M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > OPF Removal: CEL or Limp Mode?
      11-22-2020, 03:13 PM   #67
VIERsr
Switzerland
2623
Sometimes I had cel and limp mode after 10 kms, some other times nothing for hundreds of kilometers. Sometimes I can push to the rev limiter with no issues (one time I also reached the speed limit), some other times it goes in limp mode if I go full throttle at 3000 rpm. No logic, the only way is to remap if you want to push hard your car and have no issues.
      11-22-2020, 04:44 PM   #68
kart driver
Drives: M & GT
But isn’t there an easy solution with the AK Motion unit which helps to resolve the issue completely after removing OPFs?
      11-23-2020, 01:09 AM   #69
VIERsr
Switzerland
2623
Yes it's a solution.
Easy? I don't know.
Nice looking? Not for me.
      11-23-2020, 02:50 PM   #70
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
Originally Posted by NISFAN View Post
I wonder if relocating the sensor tubes from after the catalytic converter to before, will fool the electronics by reporting back a pressure reading?
For those that don't know, the OPF fitted cars have a pressure measuring sensor in each exhaust. The pressure sampling tube is placed after (downstream) of the primary CAT, but before the 2ndary CAT / OPF canister. So it effectively measures exhaust pressure just prior to the OPF /CAT2 system. I guess when it sees a high reading threshold, it triggers an active regeneration. But at all times it needs to see some kind of reading as a test. That's why a total OPF delete triggers CEL/LIMP.
My thinking about how to fool it is in three forms. And by the way, I'm looking at replacing the OPF canister mid pipe to earlier style 2nd CAT type, not a full delete. Some of the techniques below could work for full delete too.
If you're putting secondary CATS back you should be fine. I did that and had no CEL, presumably as the cats give a back pressure that fooled the opf sensor.
NISFAN3488.50
      12-27-2020, 08:39 AM   #71
Mark 1M
Mark 1M's Avatar
349
Originally Posted by prompt View Post
Did you do a remap or something else?
How many miles have you done since removing it?
Do you drive the car hard,I mean revving over 5k rmp?
No remap car is standard.
around 1k no cel light.
it has been over 5k and no issues so far.
this mod was also done on a 2019 m4 comp and no problems with it the owner is a bmw tec.
prompt292.00
      03-26-2021, 01:20 AM   #72
M2_MEDUSA
M2_MEDUSA's Avatar
Drives: 2021 M2 Comp. SpecialEdition
Forgive me for my inability to understand basic terminology but I have a few questions:
1. What is an OPF and do all m2c models have them even in USA?
2. So I can’t put a AA midpipe on my car without it freaking out?
Thanks
      03-26-2021, 03:30 AM   #73
kart driver
Drives: M & GT
Thanks
The issue is non-existent for USA cars. You don’t have OPFs.
      04-18-2021, 06:44 PM   #74
RafBsac
Drives: M2 Competition
Hi from France guys !
For those who have to deal with OPF deleting issue regarding limb mode, THE ONLY SOLUTION : OPF Deleter by LEIB Engineering
https://www.leib-engineering.de/en/l...mpetition-f87n
So happy to find-out this system, my full Active Autowerke Equal Length resonated Midpipe and rear valved exhaust is on order !
This solution is BMW warranty friendly !
Enjoy ! ;-)
Moris3.00
      05-30-2021, 02:38 AM   #75
Sammy_V
Happy M40i driver
Sammy_V's Avatar
Belgium
57
Drives: 2020 X3 M40i
Enjoy ! ;-)
Hi there France
This is Belgium calling
How is your first experience with this?
Thx for the feedback
Sam
      05-30-2021, 03:47 AM   #76
prompt
Car Designer
prompt's Avatar
292
Drives: M2C
Enjoy ! ;-)
Any direct experience on this?
To me it looks like a simple bypass on the opf sensors near the gearbox,is just this or requires something else?
      05-30-2021, 03:38 PM   #77
MR.
MR.'s Avatar
Nothing else, just a bypass cable.
MR
      05-30-2021, 05:21 PM   #78
RafBsac
Sorry guys, like a lot of people, I'm still waiting for my AA EL midpipe and axle-back.
I didn't install the LEIB OPF Deleter yet, but different feed-backs are good !
      06-26-2021, 05:36 PM   #79
RafBsac
The Leib OPF Deters work perfectly ! Quite difficult to install on M2C's because of the lack of space but it works perfectly !
      12-04-2021, 12:30 PM   #80
leshkin
I just got my harness too, but instructions on how to do it are beyond vague Did you follow a guide to do this or just took bits off until you could access the sensors? Any tips would be most welcome
      12-16-2021, 03:27 AM   #81
Irielion
Drives: Bmw M2 Competition
I removed my OPF and after some hard runs it went into limp mode. The car stil drove oke, but without the strong power. With the Leib connectors it didn't went into limp mode anymore.
      07-26-2023, 06:54 AM   #82
Crossmax
Drives: M2 CS DCT HS
To everyone using the Leib OFP Delete module: are you still happy with it? Are you getting any error codes/limp mode at all, or has it been a solid fix?
      09-04-2023, 04:49 PM   #83
Rub1con76
Drives: Bmw F87 M2
I got a lightweight performance exhaust with AA single midpipe installed with leib connectors since May 23.
Intil last week not a single issue.
When i drive into Germany I got a drivetrain warming and limpmode.
Restart and fault was gone but drove to the nearest dealership. They told me the exhaust pressure sensor was the problem.
On the rest of the trip 2 more limp modes at different speeds.
I also have an AK Motion 1st gen installed for a longer period.
Today I drove about 2 x 20 km en after 5 km or so I got an engine light.
I don’t understanding Why this is happening after all these months.
@Rub1con76
      09-05-2023, 03:56 AM   #84
Dutch Devotion
Dutch Devotion's Avatar
123
Drives: F80M3 - M2 comp ETA 14.10.2019
Hi, I have been driving with AK too and although you disable the OPF with that strange wire fix where you had to solder the wires yourself to their motherboard (really WTF!) it never worked. (no support from AK or whatsoever so I had it taken back out of the car).
Have also tried the sensor cheats (Leib engineering or something) too, which did not work either., and recently noticed they are not offering them anymore.
Only thing that worked for me and never threw a CEL or put the car in drivetrain error (limb), was to disable it in Bootmode3 and I suppose MHD offers a similar solution.
Hope this helps.
Rub1con76202.50
      09-05-2023, 04:27 AM   #85
doughboy
doughboy's Avatar
1545
Mines a 2018 car (never updated) and when I first ran without DPF I got no CEL at all.
But I still disabled OPF & CAT in BM3 as I run decat too now.
I think one of the subsequent BMW DME updates also increased DPF sensor sensitivity which meant other folks got quick CEL/limp when removing OPF.
      09-19-2023, 01:03 PM   #86
Rub1con76
Drives: Bmw F87 M2
Today I went to my carshop and he connected it to ista.
2 fault codes that appeal on the AK to came up on ista.
Of you delete the codes they will show up again without starting the engine.
So the installer thinks that the leib Connectors are the issue.
I contacten them so i’m waiting for their feedback
@Rub1con76
      10-09-2023, 07:23 PM   #87
fourthchirpin
Drives: M2C, VW GTI 3.6, Infiniti G25x
what is the OPF, is this the same as the Cat?
is there a photo of this?
      10-10-2023, 02:16 PM   #88
doughboy
doughboy's Avatar
1545
OPF is an EU thing (maybe other territories too).
Petrol Particular Filter (OPF in German)
It replaces secondary CATs under the car with more restrictive canisters to remove soot from the exhaust gases but they sap power and make the exhaust much more muted.
