M2 Technical Topics > Track / Autocross / Dragstrip > Schroth QuickFit and M2C fitment
      11-17-2020, 01:01 PM   #1
HOT M
HOT M's Avatar
Drives: 2019 M2C
Schroth QuickFit, anybody is using it with M2C seats? any other idea that will get you strapped in the seat for track use?
regards,
2019 M2C Sunset Orange/Black (Ohlins/swift coilovers, Ground Control Camber Plates, Dinan Heat exchanger, BM3 ECU tune, CF mirror caps, diffuser and rear spoiler, Vorsteiner V-FF 101 Patina Bronze wheels)
      11-17-2020, 07:35 PM   #2
asciimike
Drives: 2017 M2
2017 M2  [0.00]
You're out of luck: since there's no pass through, you can't safely run harnesses with those seats. Swap someone with an OG seat, go the Recaro Sportster CS path (AMX performance if you want OEM+ look), or go fixed back (I did an OEM+ look: https://f87.bimmerpost.com/forums/sh....php?t=1675296).
I think some folks will use the CG-Lock ala: https://www.soloperformance.com/CG-LOCK_p_83.html but I'm not a huge fan.
bentom2335.50
HOT M80.50
      11-18-2020, 10:09 AM   #3
HOT M
HOT M's Avatar
Drives: 2019 M2C
Thank you for the info, seat swap is out of the question for me. I thought there is another way or maybe one of the Schroth Quickfit, maybe the pro will fit, maybe the E82 or E92.
Anyhow, I do have the GC-Lock I used it on my Z4M for autocross. Not a big fan either but better than nothing.
Knowing that, I can't use a regular Hans style device, I will need the Simpson Hybrid S. Ok, well I tried.
