M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > How to add more Bass to the M2 HK sound system
      08-01-2016, 09:55 AM   #1
srironman911
Taiwan
56
Drives: Alpine White BMW M2
Please let me know how to add more Bass to the M2 HK sound system...
      08-01-2016, 10:58 AM   #2
sarcastrix
Wallander
Sweden
158
2017 BMW M2  [0.00]
Depends on what you want from the system and how much money you want to spend - if you just want thumping bass with no overall sound improvement simply build a bass box in the trunk. But if want good quality sounds with better bass then the established thinking is all in this thread.
Which basically involves the following:
Disconnect Center Speaker.
Swap out front doors with Etons/Focal/BAVsound
Swap out rear deck with JL's
Move fader to the back 3-4 notches
Play around with Treble/Bass to your personal liking
If then you still want more bass maybe add the Bavsound Ghost Subwoofer / Bimmertech Amp
If you just want to spend money just order the complete BAVsound system or have custom install with a local sound shop.
M2 / Range Rover
Gone but not forgotten: Porsche 911 cab / S4 cab / M6 / E60 M5 V10 / E46 M3 CSL / E46 M3 SMG (x2)
      08-01-2016, 12:39 PM   #3
srironman911
Taiwan
56
Great, did some research and
1. Swap out front speakers with Etons B100W
https://www.amazon.com/Eton-10-Way-C...ilpage_o00_s00
2. Swap out rear deck speakers with JL Audio Evolution 4" Coaxial Speakers
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
3. Add the Technic ASD bypass harness
https://technicpnp.com/product/asd-bypass-harness/
contact technic and make sure right one...
http://technicpnp.com/contact.html#
4. BMW weather stripping on front door
Part numbers
51487300493 $14.78
51487300693 $14.78
part is called a Sealing Side Pan
5. Ebay BMW OEM Speaker Connector Harness Pigtail
http://www.ebay.com/itm/BMW-OEM-Spea...-/161420349903
Hopefully this is a good start as recommended by member selmeralto, I'll also ask him in his post...
      08-01-2016, 12:48 PM   #4
srironman911
Taiwan
56
Part numbers
51487300493 $14.78
51487300693 $14.78
Found 4. BMW weather stripping on front door part number incorrect or?
Original
Part numbers
51487300493 $14.78
51487300693 $14.78
New Find...
Driver side: 51-48-7-300-693 Price: $23.63
Passenger side: 51-48-7-300-694 Price: $22.96
      08-01-2016, 02:21 PM   #5
Viffermike
Viffermike's Avatar
Drives: '18 black-n-blue 718 Cayman
Part numbers
51487300493 $14.78
51487300693 $14.78
I suggest you do Nos. 1-3 -- and disconnect the center channel speaker even before any of that -- then stop and reassess. You don't even have your car yet. There's no sense in going any farther than this until you can hear how your car sounds for yourself, and upgrade from there.
Three additional points:
- All the pigtails do is make installation easier; they're not necessary at all.
- A lot of what selmeralto did, including the Eton component/JL Audio speaker combo, was based on my advice. He's done an amazing job of making his own sound (pun intended) decisions and documenting all of it.
- Realize that the OEM underseat drivers are not subwoofers in the true sense of the word. They are low-mid drivers that stop functioning well below about 80 Hz. This has been tested by another member recently in the 2 Series forums. If you want true gut-jiggling subs, a box in the trunk with its own amplifier is likely your only option.
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.--
<<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>>
      08-01-2016, 02:28 PM   #6
srironman911
Taiwan
56
Great, sounds like good advise, the funny part is 4 and 5 don't cost much and it's hard for me to grab items from another country... so might as well just grab together, also thinking BAVsound GHOST UNDERSEAT SUBWOOFER UPGRADE and a Bimmertech amp, but worried about going back to dealer for routine dealer ECU flashes... so gonna start this first, thanks Viffermike...
Viffermike1753.00
      08-04-2016, 02:48 PM   #7
twboy1999
Drives: 1994 honda accord
try listening to the stock audio system first
but ya, is pretty shit
2019 M2 HS 10000km and counting
      08-04-2016, 02:55 PM   #8
srironman911
Taiwan
56
Decided to do this first... First disconnect center speaker, then this...
About $14 each plus shipping
and if not good enough, will add subwoofer and amp after...
Viffermike1753.00
Fabb227.50
      04-10-2021, 09:56 PM   #9
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
325
Drives: 2018 BMW M2 LCI
Are there a new links to these speakers? Seems they are no longer available. 5 yrs later....
https://www.crutchfield.com/p_136C24...o-C2-400X.html
is this the one for the rear?
      04-23-2021, 08:14 AM   #10
nearwater4me
Drives: '22 G82 Base
Yes, that's the one recommended by many members on 2addict.com for the rear fill.
Etons are a pain to come by in the states, and I'm interested in swapping out the fronts because my fader is set towards the front.
Personally, I wouldn't sweat too much about the rears and rather spend more time deciding on the front drivers.
      04-23-2021, 09:55 AM   #11
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
325
I ordered my Etons @ Madisons.
      04-26-2021, 09:35 AM   #12
nearwater4me
Thanks for the info. Would you happen to have a link for the site?
Having a hard time googling Madisons.
Thanks!
      04-26-2021, 09:38 AM   #13
nearwater4me
If you'd like a simple solution to add bass without deep diving into changing other components, throw in a cheap powered sub.
Speaker level input from the sub channel works just fine.
https://rockfordfosgate.com/products/details/p300-10/
      04-26-2021, 10:40 AM   #14
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
325
Thanks!
https://www.madisoundspeakerstore.co...00%20W-%20Pair
I believe it’s this one. You would have to email them.
      04-26-2021, 11:54 AM   #15
nearwater4me
Awesome. Thanks for the link!
