M2 Technical Topics > Track / Autocross / Dragstrip > Ok for 285/30/18 in the rear ?
      11-11-2020, 02:25 AM   #1
juicy
juicy's Avatar
Drives: F80 M3, F87 M2
Just wondering if I can use 285/30/18 in the rear. I run with dsc off but I'm not sure if this will affect other electronics like ABS.
I'm using 265/35/18 in the front.
      11-11-2020, 06:41 AM   #2
chief1richard
chief1richard's Avatar
2018 M2  [0.00]
I use 285/30/18 in the rear for my Track Days with 255/35/18 up front. Works well for me. Will be going 265 up front next tire replacement. Works well for me.
At a Point above 7,000 RPM.
      11-11-2020, 12:58 PM   #3
Fabb
Fabb's Avatar
Drives: 2019 M2C SO
Similar question. What's the disadvantage of running different sidewall profile on front and rear? There gotta be some drawbacks.
IG: M2C_SO
      11-11-2020, 01:01 PM   #4
juicy
juicy's Avatar
Thank you, glad to hear you have no issue with 285/30 in the rear which means more tire options
      11-11-2020, 09:28 PM   #5
chief1richard
2018 M2  [0.00]
There is no disadvantage to running a different sidewall profile. The aim is to maintain same diameter as original tire. Running a wider tire in the rear requires a shorter sidewall to maintain as close to possible a diameter as the original tire. So a 285/30 is 30% in sidewall height (30% of 285) vs 285/35 (35% of 285). Maintaining as close to tire diameter as OE is the goal. There are several threads that go into depth of this, and there is very good information on this site about tires.
Fabb228.50
      11-12-2020, 09:26 AM   #6
ebisu8
Dom
ebisu8's Avatar
Drives: E46 M3 Comp
The most common combination size and what I run is a 265/35 and 295/30.
      11-12-2020, 10:13 AM   #7
chief1richard
2018 M2  [0.00]
What tire brand do you use? I was looking to replace my Dunlops with Nittos but they don't have those sizes. Was looking for 100-200 treadwear.
      11-12-2020, 10:23 AM   #8
ebisu8
Dom
ebisu8's Avatar
Drives: E46 M3 Comp
Currently Michelin Cup2 Connect 240. I'll be trying Yokohama A052 next year.
      11-13-2020, 02:19 AM   #9
Gusman1
Gusman1's Avatar
Wouldn't a 295/35/18 be closer to OEM diameter?
18 LBB M2
      11-13-2020, 07:35 AM   #10
ebisu8
Dom
ebisu8's Avatar
Drives: E46 M3 Comp
I said most common combination, not closest to OEM. 265/35 and 295/30 is a common combination that is very close in diameter front/rear.
      11-13-2020, 10:56 AM   #11
Gusman1
Gusman1's Avatar
Understood. With those tire sizes I'm assuming a 9.5 front and 10.5 rear wheel would be used.
18 LBB M2
      11-17-2020, 10:57 AM   #12
chief1richard
2018 M2  [0.00]
Thats the wheel width I have been using.
      11-17-2020, 10:39 PM   #13
Gusman1
Gusman1's Avatar
How you liking the staggered setup?
This your daily or just weekend/track car?
18 LBB M2
      12-06-2020, 06:56 AM   #14
chief1richard
2018 M2  [0.00]
Like the Staggered set-up very much. Don't care for Square set-up. Run Staggered on Track, and switch to Staggered Street on way home from Track. I DD my M2, but don't commute to work with it. (Retired)
kiosko19.00
      12-10-2020, 12:26 PM   #15
kiosko
Drives: 2021 BMW M2C
Thanks for the input! I'm trying to figure out what I want to do handling wise when the factory tires are worn out. Can you expand on your experience with a square set up? what made you not like it, specifically the handling at the track.
Current 2021 M2C 6sp LBB and 2000 Boxster S
Gone 2017 M4C DCT YMB CCB, 2017 Audi S3, 2014 Audi S4, 2011 WRX, 1988 911 T track car. Oh, how I miss her!
      12-10-2020, 12:44 PM   #16
chief1richard
2018 M2  [0.00]
You are limited to how wide you can go in rear. I'm running 285/30/18 now and coming out of turns tires are spinning, especially on an uphill grade. Again, I run stock suspension, so 265/18 front and rear doesn't work for me. There are videos of people who say wider tires don't give you more tread contact, I don't buy it.
      12-15-2020, 10:58 AM   #17
Gusman1
Gusman1's Avatar
What wheel offsets you running on these?
18 LBB M2
      12-15-2020, 11:14 AM   #18
chief1richard
2018 M2  [0.00]
Apex FL-5 18x9.5 ET 28 Front Apex FL-5 18x10.5 ET 40 Rear.
      01-16-2021, 10:22 PM   #19
Doublej
40
Drives: 2020 X3M, 2022 911 GT3
Am considering this setup. Starting from scratch so curious what coilovers are you using? Do you know of any any known issues with clearance on certain coilovers for this staggered setup??
Current: 2020 X3M, 2022 911 GT3
Past:
2020 M2 Competition,2018 X3 M40i,2017 X3,2016 VW ,Golf R,2015 BMW M3,2010 VW GTI,2008 911 GT3,2005 VW GTI,2002 VW GTI 337
      01-17-2021, 08:09 AM   #20
chief1richard
2018 M2  [0.00]
Currently running Stock Suspension with no issues. Will be installing Ohlins Coil Overs in a week or two. I will update after install, but I do not foresee any problems.
