10-05-2023, 06:59 PM | #68 | |
Rep 375
Drives: 2020 M2C DCT
With regards to the second sentence, I don't agree. The B58/S58 has a completely different design and I really doubt it was changed because of the problems with the N55/S55 crank hub. BMW could have relatively easily fixed the crank hub problem by incorporating a key or a pinned design like the various aftermarket solutions. They probably didn't do that because it would have called attention to the design defect and then they would have faced a potential recall. I think it's not unreasonable to speculate that the crank hub has a two-piece design to simplify assembly. Had the block been designed with a removable timing cover, there would have been no reason to have a removable crank hub. They fcuked up when they designed the N55/S55, just like the other times they fcuked up in the past.
2020 M2C DCT Hockenheim Silver Metallic
chris7197334.00 |
10-05-2023, 08:27 PM | #69 | |
Rep 2,353
I believe the S58 will go down as the best I6 engine, it makes unbelievable power and yet problem free. The finally got an engine that is completely sorted. Too bad all of the cars they put it in are huge.
BSM ///M2cs, 6spd
chris7197334.00 bimmerdriver2179.50 |
10-05-2023, 08:55 PM | #70 | |
Rep 3,842
10-06-2023, 02:45 AM | #71 |
Rep 7,298
Rear timing doesn't bother me much. You shouldn't really have to touch the components in theory, and it's not exactly a fun day at the beach for S55 already even though it's in the front. If the chain or guides turns out to be like N20 then sure, it'll be terrible.
10-06-2023, 07:46 AM | #73 | |
Rep 2,353
Time will certainly tell..
BSM ///M2cs, 6spd
chris7197334.00 |
10-06-2023, 03:09 PM | #76 | |
Rep 375
10-06-2023, 03:12 PM | #77 | |
Rep 375
10-07-2023, 09:14 PM | #79 | |
Rep 2,353
Perhaps the power of the S58 was necessary in the G8x cars because they weigh more?
BSM ///M2cs, 6spd
bimmerdriver2179.50 ///MPhatic13862.50 |
10-08-2023, 10:33 AM | #80 |
Rep 1,074
Came from work, commuted. Didnt drive hard at all. I went with the Vargus spline lock solution as that for me made the most logical engineering sense. Its also the easiest on your wallet in terms of labor. Also there have been no failures with the combined spline lock and cbc solution. Been over a year and I abuse it.
Instagram: M2_Medusa
Reddevils7979.50 chris7197334.00 |
10-09-2023, 06:15 PM | #81 | |
Rep 7,298
10-11-2023, 12:40 PM | #82 | |
Rep 3,842
10-11-2023, 12:42 PM | #83 | |
Rep 8,970
They are not a service item. Certainly not 100k that's only cautious belt territory |
chris7197334.00 |
10-12-2023, 01:30 PM | #84 |
Rep 3,842
Yeah you're right, that is a bit short for a chain. I guess I am traumatized from my belt break repair bill $$$.
10-12-2023, 01:38 PM | #85 |
The Seeker
13863
Rep 3,323
I wonder if the N55/S55 is are like some other chain-driven engines where the chain stretches/slacks so much over time that it breaks the guides and has to be replaced anyway. I'd research it, but I imagine that's at a mileage my car will never see.
10-12-2023, 02:04 PM | #86 |
Rep 3,842
I read a few articles that mentioned stretching chains etc. I suppose at my cars current mileage rate I won't have to worry about it ....
10-13-2023, 05:11 AM | #88 |
Rep 8,970
