07-05-2022, 02:00 PM | #1 |
Rep 494
2021 m2 competition & aim solo 2 DL laptimer
Hopefully I'm the only moron here running a 21 on the track but figured I'd drop some knowledge that would have been helping as I was researching.
Aim doesnt support 2021 bmw m2 yet but with the help of support I was able to get 9 values. Below are pics of the values and settings. Hopefully this helps someone. |
07-05-2022, 04:41 PM | #3 |
Rep 494
07-05-2022, 04:44 PM | #4 | |
Rep 555
https://f80.bimmerpost.com/forums/sh....php?t=1017936
IG: M2C_SO |
M1500Z424.50 |
07-06-2022, 12:18 AM | #5 |
Rep 344
'21 M2 Comp here as well. I've been running a Solo 2 DL for quite some time wired into the CAN bus. I think I was able to get it to run via OBD with an older BMW ECU protocol, but it's been a while so I don't remember.
If you wire into the CAN, just run the BMW-F_series protocol. Use the guide that Fabb posted as a, well, guide to wire into the FEM on the passenger's side kick panel. I used factory connectors so it didn't require cutting—takes a little planning and about an hour to execute. You'll get all the data you need (except f'n oil pressure). |
07-06-2022, 11:59 PM | #6 | |
Rep 753
07-07-2022, 12:20 PM | #7 | |
Rep 494
07-07-2022, 10:06 PM | #8 |
Rep 344
Y'all are asking a lot of me . I did this back in April of last year and it took me a little while to remember how I did it.
This diagram I made should help. It's not a complicated task, but I may be explaining it poorly. As mentioned previously, for the newly tapped wires, I wanted to keep everything matching from a BMW standpoint—maybe you'd do it differently. Full size image The connectors I got are BMW 2 pin connectors, but I don't have a record of the part numbers. They look like 61132360043 and 61138373583, but I can't say for certain. My buddy who is a BMW master tech hooked me up with some pins I was missing. Again, if you're going to do it this way, get the BMW connectors because the wiring loom pins will slide right in and it's all reversible. Lastly, when connected this way, the AiM seems to get a wake signal when the car is off (really annoying) so it'll just draw it's battery down over time. My guess is something like the car's GPS positioning or some other self-check signal is pinging the CAN bus while the vehicle is off/locked and it's enough to wake the Solo. I'd love to help, honestly, but I'd prob have to charge more than it's worth for me and you right now. I may consider doing that in the future if there were enough people interested/willing to pay enough over cost. |
pal433.00 |
