 87
stock to fbo with dyno
Throughout the following days my beloved 2016 M2 manual 30k mile is going on the dyno stock & full bolt on BM3 tune
CTS Catless downpipe VRSF Charge pipe CTS Intercooler MST/CTS Turbo inlet (have both haven’t decided which one yet) GFB dv+ AFE drop in AFE oem intake duct Using Esso 91 e10 and tuning with bm3 91acn to provide safest results with my provinces fuel quality. Will be updating this post soon, just excited and wanted a place to share if anyone was interested 🙂 |
11-01-2023, 12:28 PM | #4 |
Rep 87
The results are in, with a datalog for the final pull on the 91acn file.. pretty in line with what I expected out of this car, and seems fairly typical for most stage 2 M2’s on lower quality fuel.
I may try the regular 91 file and see how it does but it’s the first snowfall of the year today of course so that will have to wait for now. I babied it home and only gave it one wot in 2nd gear around 3500rpm and it immediately spun and wheel hopped so I got out of it.. the catless downpipe is surprisingly tame and quiet with the stock non M perf exhaust, I love the way it sounds! https://bootmod3.net/log?id=6542797a9c66d258c903abe0 |
11-01-2023, 01:27 PM | #5 |
Rep 569
Great datapoint. Thanks for sharing
CanadianM280.50 |
11-01-2023, 05:12 PM | #7 |
Rep 87
11-02-2023, 11:15 AM | #8 |
24280
Rep 190,975
thank you for sharing
11-02-2023, 11:22 AM | #9 | |
Rep 4,161
And the intercooler's performance is...not good. It's almost 50F higher (on a run up to 6000RPM) than ambient.
Mods: Yes.
11-02-2023, 11:31 AM | #10 |
Rep 569
11-02-2023, 12:54 PM | #11 |
Rep 4,161
11-02-2023, 03:33 PM | #12 |
Rep 81
11-02-2023, 04:03 PM | #13 |
Rep 4,161
Absolutely.
Mods: Yes.
11-02-2023, 05:04 PM | #14 |
Rep 87
It was MST V2 for whoever asked!
Update on the car, seems to me my HPFP can’t keep up with the S2 91acn file, so a Dorch S1 upgrade is possibly in order. https://bootmod3.net/log?id=65440fc5fd77326f26c902be Also about the IC, I was just looking at a log out on the street and 3rd 3000rpm wot until the 6500rpm in 4th gear it raised from 46-54 Fahrenheit. Ambient temp was approx 40 degrees |
VGSON219.50 |
11-02-2023, 06:25 PM | #15 |
Rep 312
you have a 235 and we m2 guys have to be careful going with ones that are labeled "race"....They dont fit without modifying the brace in front of the radiator. Personally, I think a street intercooler that stays around 10deg above ambient is sufficient for most as most of us aren't hitting the race track for 30min sessions.
Also to OP...Yes a hpfp is a good idea. Our cars should have came with a Dorche stage 1 equivalent. |
CanadianM280.50 |
11-02-2023, 06:56 PM | #16 |
Rep 87
That’s part of the reason I wanted a smaller upgraded intercooler, never had to cut a thing and had zero difficulty installing👍
And I agree about the IC. This car never sees more than one or two wot pull on freeway a every other drive, and spirited back road driving it stayed cool from my observations. the cts logs are a huge improvement over my stock temps. I will change my plugs, the previous owner claimed they were two year old plugs but not many km driven on them. What does everyone recommend for plugs? My friend says to use the NGK 97506 but spark plugs are often highly debated I think I will be ordering a dorch stage 1.5 as they discontinued the stage 1, BM3 doesn’t have an option for the 1.5 so I will have to ask them about that. I am tempted to also get a flex fuel sensor to be able to have a little more power on demand with simply adding ethanol to the tank. You would think the M2 would have a better hpfp from factory |
Sultan hamdi255.50 |
11-02-2023, 08:23 PM | #18 | |
Rep 4,161
You can absolutely get away with a MAD/VRSF/BMS 5” and be ok, all are better than the CTS. |
11-02-2023, 11:47 PM | #19 |
Rep 87
Maybe you are mistaken, in my previous post I said it went up 8F after two full gears, 3000-6500rpm.
11-03-2023, 07:08 AM | #20 | |
Rep 4,161
https://bootmod3.net/log?id=6542797a9c66d258c903abe0 Single gear, starts at 72F and goes to 80F. No intercooler is going to be 100% efficient, and this idea that this intercooler (or most other ones) will regularly be with in 10F of ambient it not realistic. It realistically will be around 15-20F+ over ambient in anything around 70F and go up from there, so plan accordingly.
Mods: Yes.
11-03-2023, 09:29 AM | #21 |
Rep 87
Yes that’s indoors with one small fan blowing at the car haha, not a realistic driving scenario 😀 I did 8-10 logs driving the car and the IC worked as expected. Although I seem to having an unrelated isssue now 👍
I also posted two logs, you can see the IAT in that does not match the performance of the indoor with static air log |
11-06-2023, 11:31 AM | #22 | |
Rep 4,161
Your street log shows you making basically 14psi (vs 16-17psi in the dyno log) so you likely ran it in comfort mode, but it still noted IAT increase towards the end of the run. Next is the links I provided you in your prior thread where is shows in 30F weather, an increase of 17-20f+ over ambient. It only gets worse the longer the drive is, and the hotter it is outside. https://f87.bimmerpost.com/forums/showthread.php?t=2049782 FYI my car can be literally at ambient for 10-15 mins of my drive (ambients in the 70s to 80s) but after driving for 10-15 mis, under and around 10F. Not everyone needs what I have but I would pay the same money on the CTS vs another option that performs better. |
Kiddvegas68.00 |
