08-21-2021, 11:49 PM | #1 | |
Rep 3,540
S55 DME Removal and Replacement DIY
As a follow up to how I used the DME replacement method to have a tunable vehicle, here's the DIY on how to remove and replace the DME. Definitely not the fastest job out there with the multitude of connectors and wires that have to be handled!
21
Spider.75.50 Kelvin1000253.00 iWayne103.50 Midtown2020209.00 CoffeeLife397.00 GioM2Comp36.50 trainerjon48.50 esoj37156.00 marcw584.00 ebisu81079.50 rogeroger73.00 CosmosMpower2050.50 chris7197334.00 MarlboroM2C237.00 Detoxified204.50 ChrisK4449.00 mcvaughan704.00 hAxel91.00 BMW DIY Guy3075.00 Enabled1410.00 tailhappy0.00 |
08-23-2021, 09:58 AM | #3 |
Rep 63
Thank you for posting all the details!! It takes like 3x the amount of time to do the same job when recording a diy. Appreciate you doing it for the rest of us!
08-23-2021, 02:50 PM | #4 |
Rep 3,714
So you bought a second DME and tuned that one and if you ever have a warranty claim you'll swap back to your original un-tuned DME? How much was it to get a 2nd DME and code it, etc? Is it plug and play once it's coded to the car or is there additional work to swap it each time?
08-23-2021, 03:38 PM | #5 | |||
Rep 3,540
I traded my friend a nicer set of suspension for it.
chris7197334.00 |
08-25-2021, 11:22 AM | #6 |
Rep 7,298
Fairly clever. It's probably not dissipating more than 25 watts or something in that ballpark I would assume. Dominated by the thermals around it I would guess.
08-26-2021, 01:25 PM | #7 | ||||
Rep 1,262
Drives: BMW 1M
Think of tuning boxes that owners have removed and their cars have automatically flag up "suspected tuning" when the dealer plugs in the OBD. |
08-26-2021, 01:40 PM | #8 | |
Rep 1,803
08-26-2021, 02:01 PM | #9 | ||
Rep 1,262
Drives: BMW 1M
08-26-2021, 02:10 PM | #10 |
Rep 1,803
If I understood the question correctly, those items and a few more certainly ARE very important for the suspected tuning routine in ISTA.
08-26-2021, 02:36 PM | #11 | |
Rep 1,262
Drives: BMW 1M
If you had two cars, both tuned, one Farkle's way with those 3 items he mentions set as factory spec and one tuned with a Tuning box (then removed) both cars would be auto flagged for "suspected tuning" once plugged in? |
08-26-2021, 03:45 PM | #12 | |
Rep 1,803
The ISTA system is very picky. Even an update to a dme that wasn't done by a logged dealer computer will trigger 'suspected tuning'. That means that if you flash update your own dme with esys, the dealer computer will see that the software ID is not matching to what should be on there, and it will also trigger the 'suspected tuning' flag. Note, the dealer tech has to run the suspected tuning service function in order to determine if the car is tuned or not, for warranty purposes; although the flag can get recorded. A tuning box that is added on and then removed can only really be traced if the tuning box isn't of a great quality and if it triggers codes inside the DME. Keep in mind, the ignition key keeps track of the car's DTC, and that data does get transferred over. Otherwise a tuning box is often untraceable to the car systems once removed.
08-27-2021, 06:39 PM | #13 |
Rep 1,336
I could be wrong but the words chosen by FaRKle! and Enabled is they are not using the ecu swap to circumvent or hide that it has been tuned but to actually have the car tuned while still being able to go to the dealer for routine works.
Enabled1410.00 |
08-27-2021, 07:23 PM | #14 |
Rep 1,803
Exactly right
08-28-2021, 05:41 AM | #15 | |
Rep 1,262
Drives: BMW 1M
So oh course, kept the flash counter at zero etc for routine works |
Stryyker88.50 |
08-28-2021, 05:43 AM | #16 | |
Rep 1,262
Drives: BMW 1M
08-30-2021, 07:45 AM | #17 | |
Rep 1,803
I had helped with one F30 where someone had asked me to return it back to stock remotely. The flash counter was at 63, because they played with the flasher apps to make changes to their tune. Well, esys refused to flash initially, due to the flash counter. There are ways around it, of course. Dealer's ISTA would not override and would simply say that flash counter is full.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. Last edited by Enabled; 09-05-2021 at 08:52 AM.. |
Dr.Mark84.00 |
09-05-2021, 12:22 AM | #18 |
Rep 3,540
Worked with a forum member to swap his 2021's DME today! Physical swap took 1hr 40min, then Enabled did the rest.
Now there are two unlocked and tuned 2021 cars in NA! Last edited by FaRKle!; 09-05-2021 at 12:37 AM.. |
09-05-2021, 03:53 PM | #19 |
Rep 1,803
That's very fast! Impressed
09-05-2021, 07:20 PM | #20 |
Rep 6
I'm happy to report back that their solution works flawlessly, and I'm now a lucky owner of an unlocked and tuned '21 M2C!
Farkle took time out of his Saturday to remove & replace my DME, all while making sure to torque everything according to spec when putting it back together. There's a ton of little clips and things that get in the way and I'm super appreciative of the care and time he took to work on my car. Huge Kudos to Farkle and Enabled for coming up with a solution for '21 M2C owners! I'm super impressed of how this all came together, much respect goes out to Enabled for his intimate knowledge of how BMW systems function and his ability to problem solve. Thank you so much! |
4
