05-26-2021, 09:07 PM | #133 | |
Rep 7
Thanks! |
05-26-2021, 11:15 PM | #134 | |
Remove Before Flight
6822
Rep 1,611
I've got the TCK coilovers on with 300/600 springs on at the moment, with stock wheels and tires. The good: It's a FAR better suspension than stock-- and it *really* shines on the track. My instructor has a M2C, and he was *very* impressed with the suspension setup. Additionally, my buddy is a SCCA racer (Miata-Spec) and was out this past weekend-- he drove the car and really, *really* loved the suspension-- his exact words were "Don't change a thing." The bad: We've had some issues with ride height. With minimal lowering, I'm still having slight rubbing issues at the top of the rear wheels against the shrouds, and have also hit the bump stops a few times on expansion joints on the front. My shop (which is AWESOME) has a personal relationship with TCK and will be reaching out to him. The best bet at the moment is probably 400/700 on the springs. Not sure on that yet, but it's a possibility. Returning closer to stock ride height is another option. Apex EC-7's (M2C-specific offsets and 1/2" wider than stock) are still on order and I should see them in about three weeks. The recommend tires for the EC-7 wheelset are MP4S's in 265 & 295/30. However, Michelin recently (1 Apr) released a 285/30 which (on paper) might be a better match to the 265 front. However, a -30 series sidewall scares the hell out of me in CO (our roads? Driving off a cliff would be easier on the car)-- so I'm seriously considering going with MP4S's in a 255 & 275/35 setup-- they're about 7mm taller, but will fill up the wheel well, not lower the car too much, and provide a bit more contact patch-- they might be a reasonable compromise between traction and livability, especially if I'm running the MP4S's. Bonus points-- in that size, I can put Cup 2's on my stock wheels and use them for track days without having to mess with suspension height, resetting camber, etc. as both wheelsets and tire combinations would be near -identical. I'm still considering. puzzling and pondering-- I spent a few hours today doing the math on them as well as some other research. The car's in the shop for some warranty work (AC control panel) and an oil change at the moment-- when I pick it up, I'll double and triple-check to see that I can get 7mm of clearance at full lock on the front wheels. But at the moment? I'm sort of thinking the 255/275 combo is the way to go-- especially if I go with firmer springs. Running stock ride height (or a little lower) with the slightly larger sidewall seems to be great look from what I've seen. Performance-wise? While not as "optimal" as the 265/295 combination, it might be far more livable here in CO, and might keep the Minister of War and Finance from bruising her kidney's on Date Night. Updates as events warrant. R. Last edited by flybigjet; 05-26-2021 at 11:41 PM.. |
MovingChicane109.50 |
05-27-2021, 05:08 AM | #135 | |
Rep 7
What had been in my head was similar to what you were planning. Keeping the stock wheels and tires for daily use. I had been plotting using the apex’s for track days. The thought would be to run a track alignment, but also be able to dial the dampers between track days for road use. I’m less concerned about the sidewall in this case (not for DD use) so assume the 265/30s and 295/30s would be okay... I know you cannot say for sure, but it sounds like stock ride height could work to prevent the rubbing? Wondering if that would be an option that would allow the 300/600s to still work... Thanks again! And yes, do keep the Minister happy... |
05-27-2021, 06:15 PM | #136 | |
Rep 132
Toyo R888R in stock sizes are still about 1/2" wider and share stock diameter. Problem is they're on national back order. I'll be using Apex ec7 as well.
07-10-2021, 11:25 PM | #137 |
Rep 11
Anyone has pics of EC-7 18x9.5 ET28 255/35/18 square setup?
Listed as a popular fitment on the fitment page, can't seem to find pics though.
07-31-2021, 05:30 PM | #138 |
Rep 7
Just adding to the gallery. Stock suspension with Apex Recommended fitment for staggered 19 inch set up on M2C.
Apex EC-7s in anthracite with Michelin Pilot Sport Cup 2s. Front: 19x9.5" ET28 with 265/30-19 tires Rear: 19x10.5" ET45 with 295/30-19 tires Love the grip and the look! |
9
Rundskop148.00 Sundinisagod107.00 Dr.Mark84.00 chris7197334.00 Carrera2RS203.00 aftercorbu404.50 MovingChicane109.50 goforwand68.00 Bruuuce341.50 |
08-12-2021, 08:38 AM | #140 |
Rep 140
Newbie question. I know nothing about suspension and camber and fitment, so use small words and big pictures.
I'd like to get a set of Apex wheels for track day use. I have a bone stock 2020 M2C, which has the 2NH brakes of course. I will be upgrading the brake pads, but not the calipers or rotors, so the overall size shouldn't change. Apex recommends this fitment: Front & Rear: 19x9.5" ET28 with 265/30-19 tires Available in our EC-7 and SM-10 designs. Popular fitment. Front negative camber required. 275/30-19 tires can also fit, but requires additional front negative camber. Will I need camber plates or is there enough factory-available camber to work? Will I be able to switch back to my factory wheels without having to change camber settings? Thanks. |
08-12-2021, 11:59 AM | #141 | |
Rep 303
08-12-2021, 01:22 PM | #142 | |
3530
Rep 6,752
A 275/30-19 would likely rub up front without added camber and an aggressive track focused tire in the 265/30-19 size that runs a bit wider than a street tire could cause a slight issue as well. As you will quickly learn on track, added negative camber really helps with turn in, front end grip, and preventing accelerated wear on the outer shoulder of the tire as you're speed picks up. If you do plan on tracking often, camber plate would likely be a worthwhile investment, although some options will increase interior noise and harshness levels when driving on the street. If you were to increase your negative camber front or rear to accommodate a 275 or wide 265 track tire, your OEM wheels will still fit just fine without changing your alignment specs. If you have any other questions or would like an in depth fitment recommendation, feel free to send us an email at expert@apexraceparts.com! -Ian
08-12-2021, 02:13 PM | #143 |
Rep 303
A recent shot, on 265/245s looking forward t fitting 255/35 and 275/35s
Expert@ApexWheels3529.50 Sundinisagod107.00 |
08-12-2021, 03:17 PM | #144 | |
Rep 140
I'm getting more info from Geirsen. |
Expert@ApexWheels3529.50 |
08-20-2021, 06:55 PM | #145 |
Rep 11
Figure I should post my setup.
Square: 18x9.5" ET28 FL-5 Satin Black 265/35-18 PS4S Stock suspension, no issues. |
08-31-2021, 04:58 PM | #146 |
Rep 794
Drives: 2021 M2C, 97 M3
Apex Sm10
19x9.5 et28. 255/35R19 Yokohama A052 19x10.5 et45. 275/35R19 Yokohama A052
Performance Center Delivery, June 21, 2013: 2013 E92 335is | Le Mans Blue | Gray Leather with Black | 6MT | 19" Style 313's | Michelin Pilot Super Sports | BMW Carbon Fiber Rear Spoiler | |
09-04-2021, 01:27 PM | #149 | ||
Rep 794
09-06-2021, 05:08 PM | #150 |
Rep 1,610
Installed my EC7 today. Apex is A+ from ordering to receiving and installing the wheels. Super happy
09-06-2021, 10:04 PM | #152 | |
Rep 3,842
09-06-2021, 11:13 PM | #153 |
Rep 55
